#99 | |
Drives: 2013 SWP Subaru BRZ Premium
Thanks, I like those connections. I'm not to picky about the lights coming with the headlights, is there a way to have the DRLs to a switch and them on manually when the headlight are on? Reason is I'd love to have them on the highway but not in the city.
#100 | |
Elite Recognized Geek
Drives: 2014 DGM BRZ Limited
I think I'm going to tackle this mod this weekend, and will probably build a "harness" like @modena mentioned so I don't have to solder diodes on the car.
Am I close?
#101 | |
Drives: DGM BRZ 6MT
BTW, awesome write-up, Lithium. I would do this, but I've never soldered anything before. Makes me kind of nervous. What heat-shrink tubing size would I need to fit the diode and wires? Last edited by TM; 03-20-2014 at 01:00 PM. |
#102 | |
Not trying to be a ****
Drives: BRZ - 6MT - GBS
For tips on soldering I would just watch a youtube how to video and you should be good man, its not like welding or anything. Use flux and it almost does the work for you. For heat shrink the easiest thing to do is get a small assortment and just eyeball it. You only need about 6 inches to do the whole thing.
-EvilBeaverFace - My 2013 Subaru BRZ - 6MT - Galaxy Blue Silica
Inland NW 86 Owners Club on Facebook (Spokane, WA/CDA, ID area) FRS/BRZ/GT86 Enthusiasts Facebook Group |
#103 | |
Drives: DGM BRZ 6MT
I'm wondering if I will need to do it on both sides or just one. |
#104 | |
Drives: 2013 WR Blue Limited Manual BRZ
#105 | |
#106 | |
No no, when I turned my headlights on the DRLs would normally be off. I had only modded one side but both DRLs were on.
#107 | |
Drives: like an asshat
| The Following User Says Thank You to Lithium For This Useful Post: | ericvanderwoodsen (03-24-2014) |
#108 | |
| The Following User Says Thank You to Lithium For This Useful Post: | codesplice (03-24-2014) |
#109 |
#110 | |
Thanks for posting the DIY Sent from my Nexus 4 using Tapatalk
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+ |
#111 |
It was never really a problem. I just modded both sides and it was the same anyway. Just thought it was weird on one setting that both sides were the same even though only one side was modded. No big deal.
#112 |
Diode will drop voltage by 0.6 volts
I like the idea of this mod and will probably get around to it eventually. One thing that no one has pointed out is that the diode has a voltage drop of 0.6 volts or so, though you probably wouldn't notice that loss in brightness.
If someone electronically inclined could try wiring a simple MOSFET circuit together on small breadboard, you might be able to get around this. Thanks for all of the pictures and instructions on accessing the wires. That's the toughest part to figure out. |
| WTB Stock headlight projectors from retrofit OR a broken headlight | official_george | Exterior Parts (Aero, Lighting, Etc.) | 3 | 12-02-2013 04:32 PM |
| Right headlight wont turn on | Matt90 | Issues | Warranty | Recalls / TSB | 9 | 11-11-2013 04:56 PM |
| My turn. =( | jonbonazza | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 07-15-2013 03:57 PM |
| Voice Commands with new turn by turn in IOS6? | jadewbj | Electronics | Audio | NAV | Infotainment | 0 | 09-21-2012 11:11 AM |
