Old 02-26-2014, 05:42 PM   #407
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by tendogy View Post
Whaaaaaaaaaaaaaaaaat?!?! You got so much crap for the lack of acceleration (relatively speaking) in that video and you didn't want to mention that it was at elevation? So you were only at ~22psi instead of ~24psi; that explains everything.
Do you mean 22psia or 22 psig?
Old 02-26-2014, 05:56 PM   #408
CSG David
CSG David's Avatar
absolute broski.
The Following User Says Thank You to CSG David For This Useful Post:
Calum (02-26-2014)
Old 02-27-2014, 04:01 AM   #409
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Originally Posted by qtwre View Post
Won't a turbo just spin faster to hit the same boost target, regardless of elevation? Oh, but then I guess intake temperatures would go up, losing power.
Touche.
There's a little more to it that seems to be forgotten when people talk about turbos at altitude...
Quite often the boost control setup is designed for a target above atmospheric pressure, and isn't set up to read absolute pressure. (this will be the case with a manual boost controller) What happens in this case is your turbo spins a little faster to create the (same as sea level) pressure to overcome the spring, but atmospheric pressure is lower, and so your absolute pressure at the manifold is lower as well. It's not as big a difference as you have with a supercharger. but it's there.
if your boost control is set up to hit a specific absolute pressure in the manifold, using a map sensor and controlled by the ecu or some other electronic device, then this isn't an issue and your car should be capable of VERY similar horespower numbers at elevation and at sea level. like what Mike mentioned about the BMWs.
Sellout is offline   Reply With Quote
Old 02-27-2014, 04:40 AM   #410
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Originally Posted by jamesm View Post
if you lose power when you go up in elevation on a turbo system (i.e. the turbo can't keep up due to an inability to push the PR required to maintain target boost at that altitude), your turbo is way too small.
this isn't a realistic concern with any of the turbo kits available for this platform.
I don't think it will be an issue with lower boost setups. But PR can have a drastic impact on the power delivery and output of the system. Remember with higher PR comes higher temps, lower efficiency. The lower compressor efficiency increases the amount of drive force the turbine requires, increasing backpressure. Increased backpressure reduces volumetric efficiency and is detrimental to scavenging, this increases pumping losses.
I've seen turbo setups make 30-50whp more just by going to sea level. And it isn't just because of boost. A lot of these turbo setups utilized Absolute pressure for the boost controller. The system as a whole simply maxes out faster with elevation.
The JR system shouldn't have too many issues with running at higher altitude. But with the system so close to max output in stock form, it will probably be closer to maxed out at 4500ft.
Coheed is offline   Reply With Quote
Old 02-27-2014, 08:19 AM   #411
jamesm
You're correct it's not just about being able to hit boost target, but I maintain that f you're seeing you're turbo fall out of its efficiency rage (especially at low boost) due to an altitude change, you simply picked the wrong turbo. Also, as I a stated above it's really a moot point since no one even makes a kit for this car with a turbo small (or maxed out at reasonable boost) enough to warrant this concern.
Old 02-27-2014, 11:41 AM   #412
Not sure if serious..
Old 02-27-2014, 12:30 PM   #413
jamesm
very serious. do you have an example? one may argue avo... but even then i doubt it. unless you live in nepal or something...
Old 02-27-2014, 02:01 PM   #414
Avo and Greddy, to name the most common ones...
This is really easy for us to test, because the CA tracks are all at higher elevation, and we have tons of mountain roads.
Old 02-27-2014, 02:28 PM   #415
jamesm
Evo and Greddy, to name the most common ones...
true... florida guy here. i'd be shocked if either of those kits actually lost power at altitude, but then i don't have any altitude to test this with .
Old 02-28-2014, 10:15 AM   #416
Sellout
Mr. Cranky Pants
Sellout's Avatar
Perspective, wording, blah, blah, etc, etc...
The efficiency change in the compressor that you see from the altitude change is going to happen on any and all compressors. (supercharger included)
The amount of that change is going to be dependent on how much of an altitude change you're talking about, what the compressor map looks like, where in that map you're usually operating, etc.
Obviously, driving from sea level to Denver is going to mean one hell of a change in compressor efficiency, it will also mean there is less dense air to remove heat from your intercooler and less total density in your intake manifold. Atmospheric pressure in Denver is roughly 12psi so you've lost about 2.5 psi right off the bat. Your boost target (10 psi example) is still 24.5 absolute. Your pressure ratio on the compressor map has gone up two ticks to hit 24.5. You're making more heat. You're rejecting less heat. You're going to lose power. How much depends on your mapping. If you're an OEM you may have spent hundreds of hours mapping an ECU to generate the same power at altitude that people get at sea level, and that's probably the real reason why there's not (much) of a change.
WSIR in California is roughly in the 2300' range, so the changes will be less drastic than the Denver comparison, but they will be there.
We can't say it's all in the turbos efficiency, or all in the atmospheric density because there are things that change at damn near ALL points in the system.
If you're losing power because you didn't have enough headroom in your turbo system, then your turbo system is just too damn small to account for the altitude change. 100% accurate. You'll lose power and no amount of mapping changes will bring it back unless you switch to a fuel that needs less air to burn. So if you're on the ragged edge of what you can get out of an AVO or Greddy kit at sea level, then you're kinda fucked when you decide to drive through colorado and get a dyno sheet at every dyno shop you pass...
But if we're being realistic, we'll admit that we've known for a hundred years that going up in altitude means less power. It's always been that way. Unless you spend the time adjusting your tune to make similar power at altitude the way Mercedes Benz and BMW apparently have, it's going to continue to be that way.
The Following 2 Users Say Thank You to Sellout For This Useful Post:
CSG Mike (02-28-2014), Venator (03-06-2014)
Old 02-28-2014, 09:48 PM   #417
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
In other news...
Jackson Racing Engine Oil Cooler Kits are now shipping!
Press Release on Monday.
-Oscar Jr.
Jackson Racing is offline   Reply With Quote
The Following 7 Users Say Thank You to Jackson Racing For This Useful Post:
*LongFella (03-01-2014), CSG Mike (02-28-2014), Mad1723 (02-28-2014), OICU812 (03-01-2014), OjiGeorge (03-01-2014), ramiram1984 (03-01-2014), sklimo (03-06-2014)
Old 02-28-2014, 11:27 PM   #418
tendogy
I had given up hope that you guys would meet the February deadline, and here you are squeaking under the wire! Nice job.
tendogy is offline   Reply With Quote
Old 02-28-2014, 11:44 PM   #419
Today, I discovered, I can fit quite a few boxes in my S2000.
*LongFella (03-01-2014), Kakawate (03-06-2014)
Old 03-03-2014, 11:52 PM   #420
enivid
enivid's Avatar
Drives: WRB JR BRZED
UPS just notified me I have a package from CSG arriving on Wed. Oh what could it be? Feeling sick. Might have to take that day off.
enivid is offline   Reply With Quote
The Following User Says Thank You to enivid For This Useful Post:
*LongFella (03-04-2014)
jackson racing, jrsc, rotrex, supercharger, track
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 04:28 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 03:29 PM
