#15 |
Drives: Brz WRB - Europe LHD
Thanks for you confirmation! that's right!
#16 | |
Drives: like an asshat
| The Following User Says Thank You to Lithium For This Useful Post: | DarkestBuddha (12-09-2013) |
#17 |
Drives: BRZ limited GBS
^ I see, thanks.
had the diode the wrong way. |
#18 |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
Subbed. I'll probably do this mod at some point once I get my BRZ back. Thanks for the awesome write up!
#19 |
Drives: WRB BRZ
Sorry to clarrify
The red wire there is the wire from the DRL, the side that it is attached to, does that connect to the green wire from the head light harness , and the left side of the diode connect to the brown wire from the head light harness? Sorry not really good with electrical stuff, really want to do this but a bit confused, if some one could do a basic ms paint of how to wire it up would be much appreciated. |
#20 | |
The other side of cutted green wire must be wired to anode. From cathode (K) you reach white 12+ of DRL.
#21 |
Drives: WRB BRZ
Alright I understand it now. Thanks for the clarification.
| The Following User Says Thank You to Kefu For This Useful Post: | Trap63 (12-14-2013) |
#22 |
im seriously impressed you got that diode in there on the left side infront of the drivers seat.
there is almost no space there. i just added extensions to the green wire. even adding those extensions were a pain. Last edited by DarkestBuddha; 12-14-2013 at 08:30 PM. |
#23 |
Thanks, I work on circuit boards all day so our engine bay is much larger than I'm used to. It did take me some time to be completely honest. How did your install go?
| The Following User Says Thank You to Lithium For This Useful Post: | Trap63 (12-15-2013) |
#24 | |
#25 |
Drives: 2016 STi DGM
Cool. But can't ya just turn on the driving lights and have same effect? :P
-2014 SSM BRZ MT
#26 | |
Drives: Neptune GR86
You could have just made it so the DRLs stayed on with the headlights without worrying about the boomerangs, correct? Or am I missing something? Edit: I guess it seems to be the simplest way to get the DRLs to stay on with the headlights though.
![]() Last edited by Andrew025; 12-15-2013 at 04:28 AM. |
#27 |
I enclose my wiring for better understanding.
In my schema: cut the green wire brown=====> to white DRL wire yellow=====> soldered together brown *======>CATHODE side of diode blue======> soldered to ANODE. CATHODE TO GREEN WIRE OUT OF HARNESS ANODE TO GREEN WIRE OF HARNESS. Basically once you get the green also cutted, insert the diode in this way.
![]() Last edited by Trap63; 12-15-2013 at 06:13 AM. |
#28 |
Another suggestion for front foglight.
Maybe possibile (with another diode) to have fog light ON when you have high headlights ON.......very JDM for aggressive highway trip.....all people grant you a bit of road here, but not so polite....
| WTB Stock headlight projectors from retrofit OR a broken headlight | official_george | Exterior Parts (Aero, Lighting, Etc.) | 3 | 12-02-2013 04:32 PM |
| Right headlight wont turn on | Matt90 | Issues | Warranty | Recalls / TSB | 9 | 11-11-2013 04:56 PM |
| My turn. =( | jonbonazza | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 07-15-2013 03:57 PM |
| Voice Commands with new turn by turn in IOS6? | jadewbj | Electronics | Audio | NAV | Infotainment | 0 | 09-21-2012 11:11 AM |
