Old 01-07-2014, 10:24 AM   #43
mrk1
Drives: Sterling BRZ Ltd
Originally Posted by Mari0 View Post
Lol
Same goes for boost, its not out of the question that one day a turbo car goes into boost only to find that the waste gate vacuum line has melted or fallen off. Oops and over boost.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 01-07-2014, 10:26 AM   #44
mrk1
Originally Posted by OjiGeorge View Post
I've heard of the WOT and window switch, but not the other fail safes like bottle pressure etc. I'll give it some more research, thanks.
There are as many fail safes as your willing to buy.
The Build Thread
Old 01-07-2014, 10:43 AM   #45
mike the snake
I always wondered if a tiny shot of nitrous on a turboed car just when you get on it, to reduce turbo lag, or help the turbo spool up quicker might be possible?
Old 01-07-2014, 10:47 AM   #46
mrk1
Thats very possible, mostly only done with large turbos. Spray the nitrous to get the turbo going, then taper off as boost comes on.
The Build Thread
Old 01-07-2014, 10:56 AM   #47
FR-S Matt
Wouldn't a twin scroll turbo just get rid of the lag all together without the need for nitrous?
Old 01-07-2014, 12:33 PM   #48
mrk1
Yes and no, I'm talking LARGE turbos. Certainly there are other ways to combat lag in the realm of common sized turbos.
The general rule of thumb is don't spray below 3k rpm so if your turbo hits boost at 3800 it wouldn't really be worth while. But if you have something large that takes more rpm's then nitrous could help fill in those lower rpm's.
Trevor Langfield wrote a very good book about nitrous. He is know as the Wizard of NOS over in the UK. He did the nitrous Jag on Top Gear. Its a very good read and discusses many of myths around nitrous use. There is a section on nitrous and turbos.
MotorBooks Workshop also has a Nitrous book, I've never read it but there other stuff is good. I feel like in the days of forums and internet, good old print books often get over looked. I used to read these kinda text books on my commute when I rode public transit. Now I keep them around my shop because they are full of helpful formulas and conversion charts. Most are a little out of date but they are still a great resource.
The Build Thread
The Following User Says Thank You to mrk1 For This Useful Post:
kombatlion (01-07-2014)
Old 01-07-2014, 12:49 PM   #49
SillySaxon
SillySaxon's Avatar
Drives: Sc10n Series FR-S
it would but the point is that nitrous isn't always there, you don't HAVE to use it.
Also from a little research it looks like N2O is cheaper to get set up than a proper twin scroll turbo.
I figure as long as you smile while driving the car, you're doing it right.
SillySaxon is offline   Reply With Quote
Old 01-07-2014, 01:06 PM   #50
mrk1
I hardly passed chemistry back in high school but the play by play of how nitrous works is pretty cool, to me at least.
The Build Thread
Old 01-07-2014, 03:23 PM   #51
executivekoala
executivekoala's Avatar
Drives: fr-s
D sport actually did this already, they are running a 50 shot and are making good power about 220whp. I would check out their write up and that should answer most question...it did mine. I'm planning on going with the NX kit for the Fr-s
executivekoala is offline   Reply With Quote
Old 01-07-2014, 04:38 PM   #52
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
Nitrous is great and effective power adder. DI engines respond to it very well. Just make sure you use a wet shot.
Also use a step colder plugs and if you are tuned, speak with your tuner about retarding timing a bit. you do not want to run much advance on a nitrous setup.
PrimeMotoring is offline   Reply With Quote
The Following User Says Thank You to PrimeMotoring For This Useful Post:
mrk1 (01-07-2014)
Old 01-07-2014, 06:16 PM   #53
pcporo
No Martians here?
pcporo's Avatar
Drives: FR-S Asphalt MT
Originally Posted by Saibot View Post
Ya know, the best way to install is to pour directly into fuel tank
http://www.gixxer.com/forums/showthr...=226570&page=3
thanks man, been laughing for a good while reading this. haha
pcporo is offline   Reply With Quote
Old 01-07-2014, 10:47 PM   #54
mrk1
I ordered the back issue
The Build Thread
Old 01-07-2014, 10:56 PM   #55
diss7
Drives: AE86, 2x GT86, TE27
I came hear to troll but the good jokes have already been cracked.
Plumb the nitrous into the cabin. It will make the car feel like a time travelling Delorean.
diss7 is offline   Reply With Quote
Old 01-07-2014, 11:22 PM   #56
mrk1
I was just at my welding supply store today, I should have asked if then can get nitrous.
The Build Thread
Search this Thread:
Advanced Search
the way of engine and gearbox system work? megancheung Engine, Exhaust, Transmission 8 03-22-2012 01:56 AM
UK work Giccin EUROPE 5 02-09-2012 02:21 PM
Nitrous Oxide/Meth injection JDLM Engine, Exhaust, Transmission 6 12-17-2011 05:23 AM
Off to Work! Exage Off-Topic Lounge [WARNING: NO POLITICS] 2 09-17-2011 12:04 AM
Does anyone work for Toyota? MTD Scion FR-S / Toyota 86 GT86 General Forum 7 10-25-2009 08:40 PM
