Old 11-28-2013, 01:25 PM   #43
jeebus
Drives: 2015 Mustang GT (on order)
Originally Posted by WRB5titch View Post
Looks like mine was running lean at WOT as well, LTFT went as high as 5.14. Added a gallon of 91 as @jeebus suggested and all is well.
AM also dropped to .98 for a bit but went back up before I added the gallon of 91...
makes you want an ethanol tester right? At least adding a pinch of pump gas is easier than re-engineering the whole fuel map.
jeebus is offline   Reply With Quote
Old 11-28-2013, 04:19 PM   #44
WRB5titch
Drives: WRBrz
agree with you 1000% there!
WRB5titch is offline   Reply With Quote
Old 11-29-2013, 12:03 AM   #45
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
I haven't had any non start first starts yet. But I do notice it takes the starter an extra second or two before the motor turns over. This has only been with a cold engine. Warmed engine will turn over like it was on pump gas.
Update: couple of non starts now. Weather is colder, in the 50s. Perhaps it's my second tank of fuel is less ethanol.
garfull is offline   Reply With Quote
Old 11-29-2013, 12:48 AM   #46
Lytheum
Drives: 2013 BRZ Premium 6MT
Anyone getting a popping sound on cold starts? If I touch the throttle it stops and rpms hold around 2k ish for a few seconds then start to drop. Its been in the 20s and 30s here lately.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 11-29-2013, 02:24 PM   #47
jeebus
Originally Posted by elopez View Post
upper teens @~5000 ft elevation. 25+ attempts to start this morning.
any tuning tweaks available/recommended for improving cold starting?
Run less ethanol. One would assume that in an area as cold as yours they would have e70 or so in the tanks right now, but maybe not....How do your fuel trims look at load?
Adding a gallon of 91 would help cold starts but it also causes you to run richer. If your trims are close to zero then you can throw a gallon in and you'd likely be about 4% rich (which is still ok) If your trims are at all lean then the gallon would be a no brainer.
Old 11-29-2013, 03:52 PM   #48
krulux
Drives: 2013 Scion FRS
I'm going back to 93oct this afternoon... mainly because there is only one station that sells E85 in my area and it its about 20min from my workplace - but about 40min from my house. As such, I ran two full tanks out this week (on E85 fumes right now) during a weeks worth of driving. Granted, I've been hammering the throttle more so than usual and I can say without a doubt the car is fast on the corn juice and Vishnu's E85 tune.
That said, I'm looking forward to the OFHeader... I hope with the edition of the header I can run the Stg2 tune and 93oct and get close to what the car pulls on the E85/E85tune. (And I can always swing by and fillup for those times when I need burn some corn!!!)
krulux is offline   Reply With Quote
Old 11-29-2013, 05:01 PM   #49
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
You'll need to bump up the cranking fuel pulse widths values.
Td-d is offline   Reply With Quote
The Following User Says Thank You to Td-d For This Useful Post:
elopez (12-01-2013)
Old 11-30-2013, 12:49 PM   #50
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Just filled with e85 for the first time!!!
Drove 3.5 miles, and I'm on the side of the freeway now flashing!
The Following User Says Thank You to continuecrushing For This Useful Post:
Shiv@Openflash (12-01-2013)
Old 11-30-2013, 11:54 PM   #51
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Is there no way to prime the fuel system with E85 before switching maps? Beside running on the standard tune with E85 added to the tank. What if you run the the standard tune with E85 fuel too long? What kind of adverse effects does that have? What about when you want to switch back from E85 to regular premium gasoline?
Intent > Content
Old 12-01-2013, 01:03 AM   #52
krulux
Ok.. back on the 93oct - missing the punch of the E85 already.
A few other things I noticed also... the chirp is back (HPFP). The exhaust seems to drone more loudly at highway speed (70mph/3Kish). I also noticed the rasp at around 4K seems louder as well (back on the stg1 tune)
Old 12-02-2013, 08:35 PM   #53
garfull
garfull's Avatar
Update after first tank averaged 22.7 mpg.
Old 12-02-2013, 08:44 PM   #54
RC51ed
RC51ed's Avatar
That sounds about right. My first tank was around 21.6 then it ranged anywhere from 17-22 mpg. Depending on how heavy my foot was.
RC51ed is offline   Reply With Quote
Old 12-02-2013, 09:15 PM   #55
jamesm
you'll just see your fuel trims creep positive until it's all blended through, up to 25-30%. you can put in the e85, start the car, watch the logs for the trims to start to rise as it idles then turn it off and flash the new map once they've risen.
The Following 3 Users Say Thank You to jamesm For This Useful Post:
s2d4 (12-02-2013), Trettiosjuan (07-15-2014), WRB5titch (12-02-2013)
Old 12-02-2013, 11:14 PM   #56
solidONE
solidONE's Avatar
I filled up a tank of E85 then flashed the e85 stage 2 tune. Everything seems to be working fine. Advanced multiplier pinned at 1.0 LT fuel trim at about 7% currently, ST fuel trim floating around +- 3%.
I've noticed a loud tapping noise when the throttle is slightly depressed. The tapping sound is definitely coming from the fuel system. Louder on the driver side(HPFP side). Anyone else notice that?
Intent > Content
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 05:48 AM
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 10:52 PM
Ecutek stage 2 tune on stock brz 01s0uljah Software Tuning 15 10-15-2013 03:52 PM
Anyone choose zeta stage 1 over stage 2? BlackyRose Engine, Exhaust, Transmission 2 07-06-2013 02:32 PM
>> EcuTek << STAGE 1 / STAGE 2 / E85 - Tunes Available FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 133 05-21-2013 02:39 AM
