#113 | |
Drives: 86
#114 | |
Drives: 2005 Toyota Camry
This is just grouping similarly spec'd cars together. In the end, all that can be done is evidence provided. Oh, @solidONE when I say evidence, I mean evidence in the form of controlled conditions and isolated situations. The two articles you referenced has glaring holes: 1) BBK vs.. stock pads? Even a "street" aftermarket pad will be way better than used OEM pads. Just because it's a Corvette doesn't mean it has good pads, there's plenty of bean counters at GM to ensure that. 2) sway bars modified, then springs/shocks? I'm willing to bet that if the parts were swapped, the lap time gain (or rather, shaved) would be reversed. Again, if you feel strongly about the points system being off, we're all ears. I can speak from personal experience that adding sway bars to my car (with Ohlins) is NOT going to make my car faster. However, better tires or a wider contact patch will make an immediate difference. -alex |
#115 |
#116 |
#117 | |
![]() Would love to find that mystical gap between my lap times and those of a stock car driven by a superior driver. And no, no pressure in the canyons. My car was way too full and too many things were moving/sliding around in the back. -alex |
#118 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | mav1178 (02-18-2014) |
#119 |
Drives: FR-S Whiteout
Seriously guys... If I had the magic sway bar setup and it was giving me a decent advantage.... you guys would be the LAST to find out. I'm not going to prove it then just to have it taken away.... Especially if I spent my hard earned money on them. Emphasis 'hard earned' and 'money'.
I really like how my springs are set up, but I'll have to part and sell it because of the rules. I'm determined to begin from the bottom up. I'm also stuck with these 300TW tires I bought for the sole purpose to use them in 86 cup stock class. $600 bux down the drain.. Who's going to buy these tires from me? You? Will you want to trade me some 215 RS3 for them? Last edited by solidONE; 02-18-2014 at 05:19 AM. |
#120 | |
#121 |
Not everyone is a big baller like yourself. Budget is limited.
#122 | |
Track Junkie
Drives: 2013 Subaru BRZ Limited, 2005 S2000
I'm sorry that you spent money on parts before the rules came out and that you're super determined to fit into a class that you can't based on decisions you made on your own. Ideally we should've made the rule for stock class be that you have to be bone stock but I guess this is what we get for giving the class a .5pt wiggle room. Crap I didn't realize you become instant big baller status just for showing up for a track day running a car as is. I could've been bragging to everyone I know WAAAAY sooner
| The Following User Says Thank You to ImperiousRex For This Useful Post: | solidONE (02-18-2014) |
#123 |
LMAO! You are simply awesome, Ted. Emphasis 'simply'. Maybe because it may prove to be as much value as lowering springs. And if you guys decide to change the ruling on sways, where would that leave me then? More parts I cannot use.
I'm sure you know exactly why you are in the "big baller" category around here. Nice car, BTW.
#124 | |||
That's what I am interested in seeing... and it's not for my sake. It's for everyone else who will be impacted by rule changes, because it WILL make cars be reclassed. Quote:
I don't want to preach but when it comes to track events and modifying the car, most people don't know what it truly means to run a track event. If you want to run a track event, you have to live with the very real possibility of writing off the entire cost of the car. If you can't do that (or can't afford to do that), then something else is amiss. I got a lot of parts for my car last year, thinking I was just going to go to the track occasionally. Turns out, if I had waited another 3 months I would have 1) found out that Ohlins would bump me up to Street Class, and 2) I would've saved $700 on my Ohlins due to a market adjustment in their pricing. Am I sad I lost out on $700? Yes. Will I move on from this knowing things change? Yes. I really suggest you do the same. Not discounting your "lost money" on parts, but that is the reality of modifications and rules for any type of competition, professional or amateur. But your posts have brought up something we should look at adding: some type of "form" or mechanism to request a rules change. Something simple like: Part: Proposed point change/exclusion (50 words or less): Supporting evidence: Documents/links: Quote:
- sway bar point change (if any) - re-balance of spring/shock mods - procedure/requirements for rule changes to be considered (see above) -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | solidONE (02-18-2014) |
#125 | |
As for points on sways and springs I think .25 pts. is fair for a set of springs and .125 for each sway bar modified or changed and no penalty for removal of sway bar. Or else no points added for both the springs or sways. |
#126 | ||
It's the same as if you ordered some custom wheels or painted the car or any other thing that takes time between payment, and "completion" of the item/service's function. Who knows, if the rules never changed but your car was totaled by a tornado in Los Angeles, will you sit there and complain about "lost" mods? My point is, none of these rule changes are made to exclude anyone. If you feel you are left out but have justification for the old points system, let us know. But keep in mind several things: - modifying sway bars + the impact of sway bar improvements w/ spring/coilover vs just sway bars by themselves - supporting information (or just a really well thought out argument with proper premise and without fallacy/holes in your statement) - Use my "submission form" for proposed rule changes: Quote:
-alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | WillRacer1jz (02-19-2014) |
| Classifieds rules | ZionsWrath | Site Announcements / Questions / Issues | 19 | 04-14-2014 07:40 PM |
| 2014 FT86CUP rules discussion | CSG Mike | Tracking / Autocross / HPDE / Drifting | 34 | 11-18-2013 05:15 PM |
| Berk Technology FT86Cup Rules/Classing Discussion | CSG Mike | Southern California | 3 | 02-22-2013 05:11 PM |
