| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
Drives: 2006 Cayman S, 2007 Outback 2.5i
It's a tough choice, but the sport suspension is a bit cheaper, as well as being lower. I think it'd be a bit better performing too. I'd be on the fence though - I haven't driven a PASM-equipped Cayman, so I'd definitely want to do that before making a final choice. I'd also be curious to drive a PDK equipped one, but I'm 95% sure I'd end up with a stick shift, even though it is slower.
#16 |
Drives: MR Spyder/GT86
That BRZ is awesome no matter what the numbers say
| The Following User Says Thank You to GT86meMR2 For This Useful Post: | supra2nv (11-17-2013) |
#17 | |
Drives: Subaru BRZ Sport Tech Satin White
Once Ferrari ditched the manual in favour of DCT that basically was the end of the manual. PASM is pretty amazing but, again, not consistent with ordering a manual. Basically, PASM allows Porsche to fit a track oriented suspension which you switch "off" using PASM, although it does have automatic characteristics. Sport mode is just too hard for North American roads. Logic dictates buying a base Cayman without PASM if you want a manual. I'm just saying. The differences between the base Cayman with a manual shift and the BRZ/FRS are minimal on real roads at legal speeds. Just saying. |
#18 | |||||
![]() Have you ever driven a Cayman? The difference is pretty obvious, even on real roads at road-legal speeds. The BRZ/FR-S feels extremely nimble, but it also feels like the limits of both grip and power are fairly low. They're extremely controllable, but not terribly high (which is part of the fun of the car). The Cayman on the other hand is all about grip - the fatter tires and the engine in the back mean that even coming out of a corner, you can pretty much stand on the gas anytime you want, and the rear end won't step out until you're going a lot faster than you would have expected. Even though I have the S, I can't even chirp the tires (as long as they're warm) by dumping the clutch at 4500rpm - the car just grips and goes. There are definitely merits to each car, but I wouldn't say they're all that similar in the way they drive (aside from both being focused on the handling feel, and both being nimble). And, of course, there's the extra 75 horsepower to go with the glorious sound of having a flat 6 sitting eighteen inches behind you. (My one caveat to that is that I haven't driven a BRZ on extremely sticky tires, so if that completely changes the feel of the car, it might better approximate a Cayman. I'd be surprised if it made it Cayman-like though, since part of the reason the Cayman grips so well is the rear-biased weight distribution) |
| The Following 2 Users Say Thank You to chrisl For This Useful Post: | Ganthrithor (11-09-2013), WolfpackS2k (11-18-2013) |
#19 |
I've driven several Caymans as well as 911 and a Boxster. That's how I know the BRZ is a much better car for most street drivers, subject to one rather serious design deficiency which unfortunately was deliberate.
Drive the PDK Cayman once and you'd be a bit loony to want a manual. Indeed, drive the latest torque converter automatics and a manual shift becomes the anachronistic choice. I bought a manual shift BRZ knowing full well that the automatic could have been a better choice had Toyota/Subaru not deliberately made it so slow. My remark about PASM and a manual transmission is it is illogical to claim you prefer the manual shift for better involvement with the car and then have electronically adjustable suspension. Electronically adjustable suspension interferes with the driver's control of the car, as does "active" steering fitted to some BMW. Weight distribution hasn't got a lot to do with grip but it does affect polar moment, roll moment and relative tire slip angles. Wider tires don't deliver higher levels of grip, a common misconception. Friction is expressed as a coefficient for a reason. Rubber grips the road, the structure of the tire affects how that grip is utilized. The structure of the tire doesn't magically generate more friction. The BRZ handles differently with better tires but it still suffers from drift mentality. Drifting is slow and akin to synchronized swimming as compared to racing. Unfortunately, the perceived demographic for buyers of this car apparently include drifters and the car suffers terribly as a result. A car prone to oversteer is a pita to drive for a serious driver. The terrible stock tires just make it worse, much worse. Grippier tires would make the car much more pleasant to drive as would altering the camber rise in the rear suspension to give more camber rise more quickly in roll. As it is this car suffers chronically from roll oversteer which the stock tires exacerbate. I deduce from the cars behaviour that it is roll oversteer from inadequate rear camber rise but given that it also occurs in the wet it may also result from rear toe effects. The two can be hard to differentiate from behind the wheel. One odd thing is the car is totally benign on really slippery roads as on snow or ice. In fact, the BRZ is a bit of a dream car to drive in winter conditions with traction control fully off. Same on gravel. Totally controllable, a child could drive this car on ice. It is definitely a roll issue but whether it is camber rise or toe or both I dunno. Handling is much more benign on my Sottozeros than those awful Prius tires. However, to really compete with the Cayman in corners more needs to be done than fitting better tires. The rear upper A arm needs to be shorter or perhaps some rear bushings stiffened up if toe changes are the cause of the drifting tendencies. Last edited by Suberman; 11-09-2013 at 07:57 PM. |
| The Following User Says Thank You to Suberman For This Useful Post: | Ganthrithor (11-10-2013) |
#20 |
Drives: WRX
#21 | |||||
(Active steering on the other hand can interfere with the control of the car, though that depends on how it is implemented) Quote:
As for wider tires not delivering higher levels of grip? You need to forget about the high-school physics level knowledge about friction. Rubber on pavement behaves differently than that. Interestingly, the contact patch doesn't change size between narrower and wider tires (assuming the same internal pressure), but it does change shape, with a wider tire providing a wider (but shorter) contact patch. This allows for a higher lateral force at a given slip angle, which means that a wider tire does indeed give slightly better grip. Similarly, lowering the pressure in tires will tend to give higher grip due to the increased surface area in contact with the ground. This goes against the simplistic theory you are using above, but due to the way rubber deforms under load, it has a higher coefficient of friction when under a lower vertical pressure (which can mean either less load, or a larger contact patch). Quote:
This does however seem to go against your prior statement that the base Cayman is nearly indistinguishable from a BRZ in how it drives on the street. A Cayman has a huge amount of grip at all times (although it is also really controllable when it starts to slide), which is a pretty obvious difference from the way a BRZ on stock tires (and even on sticky ones, based on your own statement here) drives. |
#22 | |
Drives: 2013 FR-S Argento
Ok forgive me, but I sense a lot of oversimplification and arm-chair racing knowledge being spouted here. And I have to say - we all love the Cayman, it's a great car. Many of your posts seem to be "Wow the FR-S/BRZ is a great car.. but my Cayman is better!". I can't speak for others, but it kinda gets annoying. I'm here to learn more about the car I own. I'm just curious, why are you here?
#23 | |
As for bringing my Cayman into all kinds of conversations? I try not to - I don't mean to say anything about it unless someone else brings up the subject, and most of the time, I try to keep my comments pretty much generic or BRZ/FR-S related. For example, the conversation in this thread started turning towards Porsches with the Cayman explicitly mentioned in the video, as well as by Tgionet above. That having been said, I will try to pay attention to when/how often I discuss the Cayman - I really don't want it to come across the way you say it sounds (and actually, on that note, I'll pull it from my sig too). Last edited by chrisl; 11-10-2013 at 02:19 PM. |
#24 | |
2022 BRZ Build 2013 FR-S Build |
#25 | |
#26 |
LSD cause understeer. Very overrated addition. The best LSD to get is the Torsen fitted to our BRZ. Otherwise fit a fully electronic LSD.
| The Following User Says Thank You to Suberman For This Useful Post: | WolfpackS2k (11-18-2013) |
#27 |
#28 |
Porsche didn't fit an LSD to the first gen Cayman for good reason. Insufficient engine torque to warrant fitting one.
The second gen Cayman was journalist engineered in some respects. The LSD still wasn't beneficial but Porsche felt pressure to offer one. The rear axle "grip" you seem convinced is a result of weight distribution also means an LSD is pretty useless on a Cayman. I really enjoyed your remarks about high school physics ( er, Newton never went to high school and, as far as I know, non relativistic physics hasn't changed since then) and whether I knew what I was talking about re suspension design. I do and I can tell you what's wrong with the Cayman: insufficient power to exploit the chassis. Seem a familiar problem? The BRZ suffers from the same deficiency. Both cars are fun to drive. Connection? |
| MVP Track Time 2013 Great Lakes/Midwest Track Dates | Feffman | Great Lakes | 5 | 09-07-2013 02:39 PM |
| First Track day of this year *Pissing rain* | AJ PwR | Tracking / Autocross / HPDE / Drifting | 12 | 04-19-2013 03:13 PM |
| FR-S/BRZ Named Finalist for 2013 World Car of Year and 2013 Best Performance Car | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 02-08-2013 04:34 PM |
| 2013 SA Car of Year finalists | CoBrA788 | AFRICA | 13 | 01-13-2013 03:13 AM |
| Motortrend - 2013 Car of the Year | RaceR | Other Vehicles & General Automotive Discussions | 6 | 11-10-2012 04:59 PM |
