#29 |
Drives: toyota mr2/ Toyota GT86
Bent rods owch!
how much boost was that then? and at what rpm? |
#30 |
Drives: 2013 SWP BRZ
guess that means i'm out on this upgrade if its really going to be strongly advised you build the motor. Not going down that road again.
#31 | |
Drives: Firestorm FR-S
What was your experience with a build? |
#32 | |
Could be way different for this motor, but its just not something I'd personally go through again lol. I was hoping this upgraded unit would be a step up in power but not to the motor build point. Maybe on lower boost I could pull it off, but we have to wait and see. |
#33 | |
Drives: 2013 Black FR-S
| The Following User Says Thank You to sw20kosh For This Useful Post: | Calum (10-31-2013) |
#34 |
Drives: AE86, 2x GT86, TE27
They are saying built motor to cover their ass. Based on what others have achieved with the motor, I would run it as is. But, with the knowledge I have signicantly increased the risk of engine/driveline failure; as you have with any FI kit.
I certainly wouldn't pre-emptively build the motor. Big blower + built toda stroker motor = win |
#35 |
Drives: FR-S Very Hot Lava
People wants moar pawar
Kit provides moar pawar Kit needs engine build to support moar pawar. People call it fault |
#36 | ||
![]() Quote:
If this thing can make like 350whp without overstressing, I really think its going to get a LOT of attention. |
#37 |
Drives: Ultramarine FR-S 6MT
Why can't there be an interlock between the tach and a blowoff valve that prevents the excess boost at low RPM, and feeds it in at higher RPM?
that can't be that damn hard to engineer. Certainly it's cheaper than new rods! |
#38 |
That Guy
Drives: 2013 asphalt FRS MT
You could just limit the max throttle opening at low rpm, via the tune.
#39 |
Dismember
Drives: 2013 Red Scion FR-S
Remember, since an SC runs off the engine directly, it takes power to make power. 250HP at the crank might require 300HP worth of stress with 50HP going to run the blower. That plus lower rpm=engine problems. A larger blower will mean more friction, more mass, and more effort to spin for the same HP, at least much of the time. For most people, the smaller blower will probably be better, and remember, you can always twin charge!
| The Following User Says Thank You to EAGLE5 For This Useful Post: | Lawnik (10-31-2013) |
#40 | |
They make those, it's called vortech and rotrex. |
| The Following User Says Thank You to xxscaxx For This Useful Post: | OmarGC (12-11-2013) |
#41 |
Make love
Drives: H8R.. Not really
Bow down to the almighty TWIN SCREW.. Creator of POWAH. May it wet your undergarments and bring joy to those who use it!
#42 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
We can alter the boost down low with cam timing by letting the blower exhale with a partly open exhaust valve towards the end of the stroke. Reduces boost by several psi. We can also drop timing down low to cut down on power, so that portion is no big deal. But the big blower will eat HP and add weight, so any gains from the cooler charge will be lost. Stock motor I see no issues with 70mm and cooler or e85, or the 72.5 if you want to stay below the continuous redline of 15000 rpm at all times.
| The Following 2 Users Say Thank You to Xero-Limit For This Useful Post: | Mark@Abbey m/s (11-01-2013), tech4pdx (10-31-2013) |
| Abbey Motorsport Sprintex SC updated Dyno plots | Mark@Abbey m/s | Forced Induction | 49 | 02-16-2017 12:13 AM |
| Khorne's - AUDM Red 86 GTS Sprintex | Khorne | Member's Car Journals | 53 | 08-31-2014 10:44 AM |
| Sprintex or Vortech, which setup has more potential? | Turbowned | Forced Induction | 328 | 09-14-2013 12:09 PM |
| Abbey Motorpsort GT86 Sprintex installation | Mark@Abbey m/s | Forced Induction | 18 | 09-07-2013 05:11 AM |
| Sprintex Supercharger Sneak Peak!!! | invisage | Forced Induction | 52 | 03-03-2013 07:11 AM |
