#29 | |
Drives: 2013 FRS
#30 |
Sorry for the late response, I was adjusting/increasing the seat height using something like this (cut to length):
http://www.cap-aluprofile.com/S1084040L.jpg (I think I have kinda long legs and a short torso, so I'm not sure whether this info is of any use to you). (FWIW, none of the guys I race against use any slides.) |
#31 |
Drives: FR-S 10 series
I also had to drill new holes when installing aftermarket seats using the planted seat bracket. I was expecting a 'plug and play' scenario. That seems to rarely happen these days.
IG: @Lucky_FatPat
10 series // TRD x Turbo Build: http://www.ft86club.com/forums/showthread.php?t=79474 |
#32 | ||
Drives: 2013 FRS
Any issues adjusting to the lower seat height? |
#33 |
Any issues adjusting to the lower seat height?[/QUOTE]
I'm 5'8 on a good day, so height was't really an issue for me w/ the planted bracket.
IG: @Lucky_FatPat
#34 |
Drives: 2013 FRS
[/QUOTE]Not sure if I conveyed my question clearly, did the aftermarket seat being lower feel weird to you vs the OEM seat height? I know the planted base w/o sliders will drop you a couple inches as far as seating position goes vs OEM. I too am 5'8 |
#35 | |
I used 4 of these aluminum blocks as washers/spacers (screw goes through the center hole). They were placed between the seat base and the seat side mounts. (In order to get some extra height which I had with the rails before.). A machine shop cut those aluminum blocks to length (length of about 1.5" each), which took about a minute. |
#36 | |
I'm running a Nardi 350mm wheel and have it adjusted to the lowest setting as well.
IG: @Lucky_FatPat
#37 | |
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
So did you just shorten the length of the stock belt buckle bracket and connect belt buckle extension? Did you cut the stock one or make a new one? |
#38 |
I left the stock belt buckle as is.
I made an extension (basically a sheet metal piece with 3 holes, 2 holes to connect with the seat base bracket and one hole to connect with the belt buckle). This extension moved the connection hole to the stock belt buckle about 5 inches to the rear. This way I didn't have to shorten it. If possible I would weld a new bracket to the seat base, so you don't need an extension. (In my case this wasn't an option because the seat was too far back.) |
| The Following User Says Thank You to rx3 For This Useful Post: | Rookie84 (10-14-2015) |
#39 | |
#40 |
Drives: 2014 ASPHALT FR-S MT
| FS/FT: Recaro Young Sport child seat | Cade01 | Miscellaneous | 25 | 08-06-2013 03:35 PM |
| Recaro Sporster CS installed in BRZ. | Racecomp Engineering | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 06-04-2013 06:51 AM |
| The Perfect Dry CF Recaro Seat for the FRS | Hanakuso | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 05-17-2013 04:55 PM |
| Who sells Recaro seat mounts here in the US? | Hanakuso | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 02-05-2013 01:19 PM |
