Old 11-11-2013, 10:10 AM   #1
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
SOLD
SOLD
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline
Old 11-15-2013, 08:29 AM   #2
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
TTT
ecko04 is offline
Old 11-15-2013, 10:31 AM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Pretty good deal, it is a true plug and play solution.
Sportsguy83 is offline
Old 11-18-2013, 09:33 AM   #4
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
TTT
ecko04 is offline
Old 11-23-2013, 08:19 AM   #5
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
TTT
ecko04 is offline
Old 11-25-2013, 01:41 PM   #6
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
TTT
ecko04 is offline
Old 11-29-2013, 07:53 PM   #7
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
TTT
ecko04 is offline
Old 11-30-2013, 02:36 PM   #8
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
was everything installed correctly ? and did you use the filter and place the correct amount of washers ?
i might pick this up
SmsAlSuwaidi is offline
Old 11-30-2013, 02:40 PM   #9
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
FS: Deatschwerks DW65c High Flow 265lph Compact Fuel Pump Installed in Canister
I followed the exact installation instructions provided by Toni in his video.
Umm...why would someone not use the filter? It's included for a reason. Also there aren't any washers, there are o-rings and fuel pump sock. Installation requires that you use the same number of o-rings as the stock fuel pump assembly, two.
ecko04 is offline
Old 11-30-2013, 02:43 PM   #10
SmsAlSuwaidi
Boosted
Umm...why would someone not use the filter? Also there aren't any washers, there are o-rings and fuel pump sock. Installation requires that you use the same number of o-rings as the stock fuel pump assembly, two.
a few cases where Visconti used to throw away the filters stating they are not needed
sorry i meant O rings
Old 11-30-2013, 02:45 PM   #11
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
I listen to absolutely nothing Visconti has to say. In fact, I don't see his posts, I blocked him, as I don't want to see his misinformation cloud my feed.
ecko04 is offline
The Following User Says Thank You to ecko04 For This Useful Post:
bakerr6 (11-30-2013)
Old 11-30-2013, 08:42 PM   #12
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
SOLD!!
ecko04 is offline
FBM Billet High Flow Fuel Rails FullBlown Forced Induction 17 05-17-2014 03:53 PM
FS: BNIB Deatschwerks DW65c Fuel Pump mfbmike Engine, Exhaust, Bolt-Ons 12 10-25-2013 01:45 PM
Fuel Pump high pitch chirp noise lucius AFRICA 9 10-24-2013 03:40 PM
AEM High Flow In-Tank Fuel Pump JPxM0Dz Engine, Exhaust, Transmission 0 04-13-2013 01:15 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
