#1107 |
PhoneFlash by EcuTeK
Now through the end of the year we're offering 5% off on the purchase of a Flash & Go/Innovate/NA tune + our Flex Fuel kit. This can also be combined with an EcuTek License and/or EcuTek Cable Kit. Use coupon code DT-COMBO-5 at checkout. Enjoy and happy holidays!
Sincerely, Delicious Tuning Last edited by DeliciousTuning; 04-11-2019 at 06:15 PM. |
#1108 |
We have no added the ACE 4-2-1 Header option to our tuning page along with a few more options to choose from.
Stage 2 Reflash - Ace 4-2-1 Header Cheers, William Knose Delicious Tuning |
#1109 |
Drives: 2013 FRS
#1110 | |
#1111 |
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Hello William,
Thanks for all your work getting us to the current state of the art in tuning. Trying to understand where things currently stand. The Link provided above to results on DT web page for stage two tune with ACE header said: "The Stage 2 reflash using E85 for your Toyota FT86, Scion FRS or Subaru BRZ adds increased torque across the board and nearly eliminates the awful 4000 RPM dip felt by many and seen in many a dyno chart. In order to use the Stage 2 tune we highly recommend installing a full header back exhaust system in order to take full advantage of the improved performance. As far as which headers we suggest using either the ACE Muffler 4-2-1 Header for this package." Q1: Either = Type A or B, or one of the three variants of each? Q2: Using the OEM header back leaves how much on the performance table compared to "full header back system"? And details of FHBS tested i.e. Diameter, number of cats, etc. please to better evaluate cost per performance gained. Thanks
- When men make plans the gods laugh.
#1112 |
Drives: 2014 GT86
Brzzee:
Q1 - A, if you don't mind spend extra and there still are some in stock, but B is cheaper and not much worse. > 350 < - most torque, a bit less hp, should be one to get. 150 - most hp at top, less torque (somewhat similar to other top ELs on market. Should be fine on track where one keeps near redline in powerband, not so fine for daily driving). 250 - somewhat middle torque/hp wise. 350 may have fitting/rubbing issues on automatic transmissions/RHD though. Check up Ace's related threads for nfo. Q2 - actually Ace gets most gains from which you can get with full bolt ons while NA, and adding rest will be not too cost effective imho due diminishing returns when nearing +40whp .. imho you'll be fine with OEM catback too. Maybe just add aftermarket air filter. Also if considering other bolt on upgrades, remember that catless header increases loudness a lot, so choose quieter catbacks like eg. Q300 if you decide to change out stock. |
| The Following 2 Users Say Thank You to churchx For This Useful Post: | Brzzee (12-12-2015) |
#1113 | |
Recently, we've also added the Ace front pipe. We should be getting some additional fine tuning done around the front pipe soon. Our standard Stage 2 NA tune already worked pretty well with this setup; this Ace specific tune adds a bit more power, and offers considerable fueling and cam timing changes to suit its specific powerband. What this means for the end user is ultimately a smoother driving experience with a bit more power on tap than our typical map. Sincerely, Delicious Tuning Last edited by DeliciousTuning; 04-11-2019 at 06:15 PM. |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | Brzzee (12-12-2015) |
#1114 |
Drives: 2014 TRD GT86 CUP, 2014 991 GT3
I can't seem to find 97 RON fuel rating in the website.
Can I go for 98 RON option or that would be dangers? |
#1115 | |
#1116 | |
Drives: 2012 JDM Toyota 86
Sent from my SM-T700 using Tapatalk |
#1117 | |
You will be able to datalog certain parameters on the factory map with the cable kit, and more with our tune, but you will not be able to edit or view any of the maps themselves as they are locked. You can install our maps from the comfort of your garage, without ever needing to see a separate tuner or dyno! Sincerely, Delicious Tuning Last edited by DeliciousTuning; 04-11-2019 at 06:16 PM. |
#1118 |
Happy New Year!
We are working on some new developments this year and to give you an idea here are some pictures. Keep an eye out... ![]() ![]() Cheers, William Knose Delicious Tuning |
#1119 |
Update: All tunes have recently been updated for improved throttle mapping and starting from a dead stop. Current versions are listed below:
Stage 1 NA: V6.00 Stage 2 NA: V6.50 Stage 2 Ace Specific: V6.50 Innovate/Sprintex Specific: V9.50 Edelbrock: V19.00 Flash & Go: V19.00 The latest Ace specific tune also gains over 10ft/lb of torque in the lower end as compared with the previous version (V6.46), and has a broader torque curve overall. These updates will be the same $65 as our previous releases. For more information, email me directly at sales@delicioustuning.com.com To view each of these tunes on our website, check the individual links: Stage 1 NA: http://www.delicioustuning.com/Stage_1_PumpGas Stage 2 NA: http://www.delicioustuning.com/Stage_2_PumpGas Stage 2 Ace Specific: http://www.delicioustuning.com/node/484 Innovate/Sprintex Stage 1: http://www.delicioustuning.com/Innovate/Stage1_Tuner Innovate/Sprintex Stage 2: http://www.delicioustuning.com/Innovate/Stage2_Tuner Edelbrock: http://www.delicioustuning.com/node/483 Flash & Go: http://www.delicioustuning.com/flash_and_go Sincerely, Delicious Tuning Last edited by DeliciousTuning; 04-11-2019 at 06:16 PM. |
#1120 |
Drives: 2015 CWP Limited BRZ
Are the logs you request and we wemail back to you in excel sheet?
addictedcollectibles.r/My IG
'86 E30 (Project) 'VARIS Widebody http://www.ft86club.com/forums/showthread.php?t=103676 |
| Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 24 | 09-20-2013 04:04 PM |
| Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 1 | 09-19-2013 06:58 PM |
| Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 06:55 PM |
| Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 1 | 09-13-2013 02:34 AM |
| Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK | DeliciousTuning | Announcements, Contests, Giveaways | 5 | 08-26-2013 03:33 PM |
