Old 01-31-2014, 08:56 AM   #71
tranat
tranat's Avatar
Drives: Subaru BRZ SWP Limited
Originally Posted by TallTerror13 View Post
I think that you have the diode in the wrong spot from what you are saying. To me it sounds like you have the diode on the wire coming up from the DRLs and not on the wire for the boomerangs.
The DRL power wire and the boomerang light wire should be together, there should then be a diode with those two wires on the one side and then the boomerang power wire out of the harness on the other side.
Both DRLs are probably lighting up because they use the same power supply wire on the harness, so power to one is power to both.
Hope that helps.
Sent from my DROID RAZR using Tapatalk
First off I wanted thank you everyone for helping me out.
1) @TallTerror13 what you say is true and that is exactly what I did originally
- Cathode side going to DRL and Boomerang
- Anode side going to the Harness
- Result (Auto; Daytime): No DRLs and No Boomerangs
2) So I tried it without the diode and connected it directly to see
- Result (Auto; Daytime): Everything turned on; DRLs, Boomerangs, and HL
3) So then I decided to switch the wiring around to see if it works then
- Cathode side going to the Boomerang and Harness
- Anode side going to DRL
- Result (Auto; Daytime): Same as stock; just Boomerangs
4) So I finally ended up with the one I have on now
- Anode side going Boomerang and Harness
- Result (Auto; Daytime): DRLs but no Boomerangs :/
- Result (Auto; Nighttime): DRLs, Boomerangs, HL
I'm very confused why #1 shouldn't work; even if I only worked on one side of the car (the driver side), it should still work on that one side. I really hope I'm wrong though and that two diodes are needed (left and right side) for this mod to work.
Any help is greatly appreciated guys. Also I have not worked on the passenger side yet, but the DRLs seem to work well on Both sides of the car, staying on all the time day and night. (just to note that again)
tranat is offline   Reply With Quote
Old 01-31-2014, 08:58 AM   #72
tranat
tranat's Avatar
Originally Posted by Lithium View Post
Keep in touch, shot me a message if you have anymore trouble. please do both sides to eliminate the possibility of any feedback from another section of the circuit.
For sure and thank you. I will definitely get to it when I have the time
Old 01-31-2014, 12:04 PM   #73
xcelir8brz
Drives: 2013 BRZ Limited
Thanks again. Planning to do it when Chicagoland is warmer.
xcelir8brz is offline   Reply With Quote
Old 02-02-2014, 12:01 PM   #74
TallTerror13
TallTerror13's Avatar
Drives: 2014 DGM BRZ & 2015 WRB WRX
What would be stopping power coming from the wiring harness through the green wire, then down the orange wire and into the DRLs?
TallTerror13 is offline   Reply With Quote
Old 02-02-2014, 01:21 PM   #75
kayoh
kayoh's Avatar
Drives: 2014 SWP Limited BRZ
My diagram was wrong so I just deleted it, thanks for catching that
kayoh is offline   Reply With Quote
Old 02-16-2014, 07:06 AM   #76
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
Haven't read the whole thread so not sure what the current discussion is. Just wanted to stop in and say I did this mod today and it works great. Thanks @Lithium
Happened to notice that when I finished one side and turned my lights on that both of my DRLs stayed on and it kind of surprised me, shouldn't only the side I completed stay on? It doesn't really matter and isn't important I was just curious.
EvilBeaverFace is offline   Reply With Quote
Old 02-17-2014, 11:13 AM   #77
TallTerror13
@Lithium Just to touch on the issue that everyone is having with when they wire one side both work, shouldn't you wire a diode on the DRL harness just like the one for the boomerang harness? That way your not sending power back through?
So, both of the harnesses on the anode side of their own diode, both of the lights on the cathode side of their own corresponding diode, and then a jumper wire in between the two diodes on the cathode sides.
Old 02-17-2014, 11:17 PM   #78
Lithium
Lithium's Avatar
Drives: like an asshat
It sounds like both DRLs are on the same relay. If you diode isolate each DRL 12Volt then it will stop the back feeding but to be honest its not really an issue unless someone wanted to turn individual DRLs on independently..... Maybe turn the left/right DRL in to a turn signal too...... ALL IN FAVOR SAY AYE!!!!??????
Lithium is offline   Reply With Quote
Old 02-17-2014, 11:30 PM   #79
TallTerror13
Is there a main reason to have the first pair of diodes in there?
Old 02-17-2014, 11:50 PM   #80
Lithium
Lithium's Avatar
If you did this it would stop both DRLs from turning on once the car was in night mode. I believe @Dr. BRZ did this exact thing. Is this what your referring to? You might have to post some artwork of what your talking about.
Old 02-18-2014, 12:42 AM   #81
TallTerror13
Never mind, I see its purpose now. The one to stop all of the headlights coming on when just shooting for the boomerangs to be on.
Old 03-06-2014, 08:57 PM   #82
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
I would personally recommend against using this method, simply because the DRL's are at full brightness at nighttime. It would be much better to dim them partially with a PWM like the new Mercedes do. I'll be posting up a DIY for this very shortly.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
The Following 2 Users Say Thank You to Acree For This Useful Post:
KelvinBRZ (03-07-2014), Lithium (03-06-2014)
Old 03-06-2014, 10:17 PM   #83
Lithium
Lithium's Avatar
I can see everyone's concern but these DRL really aren't that bright. They're no brighter than the headlights and the DRL beam doesn't stray to far from waist level. Having Pulse Width capabilities would be nice, please post a link when you get that nailed down. You should just grab a microprocessor and remove the diodes all together, Arduino Uno would be my personal choice.
Old 03-06-2014, 10:29 PM   #84
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Dude you're awesome, this exactly what I was going to post tonight, to see if anyone knew how I could dim the bottom LEDs when the full headlights come on, so I don't blind people at night. Can't wait for your DIY.
Deathalo is offline   Reply With Quote
Search this Thread:
Advanced Search
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 04:32 PM
Right headlight wont turn on Matt90 Issues | Warranty | Recalls / TSB 9 11-11-2013 04:56 PM
My turn. =( jonbonazza Scion FR-S / Toyota 86 GT86 General Forum 28 07-15-2013 03:57 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 11:11 AM
