#43 | |
Drives: RX-7 / BRZ
#44 | |
Drives: brz
Do you guys have any numbers for the 3" intake besides from your old intake shoot out thread? Would like to know how this performs vs the intake that requires no tune. Any pictures and dyno's? |
#45 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
I was about to sell my TRD intake because I can't run an Intake in C-stock...
But after driving with the stock intake for a week or so, I decided to reinstall the TRD intake today. I just like it that much more especially for daily driving. It has a much better note, better throttle response, but not really much more power. I've done a LOT of fiddling with intakes over the years with N/A Subaru's, and this is the best aftermarket intake (next to maybe the original Cobb 2.5RS intake) that I've seen for an N/A Subaru motor. The only thing IMO that it needs is a better designed snorkel to match the airbox to possibly gain more power at high speeds with actual induction. |
#46 | |
Drives: Mazdarati
The foam seal now is 1.5" thick open cell packing out of the UniChip box, I just cut it to fit the area with a opening to match the snorkel hole. Then I just put it in-between the air box and radiator support. Works, but being open cell water will be an issue. What I plan on doing is making a air guide out of ABS Plastic sheet and heat / vacuum forming it to shape over a MDF form. I will cut ot the opening and then use some closed cell weather strip to seal it to the air box with a bracket to mount it to the radiator support. I will post more on this air guide later as a DIY post. TRD should of just extended the lip (where the snorkel fits to) out through the radiator support.....
| The Following User Says Thank You to IceFyre13th For This Useful Post: | Turdinator (10-09-2013) |
#47 | |
| The Following User Says Thank You to PERRIN For This Useful Post: | Turdinator (10-09-2013) |
#48 | |
Seņor Member
1974 TA22 Celica
2013 86 GT |
#49 |
Drives: Mazdarati
Sure will........
#50 |
Drives: sexy
K&N intake.. the tube has an insulated mount inside the airbox.... had mine on for a week with no problems. Getting a full tune in a few weeks.
#51 |
Drives: 2013 Scion FR-S in Ultramarine
Not adding anything to the thread other than I am using an Injen intake (metal) and I have ZERO issues with it. No errors of any kind.
Currently driving a Sprintex Supercharged FR-S in Ultramarine with an Invidia N1 Catback with Catless Front Pipe, Invidia Over Pipe, Injen Catless 4:1 EL Headers, Perrin Aluminum Drive Pulley & Driveshaft Shop Aluminum Driveshaft. Also, looking to upgrade wheels someday to Enkei PF01's (17x8's).
#52 | |
Drives: Matte Black STI
Here is what we last tested and tuned, creating Stage 2 and Stage 3 tunes. (it will be on the blog soon too). -Retuned FR-S with 2.5" headerback system with cat, stock header, and Stock Intake. (Creating a Stage 2 tune) -Retuned FR-S with 2.5" headerback system with cat, stock header PERRIN 2.75" Intake. (Creating proper MAF calibration) -Retuned FR-S with 2.5" headerback system with cat, stock header, and PERRIN 3.0" Intake. (Creating proper MAF calibration) This created our final Stage 2 Tune with all three intakes as an option. Using Stage 2 Tune: -Dynoed FR-S with 3.0" headerback system with cat, stock header, and Stock Intake. -Dynoed FR-S with 3.0" headerback system with cat, stock header, and PERRIN 3.0" Intake and proper MAF calibration. -Retuned FR-S with 3.0" headerback system with cat, stock header, and PERRIN 3.0" Intake. From all this we created a "Stage 3" tune for all three intakes. Most of the gains along the way are minor here and there, but are very good from start to finish. Comparing the gains over a 2.5" system, its completely worth going to 3.0" over the 2.5". Same could be said for the 3.0" Intake (if you have a way to tune for it). Here are a couple of the graphs. First one is on a stock FR-S with stock tune. We replaced the stock air box with the 3.0" intake and ONLY change the MAF curve in the ECU. ![]() Then this is a graph showing the Stage 2 tune (2.5" headerback) with a PERRIN 2.75" intake, then we swaped it for the 3.0" and change ONLY the MAF curve in the ECU. We have others, but these are a good start! With the last run of NA tuning we did we are pretty sure we hit the wall with gains. We even threw on our header we made (catless) and we could get a few HP here and there, but nothing crazy. I was really hoping to hit 200WHP, but we were not able to on our 92oct fuel. Last edited by PERRIN_Jeff; 10-16-2013 at 12:45 PM. |
#53 |
It's the Mad Cow
Great write up.
I have to say trying to read what Sosick had to say made me actually believe he was So Sick he couldn't take the time to write out his replies completely... even though he made 4 or 5 of them in a row. L33t Speak! So here is a question for you then, what about the AirRaid? Its plastic/composite. Wouldn't that solve your requirement?
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L |
#54 |
Drives: Mazdarati
Probably, but the TRD is working out great so far.........been messing with the UniChip "tunes" and found that 92 Octane, less fuel, standard timing seems the best for MPG, 92 Octane, Standard fuel, advanced tuning, seems best for power.
AND NO MORE CEL!!!! But this testing has been done on a badly calibrated "butt dyno".........LOL I am still waiting on a few parts before I make the new "inlet".......so far the foam seal is holding up.
| Tags |
| aluminum, intake, maf, plastic, trd |
| Metallic buzz over 4000 rpm? | Ingen | Issues | Warranty | Recalls / TSB | 37 | 11-21-2017 02:51 PM |
| Strange metallic rattle at around 3-4k rpm. | Brett | Issues | Warranty | Recalls / TSB | 17 | 11-08-2013 04:11 PM |
| True Metallic Plasti Dip | BeRZed | Cosmetic Modification (Interior/Exterior/Lighting) | 29 | 07-08-2013 03:30 AM |
| Green Metallic Vinyl Help | Sivtec | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 04-17-2013 09:12 PM |
| Metallic based tint | DSOmegaX | BRZ First-Gen (2012+) -- General Topics | 11 | 08-26-2012 03:15 PM |
