#43 |
Drives: None
#44 | |
http://www.ft86club.com/forums/showthread.php?t=21563 You need to remove the rear hub to install the long studs, I think you might be able to do the short studs with the hub in place, kinda sucks but not impossible to do. |
#45 |
Now w/ over 400 womprats!
Drives: BRZ LZR
Damn, talk about a blast from the past!
Let me tell ya! I started using anti seize and I never broke a lug stud again! And then I got Muteki SR48s after I got my wheels, and those haven't given me an issue either (I install them without Anti-Seize). As far as replacing them goes, I've done it on both front and rear in my driveway without removing the hub. As long as it's the stock stud, you shouldn't have an issue. I have been planning on installing ARP Extendeds, but I've had good luck with the stocks+Mutekis, so I haven't bothered.
- The Ancient BRZ Sacrament by Zaku |
| The Following User Says Thank You to Guff For This Useful Post: | strat61caster (12-24-2015) |
#46 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I never have this problem with mines.
#47 |
BRZZZZZ
Drives: 2013 BRZ Whiteout
Never had any problem with studs on my brz. I use anti seize on my lug nuts too, but not every time I remove my wheels and I only use a very small dab of it. I use anti seize coz during winter snow time, lugs gets rusty from all the salt they use here in Canada and its makes tire change just a little easy.
#48 |
Drives: Whiteout FRS
Stripped my driver's side front wheel stud the other day as well. PITA to deal with. I may change over to ARP studs in the near future when time permits.
| The Following User Says Thank You to shellslinger For This Useful Post: | Astroboy (12-24-2015) |
#49 |
Drives: 2013 Asphalt FRS
1 Are you running a aftermarket wheel and are they hub centric? Actually measure the hub and wheel, I have seen wheels millimeters off.
2 Are your lug nuts open ended? 3 Do you torque in a star pattern? 4 Are any lug nuts loose or rusted when removed
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#50 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Try anti seize. coppery stuff not silver one. My father used to grease just the end of it. I dont grease it, I use the anti seize (have been for like 8yrs now). Never had any issues.
#51 |
Drives: 2015 WRB BRZ Premium
I'd like to add that anti-seize is not a lubricant; its an abrasive.
So all of that BS above about lubricated vs. nonlubricated torque in this particular situation means precisely squat. That said, either use antiseize and avoid breaking studs, or don't and get used to replacing them. I've definitely broken a dry stud removing the lug nut plenty of times, and ive broken a stud with antisieze by removing the lug nut...once...ever.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
#52 | |
Drives: 93 MR2 gen3 3sgte, 13 FR-S
I was swapping out wheels once or twice a month because of the autox season.
Instagram @gen3mr2
#53 |
Drives: 13 Subaru BRZ, 02 Audi TTQ
I've always used a little anti-seize on all of my cars because of the winters, all of my studs are fine.
#54 | |
Sorry I meant silver not copper. Silver is better because it doesn't harden and it does better in hot temps and resistant to water. Not that it gets wet there but its good to know it wont just disappear and rub off.
| The Following User Says Thank You to Packofcrows For This Useful Post: | new2subaru (12-28-2015) |
#55 |
From the Owners Manual... I use a battery terminal brush on the stud end and battery terminal end for inside the nut. Clean off with brake cleaner and install dry.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete Last edited by stevesnj; 12-29-2015 at 12:34 PM. |
#56 |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (12-29-2015) |
| Extened Studs? | BlaineWasHere | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 05-29-2013 12:29 PM |
| Down hill breaking... ABS? | shaofis | Issues | Warranty | Recalls / TSB | 11 | 10-22-2012 05:28 PM |
| Breaking Bad: Season 5 | |-Goku-| | Off-Topic Lounge [WARNING: NO POLITICS] | 15 | 07-22-2012 02:02 AM |
| Breaking Bad Season 4 | tranzformer | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 10-10-2011 09:17 PM |
