#29 |
Drives: Sterling Silver BRZ Limited MT
2680lb or 1215kg. That's all filled up.
56/44% F/R Some mods for saving weight, but power and cooling mods that added some too. Build thread: http://www.ft86club.com/forums/showthread.php?t=53027
| The Following User Says Thank You to jack43 For This Useful Post: | Anthony (01-03-2014) |
#30 |
Curious cat.
Drives: 86 GT base M/T - Red
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) |
#31 |
Drives: 86
Got my car corner balanced yesterday..
2013 Scion FR-S Seibon DV hood Tein SRC @CSG Mike Wedsport TC105 17x9 235/45/17 RS3 Voltex Type 1S Koyo Radiator Shorai battery kit @KCMachine Grimmspeed strut bar Raceseng lightweight crank pulley APR Formula mirrors APR front air dam Cusco Rear LCA SPL Rear Toe Arms No spare tire / tools 100% stock exhaust system 3/4 tank of gas 2860 lbs with driver ~2700 lbs without driver Corner weights 816 766 664 614 Cross weights 1430 / 1430 - 50% 50% FR weight distribution 55% 45% LR weight distribution 52% 48%
#32 |
Drives: Fast ones
As a baseline, this is with everything on the car, but it's got Vortech, Brembo GT BBK, 4 point roll bar, lots of chassis bracing, massively wide tires and wheels, RB V1 widebody, no driver 2881lbs. I believe it had a near full tank of gas.
810/795 628/648 That's 1458 + 1423 delta 25 lbs With the spare it came in at 2907lbs 813/790 637/667 That's 1480 + 1427 delta 53 lbs Pulling the spare gave me closer cross weights. now with my skinny ass and no spare it was 3005lbs 864/804 665/672 1536 + 1469 delta 67 lbs Car is going through some surgery right now so we'll get back to dialing things in afterwards. Displacing weight, or using ballast weight to get us as close as we can to ideal. Currently this has the stock battery but unfortunately lightening that will do the opposite of what I want in terms of cross weights. I either need to reduce weight from the front driver side, lower that side to remove load, or do the opposite to the passenger side. I had the rack available to me on a full gas tank day unfortunately but I will recheck it again after it gets out of the body shop. I would imagine you guys should be looking more at your cross weights rather than F/R or L/R. |
| The Following User Says Thank You to AutoRnD For This Useful Post: | Anthony (06-19-2014) |
#33 |
Drives: 2004 Toyota RAV-4 5M
![]() So thats 2902lbs. with me + race gear (~215lbs.) and 70lbs. of ballast for me to stay in my class for time trials. That would put me around 2617lbs. for the car itself. The car was weighed with around 1/3 full tank. Other than removing the driver side floor mat and spare tire/tools, the interior has nothing removed and is totally stock. Mods: Mods: Essex AP Racing Sprint BBK Ohlins Road and Track Coilovers Hoosier R6 225R45 ACT Prolite Clutch/Flywheel Drive Shaft Shop CF Drive Shaft Perrin Motor Mounts Whiteline Diff Cradle Whiteline Positive Shift Kit Driveway Labs Rear Diffuser K&N Drop In Filter Crawford Performance Air/Oil Separator Enkei RPF-1 17x8 5lbs. Shorai Li-Ion battery 70lbs. of ballast |
| The Following User Says Thank You to ja1217 For This Useful Post: | Anthony (06-19-2014) |
#34 |
Drives: '87 Corolla GTS, '13 FR-S 6MT
![]() 2617 lbs without me in it. Gas light was on. No trunk junk. Weight loss mods: Ballistic battery w/tray Sparco Drivers seat w/steel brackets and stock sliders Nameless headers + overpipe/frontpipe (not too much lighter than stock) MCS suspension w/2.25" springs TRD intake w/sound tune delete Weight gain: Ground control top hats w/strut bar Cusco solid 22mm sway bar Wheel/tire combo Weds w/RS3s (42lbs vs 41lbs) 3 point lap harness Misc bushing inserts Radium catch can |
| The Following User Says Thank You to RiskyTrousers For This Useful Post: | Anthony (06-19-2014) |
#35 |
Drives: Used to Drive:Grand-Am GS #54 E36M3
NASA TT? If so, which class (too lazy to get the classification sheet out :-)?
#36 |
Yeah, I'm in NASA TTD. Apparently the organizers thought the car was too good so they added 110lbs. to the minimum competition weight, bumping it up from 2775 to 2885. The car does pretty well, but I still can't seem to catch up to some of the good drivers in E36 M3's. I could still do an E85 tune and stay in TTD which I'm sure would help my straight line speeds, but I'd like to avoid the hassle of trying to carry around tanks of E85 to the track. My car is already completely full with 4 wheels/tires for the hoosiers, tools, jack, jack stands, camping stuff and girlfriend.
| Official Component Weights & Weight Reduction Thread | JRitt | Tracking / Autocross / HPDE / Drifting | 379 | 04-16-2023 05:15 PM |
| Official San Antonio , TX Thread!! | track_warrior | Southwest | 3762 | 03-28-2019 03:03 PM |
| Official Norwegian Thread | atledreier | EUROPE | 190 | 01-19-2014 01:38 PM |
| The Exhaust Weights thread | qoncept | Engine, Exhaust, Transmission | 5 | 06-12-2013 03:34 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
