86WORX
Old 12-29-2015, 02:21 PM   #729
Originally Posted by Toyota86.ir View Post
We have ecutek kit and we just need base map of supercharger kit, is it available ? Price?
The CARB tune is $500.
If you need a Delicious tune, then pricing will vary with the options you want.
CSG is a dealer for both.
Toyota86.ir (12-29-2015)
Old 12-29-2015, 05:55 PM   #730
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
E
I can not imagine JR base tune be plug and play without map revision?!!!
I think i should send JR base tune log files to Mike (@moto-east) for final adjusting Afr/timing , ...
The Jackson Racing base tune should not be locked for map revision.
Delicious tune is not good , i will shop from moto-east.
We need two sets of supercharger , me & my friend but we are in process to choosing between HKS and JC.
Toyota86.ir is offline   Reply With Quote
Old 12-29-2015, 06:11 PM   #731
Do CARB tune mean JC calibrated base map?
I will send JR base tune log files to Mike (@moto-east) for adjusting Afr/timing and final tuning.
Delicious tune is not good.
Both tunes are locked, and cannot be edited by Moto East. If you want Moto East to tune your car, then they will need to start with their own calibration.
Old 12-29-2015, 06:20 PM   #732
Toyota86.ir
If they lock their map , then It should be 100% calibrated on all customer's brz but i think It's impossible.
I think they should unlock the map because without map revision we can not get 100% performance.
Old 12-29-2015, 06:33 PM   #733
enivid
enivid's Avatar
Drives: WRB JR BRZED
HRI Tuning is the only etune I know of that doesn't lock his maps.
enivid is offline   Reply With Quote
The Following User Says Thank You to enivid For This Useful Post:
Old 12-29-2015, 06:37 PM   #734
They are not made for 100% performance. No tune is made for 100% peformance for a street car, because 100% performance means running on the 100% ragged edge.
When you tune a race car, e.g. for the 24 hours of LeMans, the simulate the ENTIRE race on an engine dyno, down to the predicted humidity, temperature, and air composition (in a draft, out of a draft), and tune specificly for that.
You cannot get 100% with an e-tune, but you can get a tune that will work under any reasonable condition.
If you want a 100% performance tune, you need to be getting a dyno tune, at your local dyno, while simulating your exact running condition. If you deviate even 1% from that condition, you are no longer at 100%.
Old 12-29-2015, 07:29 PM   #735
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
E
The Jackson Racing Calibration is locked, because that is what is required by CARB in order for the System to be CARB Legal. The calibration is extremely good, and you will not see much more in gains with a custom tune.
Now if you have other modifications, IE. Cat delete, header, cams, etc. Then you would need a full custom tune anyway, so it doesn't really matter.
JDMChris is offline   Reply With Quote
Old 12-29-2015, 07:30 PM   #736
Toyota86.ir
I read Jamesm posts. He is great
Old 12-29-2015, 07:39 PM   #737
Toyota86.ir
The tune is good , OK , i do not say it is not good, i just say the tune will not have the same result in all customers's brz.
For example base map LTFT is zero in JC factory brz but LTFT will not be zero in my gt86 if i use JC base map.
AFR is another example, in JC factory brz the wot afr is in the commanded range but if i use JC map on my gt86 the afr may be alittle out of range.
I just say all base maps need to revise alittle for each car.
Old 12-29-2015, 07:44 PM   #738
Toyota86.ir
You are right , we can not get 100% in etunes and we need dyno for 100% .
My idea about 100% means getting commanded range in my gt86 need map revision because ecu parameters may vary after flashing JC base map on my gt86 .
Old 12-29-2015, 07:50 PM   #739
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
This particular tune that comes with the JRSC Factory Tuned System is a CARB exempt/emissions legal system that can be bolted directly to a factory BRZ/FRS and pass government regulated emissions requirements. This particular tune is optimized for this specific require, but also has been refined through a variety of environmental and performance conditions. It is the most complete tune for its intended application.
Yes, all BRZ/FRS are slightly different, however, every BRZ/FRS has the same exact tune that comes from the factory. Jackson Racing's kit works in the exact same manner.
If you need assistance with your specific setup, please don't hesitate to contact us via PM or e-mail and we'll be happy to assist you.
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
Toyota86.ir (12-30-2015)
Old 12-29-2015, 09:10 PM   #740
The Jackson Racing tune is not a base map. It is a complete tune. No revision is necessary when used as prescribed.
Old 12-29-2015, 09:10 PM   #741
You are right , we can not get 100% in etunes and we *PERFECT, never changing WEATHER* for 100% .
fixed that for you.
Old 12-30-2015, 01:11 AM   #742
Toyota86.ir
Very very good news if JC tune be like factory map because factory map is fix for all cars.
This is hard to believe to me because i had this idea before: "the limits of ecutek technology cause tuners could not make factory like maps"
jackson racing, jrsc, rotrex, supercharger, track
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 04:28 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 03:29 PM
