#15 |
Drives: 2013 FRS, 2008 R32
18x9.5 +40 wheels with 265/35 Michelin PSS. -2 degrees camber all around. All 4 fenders rolled. ~1.5" drop on RCE T0's. Pics of my car and ride height in my build thread.
Only slight rubbing at front at FULL lock. Only rubbing on drivers side rear during very hard cornering and very hard compression. Since I installed my grimmspeed strut bar, no rubbing during cornering (less body roll )You should be pretty good with 255's with rolled fenders. Extreme conditions will cause rubbing though. It comes with the territory. I bet 245's is the sweet spot but it all depends the look you're going for. There is minimal performance gains with anything wider than a 225 on this car (while remaining N/A anyway). |
| The Following User Says Thank You to mfbmike For This Useful Post: | switchlanez (12-12-2013) |
#16 |
Glorious BRZ Master Race
Drives: Subaru Libird
BUMP
I still haven't found anybody with the specific setup of 255/35R18 tires on 9.5 +45 offset wheels and I am concerned about the front inner clearance with the liner by the firewall or any suspension arms (not the outer fender lip/sidemarker) at full lock. I am lowered 1.4" on coilovers with -1.9 degrees of camber in front. I understand tire model matters for clearance and believe Hankook Ventus V12 would be a safe bet.
#17 | |
Drives: 18 BRZ tS, 27 GRMN 86
Thanks! |
#18 | |
One possible resolution is steering stops: http://www.seriesblueadventures.com/...ment%EF%BB%BF/ In my case, I eventually went staggered with 18x8.5 235/40 front and 18x9.5 265/35 rear. The skinnier front was needed because I also switched from coilovers to TRD springs/Bilstein B8 struts which has even less inner clearance.
| The Following User Says Thank You to switchlanez For This Useful Post: | botbs (03-07-2018) |
#19 | |
Personally I'm running 18x9.5 +38 square with 255/35 18 Firestone Firehawk Indy 500's lowered about 1.5 inches and I do not rub anywhere. Camber settings: -2.2 F / -1.5 R
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
| The Following User Says Thank You to tyler_win_photo For This Useful Post: | botbs (03-08-2018) |
| Will this fit? (width, offset and tire size Qs) | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4467 | 01-10-2024 03:49 PM |
| Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel | Infamous Performance | Wheels and Tires | 122 | 02-13-2014 12:34 PM |
| Lowered 1" and have a 265/35 or 255/35 tire +38 offset please post pics! | ScionFR-S | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 01-30-2014 03:26 PM |
| Perrin Front Front LCA Bushes Zero Offset SOLD | Captain Snooze | Australia Classifieds | 0 | 05-05-2013 05:14 AM |
| Sport Touring class. What tire/wheel size are you running? | UncleFester | Tracking / Autocross / HPDE / Drifting | 7 | 07-19-2012 04:56 PM |
