Old 06-23-2015, 11:38 PM   #197
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
^ just get a stronger after market axle, don't get OEM replacement
or u can get that Subaru BRZ tS axle if u have the $$$ to blow.
Old 06-23-2015, 11:51 PM   #198
wheelhaus
wheelhaus's Avatar
Originally Posted by AreteAuto View Post
Another piece of advice. Don't use lowering springs like I did. They increase the angle and don't provide much more resistance to axle travel than the stock springs. If you go lower, use coils to prevent the axles from reaching as extreme of angles.
This isn't exactly wrong, just a little misleading. Coilovers will not magically save your axles. Springs and coils both do exactly the same thing in regards to lowering by placing the wheel deeper into it's travel. Neither change anything about the suspension geometry, it still follows the same path, and the axle still follows the same deflection. The issue stems from deep lowering. Both springs and coilovers are capable of lowering the car too much, adversely affecting shaft angle. This part we can all agree on.
The only beneficial thing coilovers might offer over springs (and the point I believe you're trying to make) is stiffness; under extreme compression a coilover might theoretically resist bottoming a little more. This is extremely difficult to prove however, as coilovers would need to be individually measured for spring stiffness, damper settings, eye to eye, stroke, bump stop thickness/durometer, etc. IMO it's too many variables to lay a blanket statement.
wheelhaus is offline   Reply With Quote
The Following 3 Users Say Thank You to wheelhaus For This Useful Post:
AreteAuto (07-27-2015), DAEMANO (07-07-2017), Ultramaroon (06-24-2015)
Old 06-24-2015, 03:29 AM   #199
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Originally Posted by shezzdog View Post
so currently whats the best way to solve this, stronger cv joints? getting replacement ones that will break again seems like a waste of time.
i've only lowered recently and want to prevent this from happening, car isn't tracked and is an auto so no clutch dumping.
also 2012 model, will 13' 14' axles fit? (cant imagine it would be fine) car has 40,000 miles on it.
There is no 2012 model...
Just keep using your current axles under you can audible hear a click from a stand still to moving. That will be the sign that it's starting to fail
Look into the DSS axles, they have a different designed cv joint that allows more leeway in the angles and it's rated up to 600hp
Sent from my SM-G900V using Tapatalk
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 06-24-2015, 08:35 AM   #200
shezzdog
Drives: 86
its stamped 2012 here in aus. first model.
looking into these, but from what ive seen doesnt look too promising.
shezzdog is offline   Reply With Quote
Old 06-24-2015, 05:14 PM   #201
strat61caster
strat61caster's Avatar
Other countries don't ascribe to the North American strategy of releasing next years car many months before the year begins ('13 FRS/BRZ were available in May 2012). There are GT86's and BRZ's sold as 2012 model year cars in other countries (Europe, Asia, Australia etc.).
@shezzdog to my knowledge the axles have been unchanged from start of production.
Edit: And yes, no guaranteed solution yet, some people save money and just keep spares in the garage taken from wrecked cars or whatever.
ineedyourdiddly
Old 07-27-2015, 12:43 AM   #202
AreteAuto
Racing Enthusiast
AreteAuto's Avatar
Drives: Bone stock 2019 BRZ manual
Yes, that is what I was attempting to say, thank you for expounding.
“$20 per diddle? I can diddle myself for free and do a fine job”
AreteAuto is offline   Reply With Quote
Old 07-27-2015, 01:38 AM   #203
stugray
Drives: 2013 GBS BRZ Limited
You guys constantly freak me out.
Isnt this a little more correct?:
The only beneficial thing aftermarket coilovers might offer over OEM coilovers (and the point I believe you're trying to make) is stiffness; under extreme compression an aftermarket coilover (specifically engineered for lowering) might theoretically resist bottoming a little more.
Stock "Coilovers" ARE "Coilovers".......
Old 07-27-2015, 03:57 AM   #204
Aztec
Aztec's Avatar
Unrelated to whatever the topic has gotten off to.
If people are hearing a click noise from either rear end when the drive train is engaged or disengaged it's actually just the axle nut. Replace and retorque to spec and noise is completely gone. This is a common issue with subarus
NEW CAR!🚨🏎️⛽
Old 07-28-2015, 10:01 AM   #205
wheelhaus
wheelhaus's Avatar
You're absolutely and especially technically correct, but the term "coilovers" in the culture IMO has always generally referred to aftermarket coilovers.
The Following 2 Users Say Thank You to wheelhaus For This Useful Post:
smg1138 (06-27-2017), stugray (07-28-2015)
Old 01-01-2016, 03:56 AM   #206
DAEMANO
Time Traveller
Is there a DIY for changing these?
Found it:
http://www.ft86club.com/forums/showthread.php?t=45949
Old 07-01-2016, 02:58 PM   #207
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Well, guess I'm back in this club !
My left axle just begin clicking... I'll re-torque the nut and I will hope.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 07-01-2016, 03:25 PM   #208
stevemp5
Drives: scion fr-s
the car must be on the ground or in the air when I re-torque the nuts?
stevemp5 is offline   Reply With Quote
Old 07-01-2016, 05:22 PM   #209
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I did it with the car in the air. I don't think it matters.
Old 07-02-2016, 10:29 AM   #210
trueno86power
[||•]=(86)=[•||]
I've re-torque the axle nut over the spec (Spec 140 ft-lbs - Torque to app 160-170 ft-lbs) and it don't make any noise now. I know this will be temporary... I hope not but
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
more money than brains, stance bro
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) -- General Topics 48 08-09-2013 07:34 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
