86WORX
Old 10-09-2013, 05:33 PM   #15
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by Dan@AWD View Post
Yup that's what I wanted to do.
You have pics of the other connection in the front?
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
is hard to take a pic
but one goes to the PCV Valve and the other one goes to the Port under the AC compressor
Old 07-27-2014, 09:46 PM   #16
Dan@AWD
Drives: 2013 Argento FR-S
Has anyone removed the PCV valve completely? Does anyone know the thread size of the PCV port on the block?
Dan@AWD is offline   Reply With Quote
Old 07-27-2014, 09:50 PM   #17
Dan@AWD
OK. It seems Revworks catch catch eliminates the PCV. They provide a vibrant adapter to do this. Does anyone know the part # on it?
http://www.revworksinc.com/Rev-Works...-S_p_3287.html
Old 07-27-2014, 09:59 PM   #18
mrk1
Drives: Sterling BRZ Ltd
Originally Posted by Dezoris View Post
This applies to any car with a variable PCV system. I went through a lot of this with my catch can research talking to radium about the importance of flow testing cans and making sure they maintain a proper seal.
PCV system is apart of engine design and ECU tuning straight from the factory. The vacuum is factored into the normal air fuel balance. So by plugging the port the port on the intake manifold it will cause as much as a 50-150 change in RPM drop. It can also cause fuel trims to change or ECU to trigger a more rich condition.
Bottom line is that Intake manifold was designed to take incoming blow by air flow from PCV and use it. Thats the point of the valve being variable.
Don't plug the hole on the IM. And don't vent your PCV line straight to the ground, it will spray oil and unspent fuel all over the under body or on the pavement.
I see your thought process on paper but I capped the port on my intake and saw zero side effects in practice. My catch can is VTA off both lines and the only down side is stink.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 07-27-2014, 10:01 PM   #19
mrk1
Dan, I have a spare engine at the shop. Tomorrow I will pull out the PCV and see if I can find out the threads, I am interested as well.
The Build Thread
The Following User Says Thank You to mrk1 For This Useful Post:
Dan@AWD (07-27-2014)
Old 07-27-2014, 10:04 PM   #20
Dan@AWD
Thanks!
Old 07-27-2014, 10:09 PM   #21
Dan@AWD
Updated first post.
Old 07-27-2014, 10:18 PM   #22
mrk1
I would like to have a pcv valve that references manifold conditions to operate but the gases get vented to my vta can.
The Build Thread
Old 07-28-2014, 10:47 AM   #23
mrk1
Looks to be 3/8 pipe threads. Not sure if its NPT or BSPT. The plunger is very easy to push up from the crank case side. This makes me believe that in a VTA setup the crank case pressure should have no problem moving this plunger up. How much flow is there is another thought.
The Build Thread
Dan@AWD (07-28-2014)
Old 07-28-2014, 01:37 PM   #24
Dan@AWD
Yeah I don't want there to be an issue VTA. I see a lot of setups still leaving the PCV on VTA, but technically should be removed with no vacuum present. Vibrant doesn't make a BSPT thread so I'm sure Revworks supplied a NPT.
Vibrant part #'s if anyone is curious to replace the PCV Valve with a -AN fitting:
  • Vibrant Part No: 10222 - Straight Adapter FItting; Size: -6 AN x 3/8" NPT
  • Vibrant Part No: 10221 - Straight Adapter Fitting; Size: -8AN x 3/8" NPT
  • Vibrant Part No: 10223 - Straight Adapter Fitting; Size: -10 AN x 3/8" NPT
The Following User Says Thank You to Dan@AWD For This Useful Post:
Sportsguy83 (07-28-2014)
Old 07-28-2014, 02:52 PM   #25
mrk1
Im going to try and nail down which they are. I know the oil port on the front is bspt.
The Build Thread
Old 07-29-2014, 02:46 AM   #26
Dan@AWD
For the oil sending unit? I'm pretty sure my kit came with a 1/8" NPT and no issues with it.
Old 07-30-2014, 11:31 AM   #27
diirk
diirk's Avatar
Drives: Audi S5
When I installed the FBM catch can I didn't want to pull the AC compressor because of the SC. But the line that runs out from it is easy to tap into. Just chase it out 6-8" and cut it there. just remove the remainder and cap it off.
diirk
15 Audi S5 DSG Daytona Grey | Pinnacle Tint
<SOLD>13 SWP BRZ Prem MT
diirk is offline   Reply With Quote
Old 07-30-2014, 06:39 PM   #28
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The Mach V Galley Adapter converts it from BSPT to 1/8 NPT
http://www.fastwrx.com/products/oil-gallery-plug
Search this Thread:
Advanced Search
High Revv NA Setup? dunphyjp Engine, Exhaust, Transmission 126 03-09-2017 11:49 PM
Bad Catch Can? grostoine Issues | Warranty | Recalls / TSB 7 09-19-2013 08:05 PM
Catch Can ArKiTeCkT Engine, Exhaust, Transmission 31 09-15-2013 04:07 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
