#15 |
Drives: Ultramarine FR-S (MT)
#16 |
Drives: Scion FR-S 2013 Raven
First post updated!
o= FR-S =o |
#17 |
SoCal86
Drives: '13 Whiteout FR-S
Don't forget you can use
2008+ STI rear sways which are 19mm Or 2010+ WRX which is 16mm
.: SUPER KAWAII :. .: BUBSQUAD :. .: LivinLow :. .: FRS86 :. |
#18 |
The stock sway bars are one of the best suspension parts on this car and I will not be touching it at all. I don't see many aftermarket ones that will beat it.
| The Following 3 Users Say Thank You to husker741 For This Useful Post: |
#19 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
#20 |
Drives: Some kind of Subaru
#21 |
Can you explain your point?
o= FR-S =o |
#22 |
Just scored a 19mm Perrin rear STI swaybar with end links for $150!
#23 | |
Senior Citizen
Drives: Scion FR-S
![]() Just a suggestion: You might want to list either HOLLOW or SOLID. The stiffness of the bar will vary greatly depending whether hollow or solid. Without knowing that, it'll be tough to gauge stiffness with diameter alone. |
#24 |
Drives: FRS(sold), AP2, R35, FJC, ED9
is the oem hollow or solid?
#25 |
Senior Citizen
Drives: Scion FR-S
OEM is solid
#26 |
Sway bar option list
I will try to update the list soon concerning hollow and solid informations.
o= FR-S =o Last edited by Mikepage; 11-11-2013 at 03:54 PM. |
| The Following 2 Users Say Thank You to Mikepage For This Useful Post: | chanomatik (01-16-2014), nemes (11-11-2013) |
#27 | |
Senior Citizen
Drives: Scion FR-S
No difference? Please do enlighten us. Hollow is softer per OD mm vs solid. You can have a hollow and a solid of equal stiffness, but in such cases the hollow will typically have a larger OD and weigh a couple of pounds less. Hollow bars are typically designed to provide a certain level of stiffness while trying to save some weight vs solid. Calculations exists on the differences all over the internet. If you are comparing bars based on diameter, the detail of it being solid or hollow DOES MATTER. Last edited by simpleisbest; 11-11-2013 at 03:21 PM. |
#28 | |
we are here to learn, I don't have any problems to say when am wrong.Could you show to us? Then you will probably inform users correctly. I want to understand what is the difference between an solid and an hollow bar. I don't think it's enough big to really see the difference on the street and also maybe on a race track. I mean the difference between the 2 bar types. I am pretty sure if you try both, hollow and rigid, you will probably not see any differences. It's only about how much the bar are more stiffness then the oem. Example, if you have the same % of stiffness between an hollow and an rigid bar then this is the same thing. We say the same thing ![]() I just want to say, look at the % of stiffness you want to add on your car and make your choice from this.
o= FR-S =o Last edited by Mikepage; 11-11-2013 at 06:39 PM. |
| New F/I option | SnapOv3st3r | Forced Induction | 41 | 03-24-2013 10:44 PM |
| Leather Option. | l0aded | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 03-02-2013 09:59 PM |
| Diffuser Option on the BRZ | Markone | AUSTRALIA | 25 | 01-14-2013 04:21 AM |
| Scion FR-S Option list | Crashoverride | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 04-18-2012 04:37 PM |
| Considering this as another option 2011 WRX | Draco233 | Other Vehicles & General Automotive Discussions | 5 | 04-01-2012 11:01 PM |
