#2115 |
Drives: 13' Scion FRS MT
Short video, exhaust is a bit louder than it sounds in the video (GoPro mic isn't great...)
[ame]http://youtu.be/cYXFOHL5Y6I[/ame]
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport 13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook | |
#2116 |
This header sounds like a holy grail for me:
- kills the dip - no tuning needed = no risk of voiding warranty - boxer rumble I really couldn't ask for more. However, looking at @hattrickey 's dyno post #2109 I started worrying that flattening the torque curve happens mostly by shaving the early peak of the oem torque, rather than filling up the dip? I'm trying to find a good baseline for this chart, I 'm aware different dynos show different results, but when I google "fa20 stock dyno" on most charts I see torque peaking around 140 lb-ft before the dip (e.g., here: http://www.edmunds.com/car-reviews/t...no-tested.html) and @hattrickey 's baseline (before tune) never reaches 120 lb-ft before 5K revs? Basically, comparing hattrickey's baseline to available stock dyno charts it looks like the torque curve gets flattened mostly by shaving the pre-dip peak. What am I missing? ps1: I ignored the dyno in the 1st post simply because it comes from the manufacturer ps2: I really hope I'm missing something as I'd love to get this header if indeed it fills up the dip Last edited by sobrz; 08-10-2014 at 05:26 PM. |
#2117 | |
Drives: Scion FR-S
| The Following 2 Users Say Thank You to kodyo For This Useful Post: | hattrickey (08-10-2014), STV3 (08-10-2014) |
#2118 | |
Drives: Scion FR-S
The stock FR-S looks like it hit just over 120ft/lb of torque at 3100 RPM, dipped significantly and then didn't get back over 120ft/lb until 5850 RPM. My baseline with the header and exhaust shows being just below 120ft/lb the entire rev range until 5000 RPM when it continually increases and peaks at 138ft/lb's. So in conclusion, I sacrificed a VERY small amount of torque by filling up that curve with this header but again, you need to remember that this is a different car so my car could have been more in line with what we see with the baseline torque curve. Hope this helps ![]()
My build thread:
http://www.ft86club.com/forums/showthread.php?t=63292 |
#2119 |
Thanks for the second chart, @hattrickey, its very helpful. I photoshopped the 100% stock frs curve (blue) onto your first graph.
Looks like the header indeed shaves some torque in the 3Ks and adds in the 4Ks, nicely flattening out the curve (assuming it's fair to compare two different engines on the same dyno). There is a statement in the edmund's piece that starts ringing true: "Apparently the dip was purposeful on the part of the FR-S/BRZ powertrain engineers -- they intentionally traded some sauce at 4000 rpm in order to gain some driveability lower in the rev range." So I guess the question I'm asking myself now is: would I rather have more low end torque with a mid-range dip, or a flat consistent torque curve that gives up some of the low-end? And the right answer based on your dyno seems to be that I just need to forget about the warranty and get both header and tune. :/ Last edited by sobrz; 08-10-2014 at 11:51 PM. |
| The Following User Says Thank You to sobrz For This Useful Post: | Trettiosjuan (09-15-2014) |
#2120 |
So elite I'm 1338
Drives: WRB Subaru BRZ
Installed my FT86SF catted UEL, Motive OP, Motiv Catted FP, and my HKS Legamax Sports on Friday.
I'm pleased.
-Jack Burton |
#2121 |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
Are you running an aftermarket engine tune? If not, any codes thrown? Which intake are you using?
#2122 |
So elite I'm 1338
@Turkish No tune. No codes (yet). I am still using the stock intake, no drop in.
-Jack Burton |
| The Following User Says Thank You to tahdizzle For This Useful Post: | Turkish (08-12-2014) |
#2123 |
The cynic
Drives: An ambulance
Some great area under the curve gained here!
#2124 |
So elite I'm 1338
I'll get a clip up asap
-Jack Burton |
#2126 |
So elite I'm 1338
Sound clip of brz exhaust: [ame]http://youtu.be/Clv27JfNnq8[/ame]
-Jack Burton |
| The Following 2 Users Say Thank You to tahdizzle For This Useful Post: | Marchy (08-14-2014), Team STILLEN (08-14-2014) |
#2127 |
So elite I'm 1338
Camera on my phone, but it will do
-Jack Burton |
#2128 | |
Serial Cone Killer
| Tags |
| catted uel header, ft86speedfactory header, is my order ready yet? |
| Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 107 | 03-29-2016 11:48 AM |
| catted header or catted front pipe? | gabeg86 | Engine, Exhaust, Transmission | 28 | 10-13-2015 01:32 PM |
| P&l EL catted and coated header. | wootwoot | Engine, Exhaust, Bolt-Ons | 8 | 10-11-2013 01:50 AM |
| Catted UEL Header | Cjymiller | Engine, Exhaust, Transmission | 20 | 05-24-2013 01:01 PM |
| ***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 12 | 10-24-2012 11:12 PM |
