#281 | |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
At least it does a better job than I can explain with my simple vocabulary... What's not explained well, by Rotrex themselves or the people who sell them, is that the planetary drive is not magic. It doesn't uncouple the impeller from the crank shaft speed and allow the boost to ramp up faster than the other centrifugals on the market. It doesn't spool to full boost early in the RPM band and give you a dyno sheet that looks like a turbo car. If there's more midrange with a Rotrex, it comes from the efficiency of their traction drive and the impeller design (compressor map) itself. Not from earlier boost onset. |
#282 | |
Thupercharged
So I thought the rotrex was a planetary gear system when they introduced it, but no one ever really got in depth about the gear system... As I understand it, its basically a planetary gear system BUT smooth rollers instead of gears ![]() Thats why the non-newtonian fluid is needed, as the fluid plays a part in the drive efficiency in the gearset and which allows the impeller to spin faster under high load than it would normally with a newtonian fluid I could be way off, but its all the info I can find on the net
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#283 | |
Mr. Cranky Pants
#284 | |
Thupercharged
Off to do more research, its not a very widely discussed topic
2013 FRS
#285 | |
Mr. Cranky Pants
Clever marketing. An all wheel drive Porsche pulling a wheelie on a drag-strip only transfers enough torque to the front wheels to make them spin in the air. This is just how the physics of a drivetrain work. The reality is that in order to dynamically accelerate the impeller shaft at a higher rate as needed, something in that drive system absolutely must be adjustable for a different gear ratio. (Think CVT) Otherwise it's just not possible. As for adjustments based on load, the supercharger will never see anymore "load" than what is needed to spin the impeller, and that load isn't going to change from one pull to the next. The real benefit of their drive system is that it's nearly silent. That's pretty much all. I can remember when the Kraftwerks system was being developed for the S2000. There was a whole lot of speculation about Rotrex's wording and what it meant. The general consensus among damn near everyone on S2Ki was that it was going to be magical. The planets were going to align, polar ice would stop melting, the middle east would be peaceful, and a centrifugal supercharger would rival a twin screw for torque delivery. Then the system was finished, and there were a few of us who were not surprised in the least to see that the boost curve and resultant dyno sheet was damn near identical to every other centrifugal. I can't call it snake oil because clearly the traction drive does work, and rotrex doesn't come out and say that it does what everyone on the forums expects it to. You just can't forget that the impeller is tied directly to the crankshaft. As such, if you want 10 psi at 3k rpm, you're going to have more than 10 psi and much warmer air at 6k rpm. Last edited by Sellout; 01-18-2014 at 04:27 PM. |
| The Following User Says Thank You to Sellout For This Useful Post: | Calum (01-18-2014) |
#286 | |
Thupercharged
2013 FRS
#287 |
Drives: 2015 Series.Blue
Yeah, the only real advantage the Rotrex system has is that it's more efficient than using gears (supposedly). Less drive loss meaning it doesn't take as much power from the engine to spin.
Twin screws are notoriously bad about this. |
#288 |
Stig's dark passenger
There are major differences in the overdrive mechanisms between the Vortech superchargers and the Rotrex.
Vortech uses a gear setup where Rotrex uses a planetary type setup. The issue with any gear driven mechanism is noise. In order to combat noise, the gears are designed as helical gears. Helical gears create thrust. This axial thrust takes away from the efficiency of the drive unit. A spur gear would be more efficient, but the noise would be dreadful. Even a typical gear type planetary setup would be very noisy. Enter Rotrex. They came up with a planetary setup that doesn't use gears. It uses roller bearings, so you get the best of both worlds: no noise and no thrust load. Because of the extra efficiency, the gearing can be more aggressive, which gives the Rotrex a huge advantage at lower rpm. The tolerances are so tight between the sun/planet roller and the planet/ring roller that the ring gets squeezed during the manufacturing process in order to fit the planet rollers in the gap. That's the reason for the 'special' fluid. |
#289 | |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#290 | |
Mr. Cranky Pants
That's because it doesn't exist. The advantage is silence and a little less drive-loss as mentioned above.
#291 |
My FR-S has 5 gears
Exactly what I was getting at.
Omar GC
| The Following User Says Thank You to OmarGC For This Useful Post: | Sellout (01-18-2014) |
#292 |
Drives: Honda
How reliable is the CARB tune? Does modify the updated transient timing tables tunes that are related to the direct injection issue?
Forced induction sounds great for this motor, but not when it will impact or accelerate the deterioration of the DI seal. |
#293 | |
#294 |
That Guy
Drives: 2013 asphalt FRS MT
I wonder if the rotrex drive system is designed to slip some at high rpm.
I understand that the differences in low end torque delivery aren't there, I've seen some dynos to. But I wonder if that was a part of the design, to make it slip some at high rpm so it can be spun faster at low rpm without over spinning it. Kinda reminds me of quick bleed down lifters if that is the case. |
| Tags |
| jackson racing, jrsc, rotrex, supercharger, track |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| HKS GT Supercharger (Rotrex) in development! | madfast | Engine, Exhaust, Transmission | 206 | 12-14-2012 04:28 PM |
| Jackson Racing FR-S | Unleashed | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 11-18-2012 03:29 PM |
