#169 | |
Drives: 2015 Mustang GT (on order)
So, based on that logic, running A01C based roms on an A00C car, you will end up with the opposite, 20 degrees TOO MUCH timing between shifts.
#170 | |
Drives: 2013 FRS
#171 | |
http://www.ft86club.com/forums/showthread.php?t=50088
#172 |
In my testing, scaling is defined at the XDF level.
Which is why I think there needs to be different XDFs between A00C and A01C, etc. If I modify the XDF to -30 scaling (how I believe my ECU is actually reading this), then here's the actual running TIR table...which is no bueno
#173 | |
Drives: 2013 FRS
#174 | |
#175 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
man...Shiv can't catch a break. Dude just rolled out some new stuff and within minutes "booooom".
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
#176 | |
| The Following User Says Thank You to jeebus For This Useful Post: | toysub (11-05-2013) |
#178 |
Drives: 2013 FRS
Guys, I'm at sema for the rest of the week. I'll try to make this clear and brief as possible. There is one such thing as a "00C car". The 00C designates the rom type. The rom itself has all the mapping info. This includes scaling info. All our OTS maps are O1C roms. This is why we are able to use only one XDF file to cover all usdm cars regardless of whether they started life with an earlier rom version. We just separate them into 700c, 900c, 00c and 01c classes because the OFT firmware, once installed, doesn't permit you to change rom types. Instead of writing custom firmware, we just approached it by accommodating this restriction by making many versions of the same 01c rom. That said, I'm quite sure the same scaling applies to every car running any of our OTS maps. Perhaps I'm still not explaining this clearly enough. But I hope I am.
#179 | ||
Drives: Toyota 86
Shiv's ZA1J___Cv2.5.xdf is scaled for stock =<A00 ROMs Shiv's ZA1J___Cv2.6.xdf is scaled for A01 ROMs He has stated that all the =<A00 v1.33beta files have been updated to A01 calibration and scaling. So... If you want to modify your existing stock <=A00 ROM, use the v2.5 xdf file for correct TIR scaling; If you want to modify your existing stock A01 ROM or any of the 1.33beta files use the v2.6 xdf file for correct TIR scaling. Quote:
I agree that it would probably be better to have seperate xdf files for =<A00 files and A01 files. |
| The Following 2 Users Say Thank You to ztan For This Useful Post: | autobrz (12-03-2013), Shiv@Openflash (11-05-2013) |
#180 |
Drives: Toyota 86
For those running ZA1J___G ROMs (AU/SA/UK/EUR), I've translated Shiv's v2.4 xdf file appropriate for our use. I've scaled to A01 calibration as that is what I have on my car.
PM me if you want a copy. |
#181 |
Thanks guys. I think I get it now.
#182 |
Drives: FR-S Whiteout
Well whatever the changes in 1.33beta I see some positive results. This is coming from a A01C tune. Immediately after reflashing this time I did not get any hesitation at throttle application as opposed to when I first flashed the 1.2.
The idle dipping and shooting back up when the throttle is completely closed in neutral has returned that was experienced with the stock tune where with the 1.2 and 1.31 it would dwell at 1000rpm for a second before slowly coming to rest at 700rpms. Although it would never dip below the target idle speed like it did on the stock tune. I'm guessing this was not done intentionally, but a side effect or result of whatever changes were made that were not targeted at the idle. Strange, but not a big deal.
Intent > Content
cowardice is the mother of cruelty. |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 | FRSTEVE | Software Tuning | 105 | 08-04-2017 05:48 AM |
| anyone trying to use the openflash tablet with forced induction? | FRSTEVE | Software Tuning | 69 | 12-07-2014 05:07 PM |
| Is Openflash tablet detectable? | Boofneenee | Software Tuning | 25 | 05-02-2014 11:03 PM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 09:45 PM |
