| DIY (Do-It-Yourself) Guides For all DIYs. |
#15 |
Drives: 2015 FR-S Release Series 1.0
Sorry for bringing this back from the dead, but yea wish I could see the pictures too. Need this fix in my life, just wanna confirm by the pictures.
#16 | |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
I had a cheap aftermarket aluminum lockout before and the rattle drove me nuts at certain RPMs, changing to oa Raceseng one helped. |
#17 |
Meh!
Drives: Satin White, 86, Manual
RAYS TE37V 17X9 / MICHELIN 245/40/R17 / KW V3 / RACESENG TOP HATS / MOTUL 5.1 + BRAIDED LINES / FERODO DS2500 BRAKE PADS / NEXUS 7 IN DASH / VDS UEL HEADERS / CRAWFORD POWER BLOCKS/ K&N DROP IN FILTER / Custom 3 inch header back catless exhaust / Varex 3in Muffler / HT AUTO LIP KIT / VALENTI TAIL LIGHTS / MORIMOTO PROJECTOR + HID.
#18 |
Drives: 2013 scion frs
heres what i did... i used Allen key to remove screw and pulled out the spring inside with a thin screw driver (i had already grease spring previous to pic). i greased the shit out of it with wheel bearing grease the super thick kind. the first time i pullout spring it was completely dry.
also note that when you grease the spring and thread the screw back in place grease will come out of the holes where the lock out attaches to the shifter when you pull up on the reverse lock out. i just kept pulling up on the lockout until no grease came out. in my opinion its 1000 times better i mean there is still some noise at like 7k but i can live with it. hope this helps guys! ![]() ![]() ![]() ![]() ![]()
| The Following 4 Users Say Thank You to fanuel fierros For This Useful Post: |
#19 |
Drives: BRZ 2017 Pure Red, MT
#20 |
Sorry to re-up, my STi short shifter rattle definetly comes from the spring. I tried to follow the instructions, but it seems that I dont have the allen key on top.
Anyone has the same shifter and issue and managed to fix it? |
#21 |
Drives: 2014 Subaru Forester
If you remove the reverse lockout from the OEM/STI shifter, there is a cable inside that you can grease. Mine was rattling from there, as well as from the washer/pin on the bottom linkage.
#22 |
So, no spring in the STi short shifter? Mine definetly rattles from the internal of the reverse lockuot. Keep it firm, gently put lever under tension doesn't anything, I just have to keep reverse lockout lifted to stop rattle.
No other way to lubricate it? |
#23 | |
![]() If you remove the reverse lockout, and these plastic pieces, you can grease the cable area underneath. I had the same "lift to eliminate rattle" issue as you and this fixed it. |
#24 |
You mean to put grese into those two slots?
#25 |
| The Following 3 Users Say Thank You to tehShirt For This Useful Post: |
| Beatrush Reverse Lockout Lever | simpleisbest | Cosmetic Modification (Interior/Exterior/Lighting) | 37 | 04-16-2015 11:19 PM |
| Shift Knobs and our Reverse Lockout | Chewie4299 | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 07-28-2013 01:23 PM |
| FR_S/BRZ Reverse Lockout Lever | brzadrian | BRZ First-Gen (2012+) -- General Topics | 20 | 06-20-2013 05:07 PM |
| Reverse lockout vibration | SubaSteve | Issues | Warranty | Recalls / TSB | 4 | 03-23-2013 02:26 PM |
| Aftermarket Reverse Lockout Ring Available? | was385 | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 02-17-2013 03:28 PM |
