Old 11-11-2013, 08:08 PM   #29
simpleisbest
Senior Citizen
Drives: Scion FR-S
No ones mad here.
Just saying there is a difference. That difference is weight.
It's really that simple.
If you are racing in a competitive class, then any opportunity to save a few pounds here and there are sometimes appreciated (they can add up). If you are just modding a car for fun, then it really doesn't matter.
simpleisbest is offline   Reply With Quote
Old 11-11-2013, 08:26 PM   #30
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Originally Posted by simpleisbest View Post
No ones mad here.
If you are racing in a competitive class, then lany opportunity to save a few pounds here and there are sometimes appreciated (they can add up). If you are just modding a car for fun, then it really doesn't matter.
View from this point yes you are right
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 11-13-2013, 12:34 AM   #31
diss7
Drives: AE86, 2x GT86, TE27
Percentage increase over OEM for our 16mm adj rear swaybar are as follows –
Soft – 44%
Med – 89%
Hard – 114%
18mm bar –
Soft – 129%
Med – 199%
Hard – 251%
Email from Whiteline, after I enquired about their rear bars.
diss7 is offline   Reply With Quote
Old 11-13-2013, 08:37 AM   #32
Mikepage
Mikepage's Avatar
Thank you, I will update the first post soon.
o= FR-S =o
Old 11-13-2013, 08:58 AM   #33
ft_sjo
Drives: GT86
Soft – 44%
Med – 89%
Hard – 114%
18mm bar –
Soft – 129%
Med – 199%
Hard – 251%
The problem is, it's all bollocks. When you use those outer holes, you're changing the pick up point for the drop-link, which in turn affects the curve throughout the motion. It can also potentially place a lot of additional/wrong load onto the drop link. For reference, Subaru use the same drop links for 16/18/19 bars, possibly thicker but I haven't bothered checking.
The most reliable way to use these 'adjustable' bars is use the hole closest to OE! Forget the rest!
The Following 2 Users Say Thank You to ft_sjo For This Useful Post:
chanomatik (01-16-2014), Mikepage (11-13-2013)
Old 11-13-2013, 09:28 AM   #34
Mikepage
Mikepage's Avatar
I never thought about this, you bring a good point, I will think about it when will change my sway bar.
It's difficult to know how the car will react whit a bigger sway bar this is why they put holes to give the possibility to correct the handling depend on the setup.
I try to mean, it's maybe a little bit difficult to know exactly the bar we want, example : to get more oversteer, not to much and I need to bought a bar with only one hole in the perfect spot according to my setup.
o= FR-S =o
Old 11-13-2013, 03:09 PM   #35
diss7
You get adjustable end links. And, if you have their LCAs you have multiple mounting point options.
I'm not entirely following what you're actually talking about, but would guess that's what these other adjustments are for..?
The Following User Says Thank You to diss7 For This Useful Post:
Old 11-13-2013, 03:40 PM   #36
Racecomp Engineering
Eibach, Hotchkis, and our RCE bars are hollow. Not sure on anyone else.
Our 25mm front hollow bar is roughly equal to a 22mm solid.
Our 19mm rear hollow bar is roughly equal to a 16mm solid.
Both would weigh less than a solid bar of similar stiffness.
I can post the equations if you're curious but it doesn't do much good if you don't have the inner diameter of the bar tube.
- Andy
Racecomp Engineering is online now   Reply With Quote
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
Mikepage (11-13-2013), RehabJeff86 (01-12-2014)
Old 11-16-2013, 06:50 PM   #37
Mikepage
Mikepage's Avatar
First post unpdated!
o= FR-S =o
Old 11-16-2013, 07:19 PM   #38
FRSGeek
Drives: UltraMarine 6 Spd MT
Is it me, or the % (percents) the mfgs are spouting of +XX% or +YYY% increase are not the same for stock?
What are the values for stock and that should be in the list, pointing out those that are being *cough* slightly inaccurate as to their rate increases.
'13 Ultra Marine 6MT:AVO Stg 1.5 T, Berk Tech Cat'd FP, Perrin OP & 2.5" cat back, WinMax W3F/W2R, 18x8.5et44 Rota, 245/35R18's, Drift-Office EcuTek Tune, Cusco Strt Twr & Rear brace and Grimspeed hood struts.
FRSGeek is offline   Reply With Quote
Old 01-11-2014, 05:02 PM   #39
Mikepage
Mikepage's Avatar
Sway bar option list
First post updated for whiteline spec!
o= FR-S =o
Old 01-12-2014, 01:02 PM   #40
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
I recently installed SPL Pro rear LCA with end links, was able to play with the 3 different mounting point for the end links on the LCA with OEM sway bars at Laguna Seca, each mouting point makes drastic change on oversteering - more stiffer more oversteer, im pleased with the softest setting resembling OEM driving dynamic and clocked the fastest time.
Long story short - OEM sways are awesome!!
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
The Following 2 Users Say Thank You to RehabJeff86 For This Useful Post:
2013GTRNate (02-21-2016), Mikepage (01-12-2014)
Old 01-13-2014, 11:29 PM   #41
Mikepage
Mikepage's Avatar
Nice setup but expensive
I placed an order on the whiteline package, rear 16mm sway bar with brace and link.
o= FR-S =o
Old 01-13-2014, 11:34 PM   #42
Freshfrs86
Freshfrs86's Avatar
Drives: Scion FRS
I've been looking for something like this! Good stuff!
Freshfrs86 is offline   Reply With Quote
Search this Thread:
Advanced Search
New F/I option SnapOv3st3r Forced Induction 41 03-24-2013 10:44 PM
Leather Option. l0aded Scion FR-S / Toyota 86 GT86 General Forum 20 03-02-2013 09:59 PM
Diffuser Option on the BRZ Markone AUSTRALIA 25 01-14-2013 04:21 AM
Scion FR-S Option list Crashoverride Scion FR-S / Toyota 86 GT86 General Forum 38 04-18-2012 04:37 PM
Considering this as another option 2011 WRX Draco233 Other Vehicles & General Automotive Discussions 5 04-01-2012 11:01 PM
