Old 04-01-2014, 12:40 AM   #127
CIAGDDS
Drives: BRZ-L
@d3lirious, maybe this will help.
CIAGDDS is offline   Reply With Quote
The Following 6 Users Say Thank You to CIAGDDS For This Useful Post:
codesplice (04-01-2014), d3lirious (04-02-2014), DrDuquette (04-01-2014), Lithium (04-02-2014), stockysnail (04-01-2014), Trap63 (04-01-2014)
Old 04-01-2014, 04:44 PM   #128
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I tried this mod. Took a long time and my back isn't happy about it. I finished the drivers side, turned on the lights and realized I had the source and plug sides backwards. I fixed it then tried the lights again. The lights looked the same as stock. I see many people asking if both sides need to be wired to see a change but not seeing anyone give a clear yes or no to that question. At that point I said screw it and put it back to stock since I won't be able to remove my front bumper with this mod unless I get more supplies and disconnects. I used a variety of vampire taps, butts, and the like as I don't have a solder kit. I wouldn't have been able to undo it if I had soldered it so probably better I didn't.
stockysnail is offline   Reply With Quote
Old 04-01-2014, 05:07 PM   #129
CIAGDDS
Drives: BRZ-L
Yes. You need to do it to both sides.
The Following 2 Users Say Thank You to CIAGDDS For This Useful Post:
Old 04-01-2014, 10:20 PM   #130
Lithium
Lithium's Avatar
Drives: like an asshat
Great Visual, thank you very much.
Lithium is offline   Reply With Quote
The Following User Says Thank You to Lithium For This Useful Post:
CIAGDDS (04-01-2014)
Old 04-02-2014, 07:48 AM   #131
d3lirious
d3lirious's Avatar
Drives: brz
i love you man :P
d3lirious is offline   Reply With Quote
Old 04-03-2014, 05:07 AM   #132
Ace0711
Drives: Subaru BRZ WRB 6MT
Hey guys maybe some of you could provide some guidance. I followed that great diagram and have everything wired and soldered (except the 1side of the bottom drl source wire. But both sides are tied to my diode as I'm testing) but my boomerangs (headlight DRL doesn't come on at all now. No matter the setting but everything else works. I couldn't find out how to remove the harness (with green wire) so I took off my bumper and removed the headlights and made my connections (soldered and taped). I made sure everything was hooked back up, it all works, side markers and high beams included but not the LEDs (boomerangs) in the headlights. I'm going try and sleep on it but everything looks right according to the diagram. Any help is appreciated.
Ace0711 is offline   Reply With Quote
Old 04-03-2014, 10:23 AM   #133
CIAGDDS
Drives: BRZ-L
If you snap a couple pics of your connections maybe I can see what's going on.
Old 04-03-2014, 11:22 PM   #134
Lithium
Lithium's Avatar
Did everything go well? You didn't even need our help!
Old 04-04-2014, 04:04 AM   #135
Ace0711
Success
Hey guys thanks for the outreach but everything works great now. I followed the diagram and realized I misinterpreted the green wire harness part and just had to cut,switch and resolder my wires( thankfully I made extensions). It looks seriously mean! Leaves quite the impact and should be stock from the factory.
Big thanks to Lithium and everyone else, this community rocks!
The Following User Says Thank You to Ace0711 For This Useful Post:
Lithium (04-04-2014)
Old 04-15-2014, 01:20 PM   #136
TM
TM's Avatar
Drives: DGM BRZ 6MT
Does anyone know where the wires from the DRL leads into? The reason is because I want to solder it to the DRL above the harness so I can easily remove my bumper in the future instead of having a permanent wire attached it to.
TM is offline   Reply With Quote
Old 04-27-2014, 03:45 PM   #137
KelvinBRZ
GBS Mafia Member
KelvinBRZ's Avatar
Drives: with Snow mode on
Nice write up, I'm going to knock this mod out today.
Edit: All done. Made it all plug/play and it is wired to turn off with the headlights. Thanks again for the excellent write up.
Any chance we can meet up in socal so I could ask you to do the mod to my car? I would reimburse you for your time of course, and even buy you a drink!
I'm not competent enough to fiddle around with wires and I have no previous electrical experience at all
GBS Mafia
KelvinBRZ is offline   Reply With Quote
Old 04-27-2014, 04:15 PM   #138
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
What did you use (ie parts) to make it a plug and play?
Thanks for any info
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 05-11-2014, 09:01 PM   #139
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Plug and play, plug and play, plug and play, plug and play plug and play....
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
FLYFISHR (05-12-2014), Lithium (05-13-2014)
Old 05-12-2014, 05:01 PM   #140
Sportsguy83
Drives: Limited BRZ
@Lithium
The Following User Says Thank You to Sportsguy83 For This Useful Post:
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 04:32 PM
Right headlight wont turn on Matt90 Issues | Warranty | Recalls / TSB 9 11-11-2013 04:56 PM
My turn. =( jonbonazza Scion FR-S / Toyota 86 GT86 General Forum 28 07-15-2013 03:57 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 11:11 AM
