#15 | |
Original 2013 Owner
Drives: 13 BRZ, Galaxy Blue Silica
Second, those MPG gains are huge! I'm definitely a sucker for MPG. Why do you think this is? Is this something that is exclusive to the TRD intake because of the larger filter surface area?
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα |
#16 | |
Drives: Mazdarati
STFT= Short term fuel trim LTFT= Long term fuel trim Why do I think the gas mileage is better, the engineers who designed the TRD intake have vast amounts of money and time to do it right.....not to mention the equipment / tools to test and research the results......
#17 |
Drives: Matte Black STI
Sorry for the long post, and while this may help competitor intake sell, its important to say. Also to the OP, I am not trying to argue just point out my own findings over the years.
First variable is your Unichip. Where are the correction factors programmed? Meaning, during Unichips tuning, did they see your intake running 10% rich under full throttle, then they removed 10% across the board? Or did they only change the correction where it was different? During our testing and tuning of cars and different intakes, I have NEVER seen one that has the same correction needed at low RPM, Mid RPM and high RPM. If the Unichip was tuned for the intake you have, then for 100% you would NEVER get CEL. My guess is that it wasn't properly calibrated. Grounding Concerns In my years of making and playing with intakes, weather raw, powdercoated, plastic aluminum or steel, I have NEVER seen them being metal and grounding out cause anything. On this car specifically we tested a separate MAF housing connected to a silicone coupler (fully isolated MAF). This allowed us to test things quickly. After the design was settled, the solid "RAW" piece was bolted to the car and it performed the same way, indicated by the AFR under full throttle and trims at light load. The MAF sensor is grounded internally which connects back to the chassis. Even the signal wire is shielded by the ground. IF the flange actually touches the circuit inside it HAS to be grounded to it. Even then it won't matter as its all the same ground. If anything this will help make for a better clearer signal. I can say for 100% that the intake being grounded out, isn't an issue. Intakes and "Turbulance" The most important thing to understand is ALL INTAKES HAVE "TURBULENCE". Even the stock air box isn't perfect and it requires a specific calibration for the box. Subaru has used the same basic MAF housing since 2008. It's plastic, has an ID of 2.75", and has air straighteners, yet both the 08 WRX's and BRZ have different MAF curves. This is because air is entering them slightly different and have different curves after the MAF. This all affects how they work. During all our testing we made a MAF housing like you mentioned and it was VERY VERY lean. In fact we have made this same housing (2.75"ID) on both the STI and BRZ and in both case they cause the car to run very lean. These were both short ram types without bends in front of them eliminating other variables to start with. I made an adjustable MAF housing just to be able to test different sizes on the fly and In all situations, I found that in order to run the car safely and as close to the same AFR as stock it needs to be much smaller. The other factor is the bends. Tighter bends, bigger bends and how close they are to the MAF affect the AFR and in different parts of the RPM. There is a reason why our intake is the way it is. It doesn't throw CEL's, the trims are in line with what we want, and it make some power. Intakes NEED a Tune Far too often do I hear intakes are all the same. I hate hearing that as that is not the case at all. Really what this comes down to is that a lot of intakes require a tune and some should have a tune and very few don't need a tune. Technically even our intake needs a tune to have it match the OEM's EXACT AFR curve. But it doesn't NEED a tune as the changes to the AFR are not enough to cause a CEL, or cause a loss in power. I feel 100% confident that our intake with the stock tune runs safe, makes power and NEVER throws a CEL. For those looking to make the maximum power (versus just a little HP and some cool sounds) the only way to get that is by tuning your car to your intake. We know that there are customers who just want a good bolt on and don't want a tune, so we made our normal intake. Then there are the guys who want the most power and understand they need a tune, which is why we made our 3" intake system. So before everyone starts freaking out about intakes, you need to know more about the intake you are using. - Does is throw a CEL? If so, which one? - If its a P0172 then its a good chance that it NEEDS a tune. - Does it run lean under full throttle? - If you have a tune for an intake and you get a CEL (related to AFR or intake) then the tune isn't calibrated properly for the intake. - If designed properly HEAT isn't an issue. Even if the metal tube is 200F the actual air that touches this and heats up isn't going to heat up anywhere near 200F, and even then is a such a tiny amount it doesn't effect HP. - Metal vs plastic doesn't have an affect on the grounding of the sensor. -Does it have proven HP with Proven AFR curves? Hopefully this helps everyone with choosing an intake and while it would be great if it was ours, that is not the purpose of the post. This is a post for everyone to help understand intakes better. Last edited by PERRIN_Jeff; 10-07-2013 at 05:49 PM. Reason: Written after post #1. Some things already said. |
| The Following 21 Users Say Thank You to PERRIN_Jeff For This Useful Post: | 20valvewynn83 (10-19-2013), autobrz (10-07-2013), Batman (10-09-2013), boxer 2.5 (10-09-2013), Chee-Hu (10-07-2013), Cjymiller (10-07-2013), CK_Bladesmith (10-07-2013), Cross (10-16-2013), Fast_Freddy (10-07-2013), FR-Sizzle (10-09-2013), IceFyre13th (10-07-2013), JPxM0Dz (10-07-2013), King Tut (10-08-2013), lazyluka (10-08-2013), PERRIN (10-07-2013), Rayme (10-07-2013), SkullWorks (10-10-2013), sosick (10-07-2013), SubiePig (10-07-2013), Turdinator (10-07-2013), UncleFester (10-07-2013) |
#18 | |
#19 | |
#20 | ||||
Drives: Mazdarati
@PERRIN_Jeff First, Thank you for your insight........I will confirm it was not yours, because you took the time to help me and others get to the bottom of the issue I brought up.
I did remove the UniChip from my car, as I stated in the first post....I should have been more clearer than saying "it ran worse".......the same wild MAF readings and bad LTFT and STST happened when it was off. The main issue while off was how bad it idled and accelerated, these issues were corrected with my custom tune the first time. Quote:
I can say that even if it were a ground connection as well, even though they are both ground this can sill cause what is known as a ground loop that can make electronics "freak out" ((look what a ground loop can do to audio circuits in car stereo, (one of my first engineering jobs was in car audio)). So not in all cases would this "help make for a better clearer signal". Most times ground loops cause bigger issues than "star" or a single point grounding a system. I do not doubt your findings though, my vehicle is not the same one you tested on and there very well could be other variables that make the issue I found more apparent. If you were close to me I would volunteer my car for you to prove or dis-prove my claim. I am open to the possibility what I perceive as the issue is wrong. Quote:
I appreciate the additional information you provided on the testing of your intake. I actually learned why the original intake was designed the way it was now. Quote:
My car is not the same is your car, not built the same time yours was, not the same color, might not have the same mods......etc. etc.... ![]() The only thing I did find was when either my metallic intake, or the first metallic one I bought, and saw where the paint had rubbed through the mounting point effectively grounding the MAF sensor unintentionally was replaced by a full plastic one that isolated the MAF sensor did my issue seem to go away and my MAF, LTFT, and STFT readings seem to be rock steady compared to the other intakes I have used. Again, thank you for taking to time to explain your side, hopefully we can all benefit from each others findings.
| The Following User Says Thank You to IceFyre13th For This Useful Post: | 20valvewynn83 (10-19-2013) |
#21 |
#22 |
Drives: Mazdarati
Only if the intake gets its air from that area...........not the case here.
#23 |
fastest frs in sbg
Drives: sick ass ultramarine frs
Bro the ez fix or test to ur theory would be to un ground that support arm. Rubber between metal and use zip ties as the bolt. N if nothing changed then ur wrong about the maf getting grounded. If u would have tesedt this then u wouldnt have to make a guess on y u think they dont work. Now I think about it y didnt u try that? U wrote this whole this about it being grounded but u never ungrounded the damn thing. I kinda feel dumb after reading this.
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold 2014 firestorm frs |
#24 |
fastest frs in sbg
No one is actually testing that so for u guys to say dont buy that kind. Doesnt even make since
#25 | |
fastest frs in sbg
#26 |
fastest frs in sbg
@ PERRIN
notto thread jack but are ur claims of hp gain without or with a tune.
#27 |
Hit it with a hammer?
![]() Last edited by s2d4; 10-08-2013 at 09:56 AM. Reason: nobody wants to know how to test grounding. |
| The Following 2 Users Say Thank You to s2d4 For This Useful Post: | fuddbutter (10-08-2013), IceFyre13th (10-08-2013) |
#28 | |
Drives: Mazdarati
I have tried something else though tonight and reading your question, now that it is totally isolated I ran a wire to the tabs on the MAF sensor to the area I thought the bolt was grounding the intakes to...........ready for it, it wigged out again like before with the aluminum intakes. Removed my "artificial ground" just created and back to running right......
| The Following User Says Thank You to IceFyre13th For This Useful Post: | sosick (10-07-2013) |
| Tags |
| aluminum, intake, maf, plastic, trd |
| Metallic buzz over 4000 rpm? | Ingen | Issues | Warranty | Recalls / TSB | 37 | 11-21-2017 02:51 PM |
| Strange metallic rattle at around 3-4k rpm. | Brett | Issues | Warranty | Recalls / TSB | 17 | 11-08-2013 04:11 PM |
| True Metallic Plasti Dip | BeRZed | Cosmetic Modification (Interior/Exterior/Lighting) | 29 | 07-08-2013 03:30 AM |
| Green Metallic Vinyl Help | Sivtec | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 04-17-2013 09:12 PM |
| Metallic based tint | DSOmegaX | BRZ First-Gen (2012+) -- General Topics | 11 | 08-26-2012 03:15 PM |
