#113 | |
Drives: 2013 WR Blue Limited Manual BRZ
#114 | |
Drives: like an asshat
#115 |
hella stock
Drives: BRZ Limited
Resistor won't work since the drl just dies when it isn't receiving enough power. Least when I tried anyway.
mods & accessories:
beat-sonic shark fin | raceseng apex r limited green | perrin intake | E85 | RS*R Super Down sus | Cleib CF Lip | STi Side Skirts | Rays Gram Lights 57DR |
| The Following User Says Thank You to caffeinejunky For This Useful Post: | Lithium (03-27-2014) |
#116 |
#117 |
I will see what I can do, the only way possible at this point is PWM which isnt an easy DIY. If I put one together and make them easily adjustable would people be interested? They wont be cheap, maybe 100 bucks, hell we can probably find one on amazon for cheaper than I can make/code/ship.
#118 | |
Drives: Neptune GR86
Nothing fancy though.
#119 | |
#120 |
Drives: 2014 BR"ZED" Sport-tech DGM MT
This may be a stupid idea but what if we could find extra clips that match these, could we do the mods to the wiring between them to make it a plug and play mod? That way we could just unplug it, if we wanted to return it to stock before we had to take it into the dealer for warranty work.Your thoughts? Also where would one start looking for these connectors?
#121 |
Like this? [ame="http://www.amazon.com/DROK-Controller-Modulation-Stepless-Governor/dp/B00C46O4YG/ref=sr_1_2?s=automotive&ie=UTF8&qid=1395974615&sr= 1-2&keywords=pulse+width+modulator"]Amazon.com: DROK 9-60V PWM DC Motor Speed Controller Pulse Width Modulation Stepless 20A/600W Switch Dimmer Governor: Automotive[/ame]
#122 |
Drives: BRZ-L
Nice write up, I'm going to knock this mod out today.
Edit: All done. Made it all plug/play and it is wired to turn off with the headlights. Thanks again for the excellent write up. Last edited by CIAGDDS; 03-29-2014 at 04:01 PM. |
#124 |
Drives: Brz WRB - Europe LHD
see initial posts, it's well explained. You need two diode per side, with opposite wiring/polarity.
#125 | |
Calibrate them as close as possible and put them inline to each DRL. You must make sure to Diode Isolate this circuit, I don't really know how it will react if current back feeds. The math allows both DRLs to be powered off a single unit but I think its cutting it pretty close, honestly I have no idea what the stock DRL wattage is at but I'm guessing its not a lot. I'm going to order two of these and set them up on my car. It can get a little tricky with two circuits so please don't follow my advice unless you really know what your doing, just hold off until I get together a walk through. |
#126 |
Drives: brz
| WTB Stock headlight projectors from retrofit OR a broken headlight | official_george | Exterior Parts (Aero, Lighting, Etc.) | 3 | 12-02-2013 04:32 PM |
| Right headlight wont turn on | Matt90 | Issues | Warranty | Recalls / TSB | 9 | 11-11-2013 04:56 PM |
| My turn. =( | jonbonazza | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 07-15-2013 03:57 PM |
| Voice Commands with new turn by turn in IOS6? | jadewbj | Electronics | Audio | NAV | Infotainment | 0 | 09-21-2012 11:11 AM |
