#57 | |||
Drives: Passat
A dyno tune should definitely give you the best overall result. What I'm really saying here is that you should at least plan on having any base tune reviewed and revised by either a reputable tuner or yourself (if you feel confident enough). OFT is not necessarily a bad option but before taking the plunge I recommend figuring out who is going to review and revise the "free" base tune. I just asked Shiv and his answer was to email him for a case by case quote on e-tuning. I'd do that before making any final decision between OFT and Ecutek. Quote:
So you recommend to the OP that he can safely run OFT's generic base tune without concern but now tell me that any tune requires constant data logging and review? While I agree that any base tune needs to be logged, reviewed and adjusted as necessary, I fail to see why the end user needs to continually data log and review his tuner's finished work or what even qualifies him to do that. My tuner already corrected the open loop AFR and verified acceptable knock correction during the dyno tuning session. The ECU handles closed loop operation and will adjust for changes in altitude, temperature, fuel grade, etc. Why would anyone even use a tuner if they didn't trust him? I wouldn't. I never said that OFT wasn't a valid option. I simply said that Ecutek is a better option overall IMO. I think the main point here is that base tunes should never be blindly trusted without the need for review and revision. If you feel confident enough to do this yourself then OFT looks like a very good option. If however you prefer to let a professional tuner handle this for you, that support is already included with an Ecutek tune and some unknown extra cost with OFT. If you want to change tuners with Ecutek you just buy another tune for ~$300. Changing tuners with OFT should cost about the same. Quote:
Same tune as before. Remotely tuned at Pure Automotive by John Visconti. True but with OFT I'd only have 60% of the whp gain, possibly be running lean and waiting for a quote from Shiv for the cost of e-tuning to fix it. ![]() Why does everyone insist that end-users must continuously and constantly data log their finished tunes? What is it that you expect to change so drastically that the ECU can't adjust for it? |
#58 |
Drives: 2013 FRS
#59 |
Drives: Passat
Don't take it out of context. I was merely comparing your generic base tune to my Ecutek base tune and finished dyno tune. I doubt that any generic base tune is going to match perfectly with the myriad possible combinations of aftermarket intake and exhaust parts available. You're not claiming that your generic base tune is as good as an Ecutek tuner can do with a 1 hour dyno tuning session? If so then I call ![]() BTW, I read a post today from an OFT user who is logging 11:1 AFR with your base stage 2 tune. That's not your target AFR is it? . Last edited by Fast_Freddy; 12-11-2013 at 09:57 PM. |
#60 | |
Drives: 2013 FRS
Also, I've been in this business for far too long to make claims about anything. But IMHO, 80% of it depends on the tuner. The remaining 20% on if it's custom dyno tuned or not. Still not sure how a 1hr custom dyno tune is guaranteed to be a better tune in all cases. My job here isn't to convince you of anything. I've learned that forums aren't the best place to change a mind that is already made up. |
#61 | |
Drives: Passat
This is what happens when you drop into a thread without reading the previous posts. ![]() My point was simply that a tune that has been adjusted based on data log feedback will (in general) perform better than a generic base tune. Obviously there are again many variables here. * BTW, I edited my previous post to make things more clear. |
#62 | |||
blowhard
Drives: frs, project forester
Obviously an ots tune is not as good as a custom tune except in the case of tuner incompetence. But to apply your findings of your base tune ratio to a different product, on a different tuning platform, by a different tuner. That's real retarded sir Quote:
I don't have a dog in the fight, I want to see evolution of the platform as a whole. but your posts are typically subjective biased horseshit will be forum hired gun for free oft |
#63 | |
Drives: 2015 WRX
If you actually bothered to read the rest of those posts you'll see someone else having the same issue and its the result of an exhaust leak at the header. |
#64 | ||
Drives: Passat
You may be an obnoxious blowhard but at least you're smart enough to understand where the "60%" came from. Who knows what the actual difference might be? There are so many variables to consider that it's impossible to do more than make general guesses. I assumed, probably incorrectly, that the reader would be smart enough to figure that part out. Better make it real simple: When I said 60% it was meant to be an example of one possible outcome based upon my own experience and not a general prediction of what would actually occur in every case. Jeeeeeeeezzzzzzzzz........... Quote:
See above and are you sure that @Burn has an exhaust leak? |
#65 | |
Drives: 2013 FRS
http://www.datazap.me/u/burn/first-3-gear-pull?1-2-9-11 |
#66 | ||
Drives: Passat
Not at all but I believe I typed "11:1" when I mentioned this before which was intended to convey 11:1-ish or ranging between 11.0:1 and 11.99:1 or at least as accurately as is possible to measure with a Denso AFR sensor and it's reduced accuracy and range on the rich side of stoich. Apparently 11.37 is as rich as the oem Denso reads per your linked data log. Below is the post I referred to earlier: Quote:
Thanks for the data log link. Isn't 11.37:1 still kind of rich for just a header? |
#67 | |
Drives: 2013 FRS
Shiv |
#68 | |
Drives: Passat
Actually the AFR bottoms out rich a few places in all gears but I agree that the average AFR is high 11's. Even that seems overly rich to me for a N/A header tune but you're the tuner here. It's easier to see if you enhance the AFR resolution. ![]() I didn't realize that I was vehemently justifying my Visconti tune purchase so often. LOL! I thought that I was simply debating some of the pros and cons between Ecutek and OFT after being vehemently attacked by OFT fans for expressing my opinion that a custom Ecutek tune is generally better than a generic, canned, off-the-shelf, one-size-fits-all, OFT base tune. Last edited by Fast_Freddy; 12-12-2013 at 04:04 AM. |
#69 | |
Drives: FRS
this guy is opening doors for many things and some people like me appreciate that
#70 | |
I thought you had learnt something from everyone telling you that you need to do logs before you can claim your tune is safe, but apparently your ears are better than pros and det cans but that is only looking at knock. Blind faith/loyalty, that sums up most of the stupid fanboys. |
| Tags |
| borla, header, spacer |
| Borla UEL header | BeltedBiscuit | Engine, Exhaust, Bolt-Ons | 11 | 03-05-2014 06:35 PM |
| SOLD | sw20kosh | Engine, Exhaust, Bolt-Ons | 5 | 12-17-2013 12:46 AM |
| FS: NEW Borla UEL Header | Cjymiller | Engine, Exhaust, Bolt-Ons | 10 | 10-13-2013 11:04 AM |
| FS: Used Borla EL header | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 3 | 10-07-2013 03:11 PM |
| Ny Fs: Borla header | DarkCard | Engine, Exhaust, Bolt-Ons | 12 | 07-31-2013 10:44 PM |
