#43 |
Drives: GT86/GTR R35
#44 |
Drives: 2023 WRB BRZ (MT)
awesome. thats about what i was hoping. also i saw something about lil 400 HP. is that what the engine is making with all this or was that something different?
#45 |
#46 |
#47 |
IT WILL BE LESS THEN THE HP BY 15%
| The Following User Says Thank You to SUB-ZERO For This Useful Post: | lbroskee (10-26-2013) |
#48 |
is their any ecu for this car other then ecutek ?
#49 |
Drives: 2013 Raven 86
#50 |
Drives: Crv,Legacy-ultramarine frs
[QUOTE=Bingbong;1294667]All my thumbs is up man..just thinking about the trans how long the power 550hp ca handle this whats the upgrade? if i have 5 thumbs ill put it up too..goodluck..:-D
| The Following User Says Thank You to Bingbong For This Useful Post: | SUB-ZERO (10-26-2013) |
#52 |
Drives: Pegasus White 86GTS
Nice build. Are you going to upgrade your engine mounts?
Pegasus White 6MT got it. :happy0180:
| The Following User Says Thank You to armythug For This Useful Post: | SUB-ZERO (10-26-2013) |
#53 | |
I went with the Hydra system for my car. It has a LOT more to offer, especially for big HP. It's a standalone system, and also has an associated methanol system called Hydramist (made by Aquamist). Mine will be installed and tuned in a couple weeks. I'll be doing a build thread. |
| The Following User Says Thank You to mike the snake For This Useful Post: | lbroskee (10-26-2013) |
#54 | |
#55 |
Drives: 85 corolla gts
1800 for proper engine management is a fair price. If anything it is actually on the cheap side. I would personally prefer to use a full standalone over the factory ecu for certain cars. A standalone can bring a lot to the table. If the factory ecu had more available inputs and outputs it would be nice. There are a lot of variables I would like to be able to log, with out having to add a secondary logger. These are just my opinions. Also Hydra is a good system and I would definitely recommend checking it out.
#56 |
Compared to Ecutek, which is $700-$800, it's about a grand more, and it's a true standalone. for me, that meant that I could set the stock ECU aside until I put the car back to stock when/if I decide to sell the car or need to smog it.
I'm also going for more power than just 91 gas can offer, with WMI. The fact that the Hydra has a sister WMI system, Hydramist (made by aquamist), means that it's all going to work together and be much easier to install and tune, almost plug and play. I saw thread or vid of someone who installed an Aquamist WMI system with Ecutek, and it looked like a wiring nightmare, and still wasn't dialed in. The guy was working with Aquamist still trying to get it to work, and the wiring jumble I saw scared me a LOT. Also, I didn't want to use Ecutek, and Openflash doesn't support WMI, so I was limited in choices. My tuner is familiar with Hydra and has tuned with it before, so that weighed in on my decision as well. The Hydra I was told is better for BIG HP and for racing applications, where more exact control is required. |
| Frs300 Fa20club built motor and turbo build | Frs300 | Member's Car Journals | 32 | 01-18-2014 06:27 AM |
| Worlds Fastest Turbo BRZ gets faster! Accelerated Performance Built - Visconti Tuned | Visconti | Forced Induction | 697 | 11-13-2013 07:18 PM |
| Crawford Limited Turbo BRZ - built motor | Mrqb22 | Forced Induction | 8 | 11-11-2013 02:34 PM |
| What is the best turbo for a fully built engine scion frs | SUB-ZERO | Forced Induction | 41 | 09-18-2013 07:41 PM |
| Will FR-S ever have a aftermarket turbo built? | docyzx | Forced Induction | 50 | 07-19-2012 01:20 AM |
