#29 |
Drives: FRS
| The Following 2 Users Say Thank You to wootwoot For This Useful Post: | Dimman (10-08-2013), fuddbutter (10-08-2013) |
#30 |
Seņor Member
Good thread. I like the information put forward and that you haven't named names. I agree with others that it would have been good to test the metalic intake with it electrically insulated to isolate that as the issue.
@PERRIN_Jeff I'm also interested in the larger intake...
1974 TA22 Celica
2013 86 GT |
#31 | |
fastest frs in sbg
Drives: sick ass ultramarine frs
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold 2014 firestorm frs |
#32 | |
Drives: Mazdarati
Lets say the engine needs 500 CFM, no matter what, all the time, never idles, never changes speed, never dose anything but run at half throttle all the time with no load. Also assume the engine is mounted on an engine stand while running......no bends or turns needed to get to the throttle body, a perfect straight shot. This would be the only time you could design an intake with no turbulence and flow exactly what you need, in this example 500 CFM. No bends to other things that could change air flow direction and make turbulent air....easy to do. Unfortunately, our engine is in a vehicle. It has to run slow, and fast, and has variring loads that dynamically changes the CFM (better add what CFM is, Cubic Feet Per Minute). Flow rate at idle could be 20 CFM, under wide open throttle, 1200 CFM.....and every other flow rate in between. We also have to bend the tubes from one place to another, every bend, twist, turn causes some type of turbulence at a given CFM. Sometimes the turbulence is nothing to worry about, sometimes its real bad.....all depends on the flow rate at the given time in the certain location through the tube. I added a flow straightener into my design in an attempt to reduce the effects of turbulence in the intake tube. It had to be "tuned" to the right length and size of openings (I used a honey comb version) to give me the best no turbulent flow possible........this made most of the turbulence a "non-issue" for only about 60% of the full range of flow rate the engine actually can do. The other 40%, either not that bad or worse than no straightener at all......all about compromise, what seemed to work best was what I use based upon a flow simulation (sorry, I do not have a lab to test the real thing or the flow bench that could). Example, the TRD intake has no flow straighteners, but the factory air box dose.........why, those engineers tested and found out what worked best (but not perfect) for each of those designs, one needed them the other did not. See my post above, I tested the ground theory in a different way, yet still got the screwed up MAF, STFT, and LTFT readings.......just by grounding the MAF sensors mounting tabs......while not the same method as you said, the same end result.
#33 | |
Drives: Mazdarati
Sorry if it make no sense to you, but it is what it is........if my MAF is grounded by the tabs my car runs like ![]() If any intake manufacture wants to test my car for this problem they can, but be close to me or pay for my trip to get to them. It maybe something I don't see, it could be something unique to my FR-S, hell it could be ancient aliens...... ![]() ![]()
#34 |
Drives: 2013 Rocketbunny GT86
#35 |
#36 |
Drives: beater
So you cracked open your MAF to see that the ground is attached to the metal mounting tabs then? Pretty sure this is not true... The MAF uses a dedicated ground wire in the harness and it's one of the five pins.
#37 |
Drives: Attitude
I don't mean to be rude, but it took you $1000 to figure out that polymer was less thermally conductive than metal?
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | King Tut (10-08-2013) |
#38 |
#39 |
Drives: Mazdarati
Multimeter on resistance, connect to tab, touch pins one by one.......guess what it tells you.
#40 | |
Drives: Mazdarati
| The Following User Says Thank You to IceFyre13th For This Useful Post: | Cross (10-16-2013) |
#41 |
Drives: FRS
| The Following 2 Users Say Thank You to wootwoot For This Useful Post: | fuddbutter (10-08-2013), IceFyre13th (10-08-2013) |
#42 |
Potato Farmer
Drives: #SLOBRZ
I don't know what i like more about this thread, the informative posts by the OP who has done a great job.
Or the slackjaw yokels that keep chiming in with misguided comments.. Keep up the good work all of you
Something something butter..
www.vic86brzclub.com |
| The Following User Says Thank You to fuddbutter For This Useful Post: | IceFyre13th (10-09-2013) |
| Tags |
| aluminum, intake, maf, plastic, trd |
| Metallic buzz over 4000 rpm? | Ingen | Issues | Warranty | Recalls / TSB | 37 | 11-21-2017 02:51 PM |
| Strange metallic rattle at around 3-4k rpm. | Brett | Issues | Warranty | Recalls / TSB | 17 | 11-08-2013 04:11 PM |
| True Metallic Plasti Dip | BeRZed | Cosmetic Modification (Interior/Exterior/Lighting) | 29 | 07-08-2013 03:30 AM |
| Green Metallic Vinyl Help | Sivtec | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 04-17-2013 09:12 PM |
| Metallic based tint | DSOmegaX | BRZ First-Gen (2012+) -- General Topics | 11 | 08-26-2012 03:15 PM |
