#15 |
Don't care
Drives: 2013 Whiteout FRS
I would definitely put them in the correct spot. The primary o2 is what tells the engine how its running, and the secondary checks to make sure the cat is doing what its supposed to be doing. having them swapped is not a good idea
#16 | |
Drives: Dark Grey Metallic 2013 BRZ
the "secondary" o2 sensor is sitting in the front pipe right after the HFC. Currently with the o2 spacer being used. The "primary" o2 sensor is still in the borla header, but its sitting in the hole on the side of the header and not the hole that would be facing the front of the car. That hold on the front of the header is plugged up.
2013 Subaru BRZ Metallic Grey 6-Speed - Mods: HKS Drop in, Perrin Inlet Tube, Kartboy Crank Pulley, Berk HFC Front Pipe, Borla UEL Header, PLM Overpipe, Open Flash Tablet Stg 2 tune
#17 | |
Drives: Silver 2013 BRZ limited
#18 |
Don't care
#19 |
If both o2 sensors are in the header, then its a sure CEL since my only CAT is in the front pipe.
#20 | |
with the 02 spacer you dont need a cat, and you wont get a cel |
#21 |
So all the cash I paid for this shop to put the 2nd o2 behind the cat was all a waste? How depressing.
| The Following User Says Thank You to jordanrw260 For This Useful Post: | Ammonia (11-02-2013) |
#22 |
| The Following User Says Thank You to SliverBrz For This Useful Post: | burnt toast (11-16-2013) |
#23 |
Drives: 2015 Mustang GT (on order)
I know you are happy with the unichip, but honestly you should get a real tune. Sell your unichip and buy an openflash tablet...disable the CEL...and make way more power.
my .02
#24 |
Drives: Scion FR-S A/T, Whiteout
OP, do you know how your shop went about relocating your secondary O2 sensor? Did they have to extend the wires? I was thinking about going this route, but leaving the primary O2 sensor where it was.
While you definitely should pull the code to be sure, I'm hoping your CEL is being caused by the primary O2 sensor not being in the right spot. |
#25 |
#26 | |
Thanks everyone for the advise so far. I will go out today and try to get the code and report back later with the results. Hopefully once I have that it will be a clearer decision on what to do next.
#27 |
Went to O'Reillys, only a generic code of "P219A" was given. :-(
#28 |
Boosted
Drives: Not a supra....yet
| Tags |
| borla, header, spacer |
| Borla UEL header | BeltedBiscuit | Engine, Exhaust, Bolt-Ons | 11 | 03-05-2014 06:35 PM |
| SOLD | sw20kosh | Engine, Exhaust, Bolt-Ons | 5 | 12-17-2013 12:46 AM |
| FS: NEW Borla UEL Header | Cjymiller | Engine, Exhaust, Bolt-Ons | 10 | 10-13-2013 11:04 AM |
| FS: Used Borla EL header | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 3 | 10-07-2013 03:11 PM |
| Ny Fs: Borla header | DarkCard | Engine, Exhaust, Bolt-Ons | 12 | 07-31-2013 10:44 PM |
