Old 11-23-2013, 12:33 PM   #43
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Originally Posted by Turbo95eg6 View Post
First off, thanks for posting the video. I have a mere 200+ miles on my BRZ, and I started to notice a familiar (not as noisy) sound. Just as OP described, I thought it was coming from the speaker, and at first thought it was static coming from the audio. I'd hear it with my music turned up, so you could say it was pretty noticeable. It almost sounded like it was coming from outside the vehicle, but the noise was audible usually when I depress the accelerator during engine breaking. For that reason, it would make sense that this noise is somehow related to the accelerator. I drove it on the freeway today, and I could replicate the same noise cutting the throttle and letting the RPM's go down from 4000-3000 in 4th gear. What's strange, is that it seemed to go away on much smoother roads
I'm still confused to how the bracket would make such a noise, and why not all BRZ's are affected by this. Would you be kind enough to take a picture of where the felt is applied?
Since the tech applied the felt, I'm not exactly sure where it is. However, what you've described is very similar to what I experienced. I think it did get worse, but only a bit and then stayed about like how you heard in the video. Based on what you're saying, you might have the same issue. I guess some BRZs are slightly out of spec and that accelerator assembly just rattles against the firewall? Either way, the fix has held for me. Very happy that it's gone.
Prog is offline   Reply With Quote
The Following User Says Thank You to Prog For This Useful Post:
Turbo95eg6 (11-23-2013)
Old 11-23-2013, 12:34 PM   #44
Prog
Prog's Avatar
Keep us updated on the fix, I think I'm gonna try this out as well.
The buzz/rattle is still gone for me.
Erci (08-19-2014)
Old 11-23-2013, 09:23 PM   #45
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
So I think I have the assembly issue figured out. When I lightly tap the gas pedal assembly with my foot, I can hear a slight buzz. After I took out the assembly, tapped on the black box, and I could clearly hear the metallic rattle. I definitely think the rattle is from the spring used inside for the pedal motion, and the vibration we hear is traveling off the firewall to the dash. I did manage to put a foam "gasket" I made, and I'm not sure if it is thick enough to cancel the vibration but I think this is definitely a start. I didn't hear anything driving on the road but will give it a try on the freeway soon. Thank god for these forums!
Well that must be a huge improvement, and it must be nice to not hear that rattling anymore.
The Following User Says Thank You to Turbo95eg6 For This Useful Post:
Erci (08-19-2014)
Old 11-29-2013, 10:56 PM   #46
Blunt
Drives: WRB BRZ MT
Originally Posted by Sookainian View Post
Mine also making some kind of rattling sound behind the dash while driving. I tried removing everything but couldn't find any lose wiring.
To my surprise after i loosen this screw the sound is gone. When I tried tightening it back, the sound comes back. It sounds like the plastic is rubbing/knocking against the metal bar behind.
What i did was to take some foam padding and stick it in between and the sound is gone.
Going to test drive it later
After Subaru had about 6 cracks at it (off the road for about 5 days in total) and only put foam on the front trim, etc, I decided to take mine apart. When I got the instrument cluster out it was clear that the hadn't done anything the in depth. As soon as a wiggle the plastic with the screw in it near the beam TICK TICK TICK. Loosened the screw, foam tape behind in and tightened. Still a slight notice from the screw itself so I put the screw through a small piece of foam tape. Completely silent.
Added a bit more foam tape between the plastic and instrument cluster for good measure. Finally installed my JPM cluster hood at the same time (got it a month ago but wanted to fix the rattle first).
Took it for a long test runs over good and bad roads, not a peep (touch wood).
Blunt is offline   Reply With Quote
Old 12-23-2013, 09:29 PM   #47
puravida
Drives: 14 brz, 97 nsx, 85 land cruiser
[QUOTE=Turbo95eg6;1349320]So I think I have the assembly issue figured out. When I lightly tap the gas pedal assembly with my foot, I can hear a slight buzz. After I took out the assembly, tapped on the black box, and I could clearly hear the metallic rattle. I definitely think the rattle is from the spring used inside for the pedal motion, and the vibration we hear is traveling off the firewall to the dash. I did manage to put a foam "gasket" I made, and I'm not sure if it is thick enough to cancel the vibration but I think this is definitely a start. I didn't hear anything driving on the road but will give it a try on the freeway soon. Thank god for these forums!
how's your foam gasket working out ? i'm trying to solve the very same issue. thanks !
puravida is offline   Reply With Quote
Old 12-24-2013, 04:33 AM   #48
DCStorm
DCStorm's Avatar
Drives: 2013 FR-S (RIP), 2017 Toyota 86
http://s1264.photobucket.com/user/xD...7b6a6.mp4.html
Heres the buzzing I'm hearing.. its exactly the same as yours from the video. Thinking of taking it to the dealer and showing them that pic you posted of the report and see if they could do the same fix under warranty.
DCStorm is offline   Reply With Quote
Old 12-27-2013, 09:40 PM   #49
2014scionfrs
2014scionfrs's Avatar
Drives: 2014 Scion FR-S
Yeah, I got the same thing too! I bought mine with 21 miles on it and it has done it since day one. Going back to the dealership on Monday along with many other problems/complaints
2014scionfrs is offline   Reply With Quote
Old 12-29-2013, 10:06 PM   #50
Marusich
Marusich's Avatar
I stuck a small piece of foam between the windshield and dash to apply some pressure on the dash and the noise is gone.
Marusich is offline   Reply With Quote
Old 01-12-2014, 07:12 PM   #51
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
I took a video of the rattle and myself speaking after the noise occurs and saying where I'm holding my phone. It is clearly under the dash somewhere.
Still looking for help on this. Thanks guys!
did you ever solve the buzzing sound ?
That's the exact same noise that I hear, buzzing sound
ucsmfu is offline   Reply With Quote
Old 01-12-2014, 07:34 PM   #52
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
Originally Posted by connorlug View Post
I did the fix on my own car yesterday. Some sticky felt in between the gas pedal and the bracket for it on the body of the car. Seems to have fixed it so far!
For anyone wondering, it's extremely easy to do yourself. Unbolt the 2 10mm nuts on the gas pedal, and unplug it. Apply the felt to the back of it, and retighten it.
what kind of felt did you use ?"
thanks
Old 01-12-2014, 08:28 PM   #53
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
I'm removing my electric super charger for an update. Since I have to remove the throttle switch I'll take care of the rattle/buzz. I'm going to install some expanded PTFE tape between the firewall and this bracket. The PTFE will provide an isolate barrier between the two surfaces.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 01-13-2014, 03:12 AM   #54
puravida
hey guys,
i have the same buzzing sound . . .
my initial thought was that it was coming from the accelerator assembly. i read someones suggestion about placing felt and i tried a layer of foam. it didn't work. yesterday i placed some gt mat on the firewall and raised metal portion that the accelerator assembly attaches to . . . i figured that would cut the vibrations going to the accelerator . . . i figured wrong . . .
the buzzing continues
i'm starting to think its coming from somewhere else . . .
Old 01-15-2014, 02:11 AM   #55
jflogerzi
jflogerzi's Avatar
Can you take a picture of this?
Old 01-15-2014, 11:38 PM   #56
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
Mine usually occur when I am driving on bumpy roads and my passenger side would rattle like crazy.
Kelbyat07 is offline   Reply With Quote
Search this Thread:
Advanced Search
Light buzzing sound from driver-side dash BRZprime Issues | Warranty | Recalls / TSB 51 08-21-2015 10:34 PM
Driver Side Window Rattle RiceCooker Issues | Warranty | Recalls / TSB 23 08-18-2015 11:20 AM
Rattle from driver's side door lock. Mandy Issues | Warranty | Recalls / TSB 0 07-10-2013 09:44 PM
BRZ Driver side mirror rattle with stock speakers slawdio Issues | Warranty | Recalls / TSB 2 07-01-2013 01:23 PM
Driver Side Speaker Housing Rattle Lefty Scion FR-S / Toyota 86 GT86 General Forum 2 06-12-2012 11:32 AM
