#57 | |
#58 |
Drives: 2004 Toyota RAV-4 5M
While not on the same level of destruction as the others, I managed to crack my first rotor this weekend. It only took about 16 track days, countless autocross events, and over a year of daily driving. Kind of funny that it happened my first ever session with Hoosiers.
#59 | |
#60 | |
Drives: 2014 BRZ
#61 |
Drives: 2014 BRZ
Has anyone used some brake ducts or GT3 brake cooling scoops to see if the help with the inside wear?
#62 | |
| The Following User Says Thank You to CSG David For This Useful Post: | AreteAuto (09-30-2015) |
#63 |
Drives: 2014 BRZ
Mike, I was referring to the uneven inside vs outside wear on your rotors on the first post. I've not seen such a variance before and you mentioned cooling might make the wear more even.
Also, is the pad wear uneven?
#64 |
Site Moderator
Drives: Stuff
Mine have very uneven wear from heat. Pad wear is slightly uneven but not that uneven (less than 1mm difference).
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#65 | |
![]() We have uneven rotor wear on the inside vs. outside. We wore the J-hooks until they disappeared on the inside. Pad wear on this car was relatively similar with slightly additional wear on the inside. On the boosted S2000, there is significant wear on the inner pad vs. the outer one. Rotor has a little more wear on the inside vs. outside. Even then, the brake system lasts longer than factory for our application and we noticed a significant amount of life in our brake pads compared to stock calipers/rotors. For us, the cost of BBK is justified. |
#66 |
Drives: 2014 BRZ
Sorry David ...
So, I'm just trying to understand if cooling would even out the wear. I'm sensing the question is moot if you replace the rotors slightly sooner than you guys pushed yours. The uneven wear came to my attention mainly because I would typically use the slot/j-hook wear on the outside as a visual clue for when to replace the rotors.
#67 | |
How cooling affects wear varies by setup. E.g. if you're overcooling the brakes, it may increase wear, whereas if you're bringing the brakes down from borderline overheating to ideal temperature range for the pads, then it may decrease wear. The *best* way to figure this out is to use temp strips on the caliper, and temp paint on the rotors. |
#68 | |
Racing Enthusiast
Drives: Bone stock 2019 BRZ manual
“$20 per diddle? I can diddle myself for free and do a fine job”
#69 | |
What is your setup? My personal preference is for the Project Mu 999. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | AreteAuto (10-01-2015) |
#70 |
Site Moderator
Drives: Stuff
I agree with his preference. Mine was tied between those and the CL RC6.
-Dave
| The Following User Says Thank You to Dave-ROR For This Useful Post: | AreteAuto (10-01-2015) |
| This is how much we like our AP Racing/Essex "Sprint" BBK... | CSG Mike | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 05-06-2013 12:30 PM |
| Question about Long-Term "Garaging" | arleewa | BRZ First-Gen (2012+) -- General Topics | 25 | 01-12-2013 10:13 PM |
| Some FR-S "news" (pricing update) | Sport-Tech | CANADA | 19 | 03-24-2012 11:31 PM |
| Hyundai Calls 2011 Sonata Turbo "Very Delicious," Reveals Near-Term Future Plans | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-19-2010 03:53 PM |
