Old 11-21-2013, 11:24 PM   #85
jeebus
Drives: 2015 Mustang GT (on order)
My advanced multiplier was at .96 for my entire drive home. Never went up or down. Is it actually at .96 or is the current software reporting 1 incorrectly?
jeebus is offline   Reply With Quote
Old 11-21-2013, 11:45 PM   #86
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
It's actually at 0.96. Sounds good to me.
Old 11-22-2013, 12:06 AM   #87
jeebus
Cool, just checking. It would seem then that this e85 tune is pretty happy on my stock header 86
Old 11-22-2013, 03:49 AM   #88
Kodename47
Kodename47's Avatar
Drives: UK GT86
Just do a couple of high load scenarios (WOT pulls) and so long as all is well it will pull up to 1
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-22-2013, 12:30 PM   #89
jeebus
It did this morning...right before I got to work, BOOM 1. I'm sure it dropped a bit when I first put e85 in because the tank was somewhat mixed, etc.
Old 11-22-2013, 12:54 PM   #90
jeebus
Question: Even at WOT (pedal clicking on the floor), I'm only seeing throttle % of 83.x. Is this normal for our cars? If so, do the throttle maps accommodate for this?
Old 11-22-2013, 01:55 PM   #91
Kodename47
Kodename47's Avatar
Drives: UK GT86
That is actual throttle plate opening and is normal.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
jeebus (11-22-2013), Shiv@Openflash (11-22-2013)
Old 11-22-2013, 07:14 PM   #92
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Is there a reason why the MAF voltage is stuck at 5v and adv multiplier at .86? This is with stage 1.34 pump gas on A01C stock tune.
Loving the new data log feature. Keep up the good work Vishnu!
Old 11-22-2013, 07:18 PM   #93
Shiv@Openflash
Drives: 2013 FRS
As per the update notes, MAF voltage logging is not functional yet
Advance multiplier is working just fine. Expect it to move around a bit. Especially on gasoline (less so on e85).
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
solidONE (11-22-2013)
Old 11-23-2013, 11:35 AM   #94
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Hi Shiv!
Strange case with my OFT device - it is updated, new gauges appeared (but my lovely intake air temp scale disappeared), but Adv. Multiplier doesnot show anything. The gauge of Adv. Multiplier is present, but it's dead.
And it writes the log file, but there is no A.M. data available.
What went wrong there? How to fix? Should i fix OFT or car itself?
Will next OFT FW upgrade cure it?
Ondreiko is offline   Reply With Quote
Old 11-23-2013, 11:43 AM   #95
Malt
Drives: 2015 WRX
I'm also having issues. I logged on the way to work yesterday morning and when I got home this morning I attempted to open the log within openflash manager. I when I click on Read OpenFlash Manager just locks up.
Suggestions?
Malt is offline   Reply With Quote
Old 11-23-2013, 12:03 PM   #96
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
The scaling needs to be changed - the direct variable for throttle opening angle % is scaled at x/0.84. For reference, the RR logger definition:
Code:
                <ecuparam id="E38" name="Throttle Plate Opening Angle (4-byte)*" desc="E38-Actual throttle plate opening percentage. More accurate than the standard Throttle Opening Angle % SSM parameter." target="1">
                    <conversions>
                        <conversion units="%" storagetype="float" expr="x/.84" format="0.00" />
                    </conversions>
Td-d is offline   Reply With Quote
The Following 2 Users Say Thank You to Td-d For This Useful Post:
jeebus (11-23-2013), Shiv@Openflash (11-23-2013)
Old 11-23-2013, 12:51 PM   #97
jeebus
Suggestions?
Was your tablet updated to the very latest version before you logged? Mine did the freeze up until the most recent update. Also, I assume you are on OpenFlash 1.3?
Old 11-23-2013, 12:53 PM   #98
jeebus
Code:
                    <conversions>
                    </conversions>
But is the stock scaling the same as this? If so, I don't see much issue with just leaving it.
Search this Thread:
Advanced Search
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 11:03 PM
***VISHNU OpenFlash Tablet IN STOCK*** Garrett@Openflash Engine, Exhaust, Bolt-Ons 15 12-17-2013 02:30 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 01:10 AM
