Old 11-25-2013, 11:03 AM   #15
bluesubie
I think BRZY is onto something.
There is no such thing as "7.5w-27" in SAE J300. The first number represents cold cranking viscosity and is only tested for 0W, 5W, 10W, 15W, 20W, and 25W. Period.
http://www.pqiamerica.com/coldcrank.htm
There is also no such thing as "27". There is 20, 30, 40, etc. and 16 is right around the corner.
http://www.tribology-abc.com/abc/viscosity.htm#SAE
Before dumping this unknown oil into a car, I would at least do a virgin oil analysis including TBN and viscosity at 40C. There are so many mistakes on their web site it's not even funny (actually it is very funny). Here's one for starters:
What they have embarked on is the reduction of SAPZ. This is Sulfated Ash, Phosphorous and Zinc.
This is wrong. It is called SAPS - Sulphated Ash Phosphorous and Sulfur (although sulfur is part of ZDDP).
http://www.lubrizol.com/EngineOilAdd.../LowerSAPS.pdf
Of course, they fail to mention that there are non-metallic organic additives being used due to the reduction of ZDDP. There is also an increase in multi-functional additives such as old and new forms of molybdenum and boron. Note that the BRZ/FR-S does not have flat tappet cams.
More reading:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=245760
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=641544
I anxiously await the uoa's.
-Dennis
bluesubie is offline
Old 12-02-2013, 01:03 AM   #16
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
I'm glad this forum is reopened thank you moderators. I received my blackstone oil test kit but it was crushed in the mail I'm waiting for another one to come in sorry for taking so long.
cjsporl1996 is offline
Old 12-03-2013, 01:01 PM   #17
bluesubie
Are you doing a virgin oil analysis or only a uoa? Please get TBN as well.
Also, can you drive up to Central NJ so that I can witness the sampling procedure to make sure you don't cheat and add some Mobil1 to your sample? I also need to put a lock on the oil fill cap.
Thanks,
Dennis
Old 12-03-2013, 03:14 PM   #18
cjsporl1996
I am doing a virgin oil analysis , UOA, and TBN because you asked. I'll even post a video of me sucking the oil out and sticking it into the bottle.
Old 12-11-2013, 09:32 AM   #19
Mikem53
Drives: FR-S 6MT
Originally Posted by cjsporl1996 View Post
Before all you critics out there have nothing but negative things to say about a product why not wait for the results. Only because someone can make a homemade candy bar at home you automatically assume it's worse than a Nestle bar you buy in the store. Wait for the results. Brain handles things on the consumer side. The business was originally government contracted and does a lot more business on the commercial side.
Seriously, what do you think you will gain by using this so-called magic oil concoction Over any other oil that meets the standard of Subaru and Toyota for this car? It's your time and money.. Have fun..
Mikem53 is offline
Old 12-11-2013, 11:26 AM   #20
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
This just voided the warrenty.
Rayme is offline
The Following User Says Thank You to Rayme For This Useful Post:
NickFRS (01-31-2014)
Old 12-11-2013, 12:42 PM   #21
cjsporl1996
i received the Blackstone kit in the mail today i will be shipping it out tomorrow for analysis. Thank you for your patience.
Old 12-11-2013, 03:47 PM   #22
bluesubie
Found a recent uoa on a Quantum Blue blend at bitog:
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3210926/Quantum_Blue_/_5W-30/8,459_mi/#Post3210926
I'm really amazed at the levels of phosphorus in this oil. It's more than any racing oil that I've seen. This is much higher than MPT Thirty-K, Amsoil Dominator, Motul 300V, Red Line Street oil, Red Line Race oil, Mobil1 Racing Oil, etc.
Hopefully yours won't be that high, unless you don't have cats. Otherwise, you may have a dead kitty if you burn any oil.
-Dennis
Old 12-12-2013, 12:24 PM   #23
cjsporl1996
-Dennis
I have only one cat at the moment. I'm impressed with that report too.
Old 12-12-2013, 02:07 PM   #24
mike the snake
I'm running catless. Would the extra phosphorous in this oil be a good thing?
I know when I had air cooled Porsches the best oils had the most ZDDP because it helped with the higher pressures.
My car is getting a turbo kit and catless exhaust installed presently, planning on running Motul oils.
mike the snake is offline
Old 12-17-2013, 11:53 AM   #25
bluesubie
Apparently, this company blends oil to a customer's specific needs so perhaps not all formulations would have this much phosphorus. Even so, I can't imagine that much phosphorus being a good thing. It's pretty much twice the amount of any pure race oil that's not intended for the street (Red Line Race, Mobil1 Racing, etc.). Too much of one ingredient doesn't make an oil better.
Mobil1 actually recommends their 0W-40 or 15W-50 for street cars that see track use and for applications that call for those viscosities. The 0W-40 has 1,000 ppm's of phosphorus and the 15W-50 has 1,200 ppm's. Motul 300V 0W-20 uses around 900-1000 and I believe that Red Line Street oil uses a bit more phosphorus at 1300-1400. Brad Penn uses around 1,300 as well. Motul and Red Line use a lot of molybdenum as well, which is a great friction modifier.
Although there hasn't been much of a uoa trend (these cars are still relatively new), there are some good random uoa's on this forum showing that the phosphorus levels in Red Line and Motul 300V 0W-20 appear to be fine for forced induction, tracked applications. Like I said above, maybe the phosphorus levels in the OP's blend will come in a bit lower than the bitog uoa.
-Dennis
Old 12-17-2013, 01:13 PM   #26
cjsporl1996
Good news I'm sending the oil out today through ups. Bad news is my dad accidentally dropped the drain nut so I drained all my oil out and replaced it with Mobil 1 for now. I will post the results when they come in.
Old 12-17-2013, 01:16 PM   #27
mike the snake
I know when I was racing Porsches, that Brad Penn and Swepco were very recomended because of the extra ZDDP and their formulas. This was for air cooled engines though, and these are Dino oils.
Our twins run on synthetic, and I'm changing the oils to Motul presently, but if there's a better oil brand to run I'd run that of course.
Has anyone ever heard of, or run Klotz oils?
Old 12-19-2013, 12:39 PM   #28
bluesubie
Even if you keep your car for 300,000 miles, I doubt you'll ever find the answer to which oil is better.
I would stick with Motul though. Even though they make non-API certified race/street oils, they also make oils that meet the most demanding specs, builder approvals, and certifications in the world (same goes for Mobil1 and many other brands. No offense to Quantum Blue ).
I can't really tell by the pic, but it looks like the Klotz has sort of a rip-off logo of the API starburst on the front of their bottle.
-Dennis
blackstone, bnd, oil
AT owners only, custom CF paddle shifters, pin stripe custom color BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 80 02-03-2016 11:35 AM
FS: Custom Acrylic Accents, $13. YOUR custom design! Cupholder and Mission Tray too! Diode Dynamics Interior Parts (Incl. Lighting) 155 11-19-2014 12:42 PM
Perrin Pulley review? Invidia Q300 exhaust review? ScionFrsFan Engine, Exhaust, Transmission 4 12-10-2012 09:27 PM
AutoExpress BRZ Review - Follow up to the GT86 Review Zgrinch BRZ First-Gen (2012+) -- General Topics 3 12-13-2011 09:03 AM
