#183 | ||
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
#184 | |
#185 |
@CSG Mike interesting - this happens even with no load? Car was up in the air on hoist. Thought the droop would just keep everything at balance.
I'll try again next time with endlinks off Sent from my SGH-I317M using Tapatalk
#186 |
Drives: FR-S Whiteout
Check that the preload on the spring is even too before you try again.
Intent > Content
cowardice is the mother of cruelty. |
#187 |
@solidONE yeah I'll remove the spring load and endlinks. Thanks!
#188 |
@CSG Mike so I undid the preload and swaybar connection to the rear, still felt that driver side was easier to compress but rebound seemed to come out at the same rate. Gave ohlins a call and they mentioned that at low speeds it is hard to get them to exhibit their characteristics vs. at speed on the road. Any thoughts? Thanks!
#189 |
Did you happen to ask whether they check each damper for uniformity in the damping range before they leave the factory?
Intent > Content
#190 |
| The Following User Says Thank You to 1Cor10:23 For This Useful Post: | solidONE (08-04-2015) |
#191 | |
Drives: '13 BRZ Ltd
If these ride as well on the BRZ I would seriously consider them. |
#192 | |
#193 | |
Intent > Content
#194 | |
A little more travel on the Ohlins would have been nice. It's possible to adjust the KW's to ride really well with a little more ride height and turning down the rebound. But for our "usual" set-ups for both cars they both still rode pretty similarly (and pretty well I'd say given 400 and 450 lbs/in springs). - Andrew |
#195 |
Drives: '22 BRZ
So does anyone know why Ohlins dropped their spring rates so much for the kits without top hats (MP20)? They dropped to frankly useless (for anything but street driving) 228lb/in front & 171lb/in rear
Also, I assume the MI20 kit (with tophats) still has the normal 350lb/in springs front/rear? |
#196 |
Drives: GT86 Cosworth
I have ordered a set of the new MI20 which are 7kg/mm front and 6kg/mm rear.
I WILL be swapping the springs front to back (or getting new springs) Not idea about the mp20. That should be called Öhlins Road. |
| The Following User Says Thank You to ajc209 For This Useful Post: | DocWalt (11-06-2015) |
| ohlins road and track shock absorbers | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 11-11-2014 06:00 AM |
| >> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! | Circuit Motorsports | Brakes, Suspension, Chassis | 90 | 08-16-2013 01:39 PM |
| Ohlins Road & Track Coilovers - IN STOCK!!! | RallySport Direct | Brakes, Suspension, Chassis | 7 | 05-28-2013 05:11 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| Ohlins Road & Track Subaru BRZ and Scion FR-S | HP Autowerks | Brakes, Suspension, Chassis | 0 | 04-24-2013 04:27 PM |
