Old 12-19-2013, 11:56 PM   #127
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
That's what the "factory tuned" version of the Jackson Racing kit is designed for, and that's exactly how we're testing our kit up front.
Maybe I missed it somewhere; but what made you choose the JR kit over the KW kit?
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 12-20-2013, 12:38 AM   #128
ramiram1984
Drives: 2016 STi DGM
Originally Posted by shaunsweeney View Post
I guess the question is would it be worth changing the header, it is obviously a terrible design, and replace with the catted UEL and get a tune.
I don't want a torque dip at all and I still see a slight one with this kit. Then again, I don't want to spend this much money and have another $500+ in tunes to take care of on top of it.
I guess the real question is how much the FT86 SpeedFactory catted UEL changes the VE of this engine.
Now go look at KW digital assassin's greater torque dip...
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 12-20-2013, 02:24 AM   #129
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
I think the key here is that if you really want to tackle the very minor differences a header will make when going S/C you can expect to see very small gains for a fairly large sum of money.
I will likely get a EL header at some point and the front runner is the HKS at this point due to it's proven performance but Kraftwerks is releasing a EL too and it will work with their kit (some EL's won't due to pulley clearance issues) so I'm waiting to see. Sam's TQ is looking better without the dip and I'm fairly certain the dip would go away on mine if I went with any of the headers as even the RevWorks header has been proven to eliminate the dip.
$1,200 for a good header gets you another 6.3TQ and 1.8TQ at the top end of the spectrum and will kill the TQ dip and that's only speculation because we don't have the same exhaust setup either. I have a catted over/front pipe combo so 2 cats in my system vs Sam with no cats. People looking at UEL will likely not do as good as the EL seems to be what this engine likes when S/C
digital_assassin is offline   Reply With Quote
Old 12-20-2013, 02:52 AM   #130
shaunsweeney
shaunsweeney's Avatar
Drives: 2014 FR-S MT Asphalt Grey
This is why I am intrigued by the possibility of the FT86 SpeedFactory Catted UEL. It knocks out that dip and is going to be priced much better than the other options currently available.
Thanks for showing me the KW kit, because now I have to decided which one I like better. The KW has some great pluses like the separate belt drive. Hmmmmm
shaunsweeney is offline   Reply With Quote
Old 12-20-2013, 04:31 AM   #131
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
I'm a newb to engines. I understand the very basics. Can someone point me to a direction where I can learn why increasing the exhaust flow in the header would not improve SC performance? If we look at the engine as a fancy air pump, anything reducing resistance will make life easier on the engine.
Maybe the picture will change once we begin to push more power out of a supercharged motor?
OjiGeorge is offline   Reply With Quote
Old 12-20-2013, 05:05 AM   #132
They essentially make the same power, but the Jackson Racing kit does it utilizing 87% of the rated capacity, while the Kraftwerks kit does it utilizing 99% of the rated capacity. Kraftwerks touts larger piping and larger intercoolers, but yet the kit is less efficient? Hmmm. The expandability to a C38 means nothing to us, because it's more power than the stock driveline can handle (Transmission, axles). See math here: http://www.ft86club.com/forums/showp...&postcount=549
The Jackson Racing kit also has less points for failure (less pulleys added, less complicated belt system, etc.).
As far as we have observed, we have not seen the Kraftwerks car at the track, except for the Import Tuner FR shootout. This doesn't mean that they're not getting private track time, but we're at the track nearly every weekend. It's difficult to NOT run into us. We've observed the Jackson Racing cars at a multitude of events.
Additionally, when we ask Jackson Racing a question, they give us an answer. Kraftwerks, not so much. See: http://www.ft86club.com/forums/showp...&postcount=541
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
diirk (12-20-2013), shaunsweeney (12-20-2013), smbstyle (12-20-2013), Victor Draken (12-20-2013)
Old 12-20-2013, 05:28 AM   #133
shaunsweeney
If you alter the flow characteristics of the exhaust the volumetric effeciency changes. When a kit is supplied with a tune designed for a specific volumetric effeciency (i.e. stock exhaust), any changes which effect that require additional tuning to account for the change.
In some instances the changes are so minimal that a tune is not absoultely necessary for safe operation, but may be wanted for optimal performance and reliability.
Old 12-20-2013, 05:31 AM   #134
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Originally Posted by sw20kosh View Post
Whats this I don't even...
I thought your best NA numbers came out the rear of a JDL UEL? =P
My best numbers was 198 out of a prototype T1R Header out of Canada. The next best as 195 out of a HKS EL
Ref : http://www.ft86club.com/forums/showthread.php?t=41525
I don't recall saying that the JDL UELs were the best performing ones, only that they're probably the best out of the UEL selection that we've tuned here.
Cheers!
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
Old 12-20-2013, 05:33 AM   #135
shaunsweeney
Thanks for that reply. It kind of helps me in my decision process. I am not familiar with SC setups as I am more of a turbo guy when it comes to FI knowledge.
I wasn't sure if the belt setup on the KW kit was a plus or minus. The plus to me was if the belt broke, I can still drive (this is my DD). The miuns is as stated, added complexity. I also didn't realize they have already pushed their SC to damn near 100%! If there is one thing I learned from the turbo world, you always want a little headroom.
I also don't plan on anything over what the stock transmission can handle. Upgrading axles isn't the end of the world, but I would also like to avoid that if possible.
Old 12-20-2013, 07:33 AM   #136
Victor Draken
Drives: Toyota Gt86
I'm getting every day more interested in the Jackson racing S/C.
To bad I have already a 3" Perrin exhaust with a 2.5" catted downpipe combo from
Nameless.
So will have to understand if it is still possible to etune the mods I have and the S/C, and run the JR safely.
Victor Draken is offline   Reply With Quote
Old 12-20-2013, 12:24 PM   #137
sw20kosh
Drives: 2013 Black FR-S
Where is this whole "our trans and axles can only handle the power/trq of ~270 whp / 220 wtq" coming from? Is there hard evidence that I have missed? I haven't seen this happen to any high hp 86.
Old 12-20-2013, 02:39 PM   #138
gmsii
gmsii's Avatar
bro...ur math can't be correct
what is the size of the JR sc pulley that comes with the kit?
gmsii is offline   Reply With Quote
Old 12-20-2013, 03:12 PM   #139
Then please correct my math so that I can amend my post/information.
The JR sc pulley is 110mm diameter.
Old 12-20-2013, 03:35 PM   #140
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
I recall -- and I might be wrong -- Crawford breaking their axle(s). Obviously, they were pushing a lot more power than most of us but that's one case of broken axle(s).
600HP axles can be had from DSS for about $900ish... so, not too, too bad for peace of mind.
cobrabyte is offline   Reply With Quote
280 whp, maybe the next day, rotrex, some day soon
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 01:57 AM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 10:51 AM
Drift-Office N/A tune zuldajin Engine, Exhaust, Transmission 14 07-09-2013 09:38 PM
Drift-Office Stage 1, 92 Oct tune BRZranger Engine, Exhaust, Transmission 15 01-07-2013 10:40 PM
