Old 11-30-2013, 08:05 PM   #15
CodyFRS
CodyFRS's Avatar
Drives: Asphalt FRS
Originally Posted by infinite012 View Post
The intake on the WRX/STI has long been proven to flow more than basic bolt-ons will require. Nobody really changes out the intake unless they want more sound and/or going ginormous turbo.
The sound change had no influence on buying an intake for me. It was simply to try and give the car a little more power. If you dont have thousands to drop on a turbo or s/c, anything helps for additional hp & t/q gains.
CodyFRS is offline   Reply With Quote
Old 11-30-2013, 09:19 PM   #16
Grateful Dave
2nd 86 member
Grateful Dave's Avatar
Drives: 2013 Asphalt AT FR-S
I tried The K&N oiled drop in. I didn't feel any much of a performance gain. Then after installing the Greddy intake without the snorkel. I felt a performance gain. No numbers but I feel a gain. Greddy recommended to take the snorkel off. I wanted to leave the snorkel on but I removed it. It was a pain to remove, but if I wanted to get their claim of "HP: upto 9*hp increase, 2-3 peak and TRQ: upto 10*ft-lbs increase, 6-7 peak". The car needs all the boost it can get. I didn't drill a hole for the sound tube but kept the sound tube installed. I left the sound tube so when switching back to stock for smog certification the intake looks completely stock. I'm not sure not having the snorkel will effect smog certification. I don't want to reinstall the snorkel. You can hear the intake so much more than with the sound tube. I have the dry element filter. The K&N filter is oiled and they can contaminate the MAF sensor. I went through that with my Tacoma 4x4 and I had to buy a new MAF sensor even after cleaning with alcohol. No more oiled filters.
Overall I like my Greddy intake. If someone can make an intake with better performance gains, I might give it a try.
Grateful Dave is offline   Reply With Quote
Old 12-11-2014, 10:55 AM   #17
FRS Justin
Drives: 2013 Asphalt FRS
I was on a dynapack dyno stock airbox and factory filter made a pull 199hp opened air box dropped in a k/n made a pull 200hp thats it. Went to Airaid bolted on a cold air intake system while on their Mustang dyno picked up 4 hp they work.
FRS Justin is offline   Reply With Quote
Old 12-11-2014, 12:04 PM   #18
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Hey I just wanted to answer the OPs question as this is info we obtained while testing intakes. I would STRONGLY suggest taking the time to remove the OEM snorkel, as the car runs extremely lean with it equipped.
Greddy, No Snorkel
Greddy, OEM Snorkel
Greddy Before and After Snorkel
So you can see the results are consistent, and are not favorable with the OEM snorkel, so I'd remove it. Sorry I saw this thread so late!
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
The Following User Says Thank You to GrimmSpeed For This Useful Post:
JPxM0Dz (12-11-2014)
Old 12-11-2014, 12:24 PM   #19
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
According to about 50 dynos Toyota/Subaru have already made a better intake..just need to put in a filter
Old 12-11-2014, 12:26 PM   #20
jflogerzi
jflogerzi's Avatar
Intakes are a waste of money. Just get a drop in filter and a intake tube that deletes the stupid noise generator.
2013 Series 10 FRS #553
Old 12-11-2014, 05:30 PM   #21
Koa
Sweeper
Koa's Avatar
Originally Posted by JPxM0Dz View Post
Sorry man, but...
. Go back to stock
. Install a decent drop-in filter
. Remove or modify your existing snorkel for better airflow or just replace it with an HKS air duct
. Do a sound tube delete while your at it
. Get a tune!
. Sell your Greddy
And in that order! If someone would have gave me these instructions months ago, I would have saved alot of money on intakes
Reason: Stock intake with a drop-in filter & tune is as good or better than any aftermarket intake
If you want to keep your Greddy, just remove and replace with modified snorkel or an HKS - Get a tune if you don't already have one
What's right for you isn't right for everyone, although I am inclined to agree that the budget-conscious performance oriented person should get a hi-flow filter in lieu of the entire intake.
I got a grimmspeed intake for $200, factoring in the group buy price and the money I got from selling the stock box. $200 is nothing. People spend 1k+ on catbacks. To each their own brotha... that's the beauty of it all
The Following User Says Thank You to Koa For This Useful Post:
Old 12-11-2014, 05:36 PM   #22
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Hey I don't always follow my own advice either, as I ended up grabbing one from the GB myself
2URGSE
JPxM0Dz is offline   Reply With Quote
The Following User Says Thank You to JPxM0Dz For This Useful Post:
Koa (12-11-2014)
Old 12-11-2014, 10:11 PM   #23
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
I removed the stock snorkel when I installed my Takeda V2 (Same design as the Greddy).
Only because the instructions told me to.
You don't have to remove the front bar to remove the snorkel BTW. I simply unbolted the top of the bar, removed the thin bolt plate and then had a buddy bend the top of the bar back slightly while I snaked my hand in with a socket and undid the three bolts underneath.
Then you just pull the snorkel out of the space made by bending the top of the bar back. Bending the bar doesn't damage it at all, it's meant to flex.
Wise is offline   Reply With Quote
Search this Thread:
Advanced Search
AFe Intake -with or without snorkel? gms Engine, Exhaust, Transmission 2 10-25-2020 05:23 PM
Does anyone have a GReddy Intake Installed? Massdrop Northern California 6 08-01-2013 04:02 AM
Changing Intake Snorkel JDKane527 Engine, Exhaust, Transmission 10 05-08-2013 12:27 AM
MT Stock Shift Knob, Stock Intake w/Snorkel Vicious LED Interior Parts (Incl. Lighting) 1 02-09-2013 04:14 PM
Bigger Intake Snorkel Duct? Anorexic 86 Engine, Exhaust, Transmission 8 01-29-2013 02:00 PM
