#1163 |
NASA SpecE30 Racer
Unless the valve is somewhere inside the block, it looks like it is just a hose barb on the block to me meaning it is just a PCV system with no valve.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#1164 | |
if we use race cars as empirical evidence, i would dare say practically none of them recirculate oil vapors back into the intake tract. even a dry sump system pulling highlevels of crank case vacuum has a oil tank that vents to atmosphere. yes, you need to figure out a way to relieve crankcase pressure, but oil vapors can cause detonation and gunk up motors...thats why you dont recirculate oil vapors i can only think of one instance where you would want crank gasses recirculated into the intake tract and that is when drag racers mix nitro into their oil and recirculate the crank/nitro vapors for a power gain. from a performance perspective, the best to worst the strategies for venting the crank case would be: drysump pump venting to atmosphere vacuum pump venting to atmosphere catch can venting to atmosphere direct mounted breather venting to atmosphere PCV recirculation non vented |
#1165 |
Drives: 2013 Scion FRS
![]() Our Kraftwerks Powered Scion FRS at the Import DPS booth during the Import Invasion event held at Cecil County Dragway |
#1166 |
Drives: 2013 Black FR-S
What proplem? The breather and PCV system (and the catch cans installed in-line with them) are meant to see vacuum. The check valve allows them to see vac but prevents them from seeing boost.
#1167 | |
That Guy
Drives: 2013 asphalt FRS MT
#1168 | |
but... who can answer how much vacuum needs to be pulled for it to matter? if you can answer that, then you will know the pcv system does little to seal rings. funny enough, the pcv wont do squat for sealing rings when the engine needs it the most at WOT because the manifold vacuum is near zero. from a practical standpoint, the amount of vacuum needed in the crankcase to make a difference is MUCH higher than what you might think, and it certainly cannot be passively achieved by the intake manifold pulling through a tiny rubber PCV tube. on race engines we need to use multiple -10 or -12 lines and a stout pump to actively pull enough vacuum for it to matter in terms generating more power from better ring seal. and im talking using standard tension rings. if you use low tension rings, you need to be pulling even more vacuum. anyways PCV recirc is for emissions and not performance Last edited by gmsii; 05-21-2014 at 07:28 PM. |
| The Following User Says Thank You to gmsii For This Useful Post: | Calum (05-21-2014) |
#1169 | |
That Guy
I'd love to actually get my hands on something that shows the engine load vs pcv air flow vs crankcase pressure. I know it would vary from platform to platform but even a general idea would be helpful. |
#1170 |
@post_break just came across your YouTube vids. are you running the Moto East FlexFuel kit now, or are you still running Visconti's V2?
#1171 |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Cusco catch can
All this talk about the value of catch cans and stuff, might as well ask the question here. I just received my Cusco catch can in the mail today... going to install on Friday but all instructions are in Japanese. Going to install on the PCV side. Based on the photo of the Cusco can below, is it safe to say the left side goes back into the intake manifold and the right side will go down into the crankcase?
#1172 | |
Professional Smartass
Drives: White Out FRS
#1173 | |
NASA SpecE30 Racer
- King Tut
#1174 |
#1175 |
NASA SpecE30 Racer
Then it shouldn't matter which side. It should look like this on a Kraftwerks car:
PCV hose barb > Cusco can inlet > Cusco can outlet > Check valve > intake manifold
- King Tut
| The Following User Says Thank You to King Tut For This Useful Post: | mit_peid (05-22-2014) |
#1176 |
Boosted Noob
So if it isn't baffled, means it doesn't matter which way is IN or OUT? This guy seemed to have used the left side to feed it back into the intake.
EDIT: Sounds like there's a simple DIY to stuff some steel wool into the can to make it a baffled can. Last edited by mit_peid; 05-22-2014 at 12:43 PM. |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 01:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 06:27 PM |
