Old 06-13-2015, 07:04 PM   #1051
spdfreak
spdfreak's Avatar
Drives: GBS BRZ Limited
Thanks for the quick response, Zack!
I'm probably doing something wrong.
Email sent.
spdfreak is offline   Reply With Quote
The Following User Says Thank You to spdfreak For This Useful Post:
Old 06-13-2015, 10:38 PM   #1052
Jcl
Drives: 2014 BRZ
Sorry didnt want to create a new thread for a simple question. I have kraftwerks c30 with the tune they sent. I am selling the kit with ecutek can the new owner flash the tune I got from kw? After they purchase their licence and such.
Jcl is offline   Reply With Quote
Old 06-14-2015, 04:20 AM   #1053
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yes, so long as you give them your dongle you use to flash the tune.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-22-2015, 03:10 PM   #1054
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Who would like CLFC (Closed Loop Fuel Correction) under WOT for naturally aspirated stage tunes? We have been testing it out on our Innovate tunes and it is already implemented in our Flash & Go tunes. So far it has offered great improvements in consistent and repeatable power.
So the only thing left is to add it to the NA tunes we offer. This is great option to hit exact AFR targets all the time. For those looking to our perform at the track, this offers precise and exact AFR for all conditions, including altitude, heat and heavy loads in higher gears.
We are going to be further refining these tunes on our sponsored vehicles running Pirelli World Challenge and SCCA sanctioned events. So let us know your thoughts on a unique option only offered by Delicious Tuning - Closed Loop Fuel Correction (CLFC).
Cheers,
William Knose
The Following 7 Users Say Thank You to DeliciousTuning For This Useful Post:
civicdrivr (06-22-2015), JOSEC (06-23-2015), malave7567 (06-22-2015), Ryan86 (07-01-2015), Shneegle (06-22-2015), Tatsu333 (02-15-2022), vtmike (06-22-2015)
Old 06-22-2015, 03:20 PM   #1055
malave7567
malave7567's Avatar
Drives: (formerly) 2013 Raven FR-S
Originally Posted by DeliciousTuning View Post
Who would like CLFC (Closed Loop Fuel Correction) under WOT for naturally aspirated stage tunes? [...]
I'm all for it (been running N/A tune from you for about a year). I'm also glad you guys take what you learn at one tune and trickle down to the others.
malave7567 is offline   Reply With Quote
Old 06-22-2015, 03:46 PM   #1056
Shneegle
Shneegle's Avatar
Cheers,
William Knose
Yes I would like this. The current tune I have is working great for the Dallas SCCA Solo events and other AutoX events I go to.
Shneegle is offline   Reply With Quote
Old 06-22-2015, 03:53 PM   #1057
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Cheers,
William Knose
Yes please!
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 06-22-2015, 05:01 PM   #1058
phrosty
Neat. There must be a reason CL and OL are separated on stock tune -- I assumed the idea was that inputs fluctuated too fast and so readings would always be incorrect and "behind". How did you work around it?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 06-22-2015, 10:34 PM   #1059
vtmike
vtmike's Avatar
Drives: Scion FR-S
Cheers,
William Knose
I'm in if there are advantages for CLFC. Are there there any disadvantages to this?
Sent from my Nexus 6 using Tapatalk
vtmike is offline   Reply With Quote
Old 06-23-2015, 12:23 AM   #1060
JOSEC
Drives: 2014 Subaru BRZ WRB
Cheers,
William Knose
I'm all up for it Bill.
JOSEC is offline   Reply With Quote
Old 06-24-2015, 03:26 PM   #1061
OkieSnuffBox
Drives: '23 BRZ Limited
Cheers,
William Knose
Get it done and I'll be buying your Flex Fuel kit and tune ASAP.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Old 06-27-2015, 12:47 PM   #1062
DeliciousTuning
The stock tune does run OL under WOT, and CL in cruising conditions. Where as manny manufacturers such as the GTR, Porsche run CL active 100% of the time.
Why Subaru does not CL 100% I am not sure, might just be preference. But we have rescaled the sensor in our tunes and it is pretty accurate from lean to rich.
Currently we have tested this heavily on our forced induction applications with great success. The response time even on air fuel ratios for those applications works great. By pulling the afr to the target value in hundreds of a second we can have perfect targets every time. If it is fast enough on a FI application it will be fast enough for NA.
Drawbacks, there are none that we have encountered except making sure you have a good working sensor. This technique will help those on the track to be more precise repeatedly, which will lead to better results.
Cheers,
William Knose
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
civicdrivr (06-27-2015), phrosty (06-27-2015)
Old 06-27-2015, 04:30 PM   #1063
ramosryan
Drives: Frs 10 series
how do i know i received right tune?
I received my tune from delicious today and installed but seem to have only one map and not sure if tune is for 93 also how do I know race Rom features were downloaded because they were supposed to be in map 2?
ramosryan is offline   Reply With Quote
Old 06-29-2015, 01:05 PM   #1064
DeliciousTuning
Hey Ryan,
What likely happened is the features simply didn't stick when you flashed, which is fairly common. Can you please send me an email directly so I can walk you through reapplying them? My address is sales@delicioustuning.com.com . For future reference we check our emails much more frequently than the forums
Sincerely,
Search this Thread:
Advanced Search
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 04:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 06:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 02:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 03:33 PM
