Old 05-29-2014, 12:27 AM   #169
horatioo
Drives: CBC
count me in for the lithium option!
horatioo is offline   Reply With Quote
Old 06-16-2014, 03:59 PM   #170
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Completed this project thanks to @marcoaferrer soldering skillz, the results are awesome!
Old 07-05-2014, 03:11 PM   #171
Candlejack
Ignorance Intolerant
Candlejack's Avatar
Drives: '13 WRB BRZ Limited
Did anyone figure out for sure which Toyobaru connectors to buy for a plug-and play harness? I'd like to do it that way instead--without having to junk yard dive for some connectors.
Also how would you make the DRL source wire plug-and play? I guess you'd have to follow the harness there to where it plugs in. So maybe you'd need 4 connectors on both sides:
1 male headlight
1 female headlight
1 male DRL
1 female DRL
Following this wiring diagram to see if I can figure it out. But wiring diagrams are confusing as fak.
*Edit* Looks like A38 (RH side) and A60 (LH Side) Although they look like the same connector.
Candlejack is offline   Reply With Quote
Old 08-11-2014, 11:56 PM   #172
ohmai18
ohmai18's Avatar
Drives: Subaru BRZ
Going to try this soon!
ohmai18 is offline   Reply With Quote
Old 08-13-2014, 09:49 PM   #173
Splicer006
Drives: 2013 Subaru BRZ
My Local store only had 6A, 100V Diodes, Will this be OK?
Splicer006 is offline   Reply With Quote
Old 08-16-2014, 05:08 AM   #174
trinxified
Drives: Subaru BRZ Aozora Edition
Umm... on my 2015 BRZ Series.Blue, The second option upwards after "AUTO" already does this... I notice the regular DRL turn off though when you're e-brake is up.
What's the difference?
trinxified is offline   Reply With Quote
Old 08-17-2014, 01:43 AM   #175
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
First, it's not just your special "Series.Blue" that does this, they all do, we all know this, and this has been mentioned.
Second, it's not the same thing, and the whole point of this thread was so we don't have to do that. Reason being, turning the stalk to that position is the same as turning the headlights on, the dash and radio dims, the side markers turn on, the lights stay on when you turn the car off. We were trying to (and have achieved) actual automatic boomerang daytime running lights.
Deathalo is offline   Reply With Quote
The Following 2 Users Say Thank You to Deathalo For This Useful Post:
Hyper4mance2k (09-03-2014), Trap63 (08-17-2014)
Old 09-08-2014, 10:37 AM   #176
Cdub998
Cdub998's Avatar
Drives: 2014 BRZ
Hey Guys, quick question. I just did this mod this weekend and only wired up the left side. Both sides work and everything is lit up (only used the single diode method). Is there any need to do the other side if everything is working?
Cdub998 is offline   Reply With Quote
Old 09-09-2014, 11:59 AM   #177
Cdub998
Cdub998's Avatar
Drives: 2014 BRZ
Ha. Nevermind with that. I see what happened. At night the auto works and everything comes on. DRLS and Boomerangs. But in the day the DRLs and only 1 boomerang came on. Damn I have to wire the other side now.
Old 09-13-2014, 02:48 AM   #178
Phaedrus29
Phaedrus29's Avatar
Lotta people on this thread and the PnP one seem to prefer the stock behavior (or dimmed DRLs with headlights). Would the DRLs at full brightness at night really be annoying to drivers or something? I think it would look good with them on but don't want to cause issues on the road.....
Phaedrus29 is offline   Reply With Quote
Old 09-13-2014, 03:26 AM   #179
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
At somewhat close distances they would be kind of annoying but I doubt they're bright enough to cause any real concern.
I can drive through my neighborhood (15mph) with just the leds on and see just fine.
Old 01-04-2015, 10:04 PM   #180
sactownbwoy
sactownbwoy's Avatar
Drives: 2014 BRZ Limited
Just did mine, next will be the mod to make them brighter
sactownbwoy is offline   Reply With Quote
Old 01-05-2015, 04:34 PM   #181
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
So has any one managed to create a plug-n-play harness for this mod?
Or does anyone have suggestions on what kind of taps to use so I don't have to solder?
I'm feeling apprehensive about soldering the green wire while its still in the car, and I'd rather not have to remove the headlights just so I can comfortably solder that one wire. I've had bad luck with past projects (not on the BRZ) where I'd accidentally melt plastic because I wasnt being careful enough.
PandaSPUR is offline   Reply With Quote
Old 01-05-2015, 04:59 PM   #182
amaciose
amaciose's Avatar
Drives: 2013 BRZ Limited
http://www.ft86club.com/forums/showthread.php?t=65718
TL;DR: Yes, and Diode Dynamics took over the project a few months back. It's due sometime this month or next.
amaciose is offline   Reply With Quote
The Following User Says Thank You to amaciose For This Useful Post:
PandaSPUR (01-05-2015)
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 04:32 PM
Right headlight wont turn on Matt90 Issues | Warranty | Recalls / TSB 9 11-11-2013 04:56 PM
My turn. =( jonbonazza Scion FR-S / Toyota 86 GT86 General Forum 28 07-15-2013 03:57 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 11:11 AM
