86WORX
Old 11-26-2013, 03:39 PM   #169
M1K3
M1K3's Avatar
Drives: vrooom...
Amazon carries [ame="http://www.amazon.com/Techflex-PTN0-50BK25-General-Purpose-Braided/dp/B004UHQNUU/ref=sr_1_6?s=electronics&ie=UTF8&qid=1385495013&sr =1-6"]Techflex[/ame]
M1K3 is offline   Reply With Quote
The Following User Says Thank You to M1K3 For This Useful Post:
autobrz (11-27-2013)
Old 11-27-2013, 11:21 AM   #170
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Well the Oil Cooler Connector is back ordered to eternity.
I just talked to Shawn over at Subarupartswarehouse.com and ordered the STI bolt from a 2008 model. He said if it doesn't work I can send it back for a full refund which is badass. I'll update if it does in fact work, there were more in stock too.
post_break is offline   Reply With Quote
Old 11-27-2013, 12:03 PM   #171
autobrz
Drives: Mazda 3
Has anyone logged oil temps on the track with this oil cooler?
^^ my dealer is also still waiting on the oil cooler and connector.
autobrz is offline   Reply With Quote
The Following User Says Thank You to autobrz For This Useful Post:
CxG (04-25-2016)
Old 11-27-2013, 01:01 PM   #172
The Slow One
Track Junkie
Drives: Argento Scion FR-S
I'm going to record my track logs this weekend
Sent from my SGH-T889 using Tapatalk
The Slow One is offline   Reply With Quote
The Following 3 Users Say Thank You to The Slow One For This Useful Post:
autobrz (11-27-2013), CxG (04-25-2016), normancw (11-28-2013)
Old 11-27-2013, 01:54 PM   #173
CARNZ
CHECK ENGINE
Drives: 2004 STi
If the 08 STi oil cooler connector works let me know and I will add it to the list on the first page as an alternate piece.
i don't cry about crickets
CARNZ is offline   Reply With Quote
The Following User Says Thank You to CARNZ For This Useful Post:
CxG (04-25-2016)
Old 11-28-2013, 02:22 PM   #174
post_break
post_break's Avatar
Will do. Also know that the new WRX has an oil cooler just like this. I would assume 2014 model, the one with the six speed.
Old 11-28-2013, 02:52 PM   #175
CARNZ
CHECK ENGINE
Drives: 2004 STi
Once a 2015 wrx makes it to our dealer, I am going to look it over and see if their water pipe will be a better fit than the FXT one.
The Following 2 Users Say Thank You to CARNZ For This Useful Post:
charged86 (04-18-2014), CxG (04-25-2016)
Old 11-28-2013, 04:23 PM   #176
post_break
post_break's Avatar
It's top mount oil filter too so the oil cooler should work on our car as well.
Old 11-28-2013, 04:34 PM   #177
CARNZ
CHECK ENGINE
Drives: 2004 STi
the cooler is probably the same part number as the FXT since its basically the same engine. I just wanna see that water line since some people have expressed concerns about the current FXT solution
Old 12-01-2013, 04:48 AM   #178
The Slow One
Track Junkie
This is my oil temps with the first session of the day, I only logged 2 sessions, I can upload my afternoon session(slightly higher ambient) if anyone requests for it. My other sessions were running my lap timer.
The Following 5 Users Say Thank You to The Slow One For This Useful Post:
CARNZ (12-01-2013), CxG (04-25-2016), keen as (12-01-2013), M1K3 (12-01-2013), normancw (12-01-2013)
Old 12-01-2013, 09:35 AM   #179
M1K3
M1K3's Avatar
Drives: vrooom...
Yes, please do. Also what was the actual Max Oil Temps that you hit? Thanks
Old 12-01-2013, 02:14 PM   #180
The Slow One
Track Junkie
Can do I my last track event was on October 26-27 at the same track but I peaked at around 294f in oil temps. The ambient temps were in the mid 80s those days though. Sadly I accidentally cleared all my logs before I was able to email them to my account.
autobrz (12-01-2013), CARNZ (12-01-2013), CxG (04-25-2016), keen as (12-01-2013), normancw (12-01-2013)
Old 12-01-2013, 06:02 PM   #181
track junkie
Drives: 2022 Subaru BRZ
The OEM oil cooler looks great for track use. A manual by-pass valve for closing off the oil cooler when driving on the street might be beneficial to prevent oil temperatures from being too cold.
track junkie is offline   Reply With Quote
Old 12-01-2013, 07:14 PM   #182
The Slow One
Track Junkie
no need for it, the cooler cooler acts as a oil warmer for faster warm ups, while cruising to the track, my oil temps tend to be 6-8 degrees above my water temp.
just to add as well, it was 40 degrees outside when i went to the track that morning.
The Following 2 Users Say Thank You to The Slow One For This Useful Post:
CxG (04-25-2016), normancw (12-02-2013)
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 06:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 01:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 04:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) -- General Topics 37 03-21-2013 07:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) -- General Topics 12 02-01-2013 01:29 PM
