#281 |
Drives: GBS Premium
No, its the BRZ heater hose that connects to the BRZ pipe-- its the hose that comes out of the firewall between the strut braces. The forester pipe that you replace has the 90 degree bend in it and tends to kink the stock heater hose (5/8 inch) when you reattach it.
#282 |
Drives: Exige S 240
Ok, thanks for the clarification. Having that installed on Friday.
#283 |
CHECK ENGINE
Drives: 2004 STi
i didnt use loctite on mine.
i wrapped some teflon sealing tape on the threads and installed the fitting to the bloc
i don't cry about crickets
#284 |
Drives: vrooom...
This is good stuff: Loctite - PST Thread Sealant 567 High Temperature
#285 |
Yeah use thread sealant/Teflon tape. Loctite isn't a thread sealant.
.o0+Eric+0o.
2016 Chrysler 200S 3.6 2013 FRS 6MT |
#286 |
Drives: Exige S 240
Had mine fitted a few days ago as planned. Thanks again @CARNZ for putting this DIY together.
Looking forward to testing this around Spa later this week.
| The Following User Says Thank You to Guillaume For This Useful Post: | CARNZ (04-01-2014) |
#287 | |
Drives: 2005 Toyota Camry
-alex Edit: I know it's not the best thread sealant available. Teflon is better. Normal Loctite ThreadLocker can be used if you allow it to dry completely prior to application... but since there's so many different products that carry the Loctite brand name, it's best to distinguish clearly. FWIW, many people use Loctite ThreadLocker (dried) on brake bleeder valves. Last edited by mav1178; 04-01-2014 at 04:21 PM. |
#288 | |
we don't use anything on our bleeder screws on the race car. When they are tight, they don't leak and they don't come loose. thread lock and thread sealant are two different things for two different purposes... use what you want, it's your car, hell silicone will seal threads too...
.o0+Eric+0o.
#289 | |
-alex |
#290 |
Drives: Toyota 86 RC
Hello
Please someone tell me hose size in metric for t-piece??
#291 |
Drives: blue GT86, AT
#292 |
Lacking brains
Drives: frz
Looking at this pic of the cusco unit it uses banjos. I'm terrible about the details of fluid pressure, flow restrictions etc. But keeping the diameter of the banjo bolt holes in mind how viable would just taking the throttle body coolant hoses to run into the cooler plate be?
![]() ![]() heres a pic of the 2 hoses, one is at the bung on the crossover coolant pipe the other is the black hose running along top of it to the black of the block. Would be super easy, and clean just to remove the one at the bottom of the throttle body, and just unhook the other, then replace both with lines running to the oil cooler. Last edited by Model Citizen; 04-13-2014 at 08:17 PM. |
#293 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
they are about 1/2 the diameter of the lines going into the oil cooler. Thats too big of a difference to me. Do the math on the area of a circle when you decrease the size of the diameter that much...
#294 | |
Lacking brains
Drives: frz
Those cusco banjo bolts look pretty small too, let alone the bends. Hence picture of the cusco kit linked for reference. Assuming choked flow works similarly wether the restriction is 1 inch or 2 feet than does the diameter really matter significantly? I'm far from an expert on that sort of thing, my last college level physics class was about 15 years ago and a lot of brains were lost in between Last edited by Model Citizen; 04-13-2014 at 10:06 PM. |
| Tags |
| brz, fxt, oil, oil cooler |
| OEM Oil cooler from the 2.0 DIT Forester | Kostamojen | Engine, Exhaust, Transmission | 119 | 09-10-2019 06:28 AM |
| Bought a 2014 Subaru Forester | EAGLE5 | Other Vehicles & General Automotive Discussions | 10 | 10-02-2013 01:54 PM |
| 2014 Forester key fob - nicer than BRZ | Turbowned | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 04-17-2013 04:35 PM |
| BRZ 2.0L Turbo in 2014 Forester | Sleeperz | BRZ First-Gen (2012+) -- General Topics | 37 | 03-21-2013 07:42 PM |
| Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… | 2013GTRNate | BRZ First-Gen (2012+) -- General Topics | 12 | 02-01-2013 01:29 PM |
