#43 |
Drives: Whiteout FRS
@shiv@vishnu My cousin who got the tablet from you @ the NorCal meet is getting the CEL P0700 after installing catless headers and flashing 1.3. Any ideas? It's an AT FRS.
#44 | |
Drives: 2015 Mustang GT (on order)
#45 | |
Drives: '13 DGM BRZ Limited
(DTC) CODE # P0700....Transmission Control System (MIL Request) Translation: Transmission Control Module (TCM) Malfunction or Failure. P0700 Information Code The Transaxle Control Module (TCM) monitors the malfunction of sensors and actuators relating to transaxle control. If any malfunction is detected, the TCM informs the PCM by sending a signal (P0700 code). P0700 means that a code has been set in the TCM. This code is for information ONLY. If this code is present, check for transaxle codes. So basically, the P0700 code is telling you to check the TCM for a transaxle DTC. The TCM can not turn on the check engine light so it has the PCM do it. |
#46 | ||
#47 |
F Z1LLA
Drives: Lexus IS-F Series 2
Have you tried reflashing back to stock, then the tune again ?
2URGSE |
#48 |
Drives: 2013 FRS
Sounds like a connector on the transmission was unplugged when the header was installed.
#49 |
Drives: 2014 BRZ Limited
Picking up BRZ tomorrow. OFT in hand. Catless EL header ordered, no ETA.
Upon install of the latter my question is whether an O2 spacer is necessary with this tune to avoid the CEL or whether it must/can be turned off safely with Tuner Pro? |
#50 |
Drives: 2013 FR-S whiteout
Welcome fellow South Carolinian. You should not need the spacer. I plan to get rid of mine once my OFT arrives.
#51 | |
Does that mean that this build has already turned off the 2nd sensor? |
#52 | |
He was on 1.2 prior to this. Will have him downgrade to 1.2 then to stock before back to 1.3 to see if CEL still exist.
It turns off the error code for the o2 sensor. |
#53 |
Not sure it turns the sensor off (i.e. heater), but keeps the CEL from coming on in relation to at least catalyst check (possibly heater malfunctions too).
#54 |
Drives: red frs
stage 2 test drive tomorrow.
also on a side note the tuner pro update solved my no start issues when adjusting the launch control.
| The Following User Says Thank You to Shit Luck For This Useful Post: | Shiv@Openflash (10-26-2013) |
#55 |
Hmm, maybe it's just me but 1.3 feels more sluggish than 1.2. I did some comparisons and ignition advance looks to have been adjusted significantly in the low rpm range. I know you did this in the interest of knock prevention, but what does it look like on a dyno?
For comparison, here is stock vs 1.2 vs 1.3
#56 | |
Drives: 2013 FRS
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 | FRSTEVE | Software Tuning | 105 | 08-04-2017 05:48 AM |
| anyone trying to use the openflash tablet with forced induction? | FRSTEVE | Software Tuning | 69 | 12-07-2014 05:07 PM |
| Is Openflash tablet detectable? | Boofneenee | Software Tuning | 25 | 05-02-2014 11:03 PM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 09:45 PM |
