#43 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
#44 |
Drives: 2014 GT86
PandaSPUR: issue is relatively low ground clearance even for stock for rally-ish driving on gravel roads with potential roadholes/jumps or in deeper snow. Those plastic panels (mostly meant not for protection, but to decrease air drag)/mud flaps (to save somewhat bumper paint from chips) won't do much protecting from scraping engine/bottom. While rally sump underguard panels may help with protection when you do scrape/hit, better would be prevent scraping/hits by avoiding them completely with more ground clearance.
#45 | |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
#46 | |
Drives: 2013 Ultramarine FR-S
| The Following User Says Thank You to DustinS For This Useful Post: | BigFatFlip (05-11-2016) |
#47 |
Drives: ...Cars...
#48 | |
Sounds like a rally build would be right up your alley. Nameless Performance Rally BRZ on the bottom. liftedbrz from Instagram on the top.
#49 | |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
![]() ^this (looks badass btw!). Its been a while since I've looked at the subtle solutions website, but it looks like they now sell SPC LCAs and "alignment correction" kits. I've never liked the lack of detail on their website, but I've found them to be very responsive with e-mail. |
| The Following User Says Thank You to BigFatFlip For This Useful Post: | DustinS (05-11-2016) |
#50 |
You can also look into Anderson Design and Fabrication. He takes into account camber setting and adjusts his kits accordingly. So Camber stays within Factory specs. He has a lot of great products and good customer service as well. Can't really go wrong with either company.
#51 |
Dismember
Drives: 2013 Red Scion FR-S
I wonder if the stock LCAs can't be reinforced and then re-drilled. A bit low-rent, I'm sure, but then so is a threaded rod end in bending, which is what every single adjustable solution uses for our platform.
There's also the whiteline camber bushings.
#52 | |
#53 |
Dismember
I believe the SPC control arms have reports of snapping bolts in that slot. Hence me not suggesting slots.
#54 |
Drives: 2014 WRB BRZ Limited
What size wheels and tires are those? I think I have decided that 16 inch wheels with meatier tires on stock suspension could be my solution for now, considering that for every 10 miles on farm roads I do 100 highway. I need a middle ground approach.
#55 |
16x6.5? WRX Wheels with 215/65/16 You would not be able to fit these with stock suspension. This requires a 1" lift
| Where to Lift with Two Post Lift? | Don Ivey | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 08-18-2022 09:51 AM |
| Lift rental | Calidrifter | Southern California | 15 | 06-04-2013 11:23 PM |
| EZ Car lift | RRnold | Other Vehicles & General Automotive Discussions | 13 | 11-09-2012 05:20 PM |
| How to lift? | Mo707 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 08-28-2012 01:57 PM |
| don't lift | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 08-17-2012 12:51 PM |
