#29 | |
Drives: '20 Hakone 86
Their customer service is absolutely fantastic as well. 95% of the people who actually drift their cars on this forum use Stance coils and most also use their LCAs as well. Stance also makes different types of coilover systems. There are normal sport plus' which are like the entry level. Then they have those with swift springs as an upgrade, and then they have 2-way and 3-way systems with external resevoirs. After a personal experience with BCs and their products/company, which I won't publicly discuss on this forum, I chose not to ever do business with them. Lots of people have BCs and have no issues. Lots of people here have BCs and do have issues. A personal friend of mine just installed some on his car and had to run over 25mm of spring preload just to keep from the popping noise to keep happening. Seems like a hit or miss kind of thing. I just prefer Stance. Always have. Always will.
| The Following User Says Thank You to TylerLieberman For This Useful Post: | WolfsFang (11-22-2013) |
#30 |
Scrape Master
Drives: Goal: Oldest FRS State Side
Im running stance coils lowered around 4-5" and im loving them. Alot of my friends have had bc br fail on them. Ride is not so bad, though i prefer a stiff ride over a soft so dont take my word. I have done a few autox days and after playing around with the damper setting the coils felt really nice around the turns.
Also guys he said his budget is 1500, idk why you keep on saying get the FA500 when they are already past his budget. Also to the OP, I would never spend more then 1800 on coils unless you are going to track your car often (more then just 2 times a year.) For this I would choose Stance > BC BR. Stance SS are also a inverted mono-tube which make them little stronger.
#31 |
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
#32 | |
The Original Super Saiyan
Drives: 2014 SWP BRZ
#33 | |
Because compromise ®
Drives: Red Herring
Oh no!!!! I'm quoting myself!! :/
#34 | |
Scrape Master
Stance SS |
#35 |
Drives: Frs
Swift Springs add on.
I personally would look into BC Racing but opt for the Swift Springs upgrade. The swift springs coils on the BC damper are hard to beat and if i am not mistaken should still be within your budget.
#36 |
Drives: FR-S Whiteout
From what I've seen and read people have gone fast with BC and others have done the same Fortune Auto. "Fast" as in winning various local amateur competitions with them. Whether they used off-the-shelf stuff or custom built, I'm not sure. From a spec sheet perspective, the Fortune Auto stands out with the digressive valve and the quality of components used to build them (according to their marketing material at least). From end user feedback I've seen, there seems to be some common complaints about the BC top mounts making weird noises. I've not read anything negative about the fortune auto set.
Stance.... I've worked on a FR-S with them. Not a lot of suspension stroke with these. I think they get the same complaints about top mount noises as the BC. If I were in your shoes, I'd shell out that extra bit of money for the fortune auto dampers.
Intent > Content
cowardice is the mother of cruelty. |
#37 |
Drives: 2013 scion FRS
so kw v1 or FA? i was also in the same boat as OP, but considering ARK because of it's spring rates.
| Stance super sport coil overs 1200 miles | Jhon19lopez | Brakes, Suspension, Chassis | 4 | 11-09-2013 02:38 PM |
| AutoX coil-overs what should i get? | subaruferrucci | Tracking / Autocross / HPDE / Drifting | 4 | 02-19-2013 04:03 PM |
| Coil-overs \ Spring kit ????? | v3rgil | AFRICA | 9 | 11-16-2012 09:27 AM |
| XYZ Coil overs??? | Juanito08 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-31-2012 10:12 PM |
