Old 05-19-2014, 04:38 AM   #1051
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I'll clarify as well. The Rotrex does put more heat into the stock cooling system, but not so much that it can't handle it. In other words, the peak temps were the same.
However, (this is where the clarification comes in), the rate of fluctuation in the temperatures is now faster. The fans turn off at about 185F, and turn back on at about 195F (depends on which temp sensor you're logging). Once the fans turn on, coolant temps start to go down, and when they turn off, the temps start to go back up. The rate at which the temps goes back up was faster post-Rotrex, indicating that there was indeed more heat going into the coolant, but the fans were able to bring the temps down every time, also indicating that the stock system is more than capable of handling that extra horsepower.
When you start dumping oil heat into the radiator... well, my data set for that is not yet large enough to draw any conclusions.
I thought the fans turn on at 212 F someone was mentioned that and also suggesting lowering the fan activation to 200 F might help so I asked @moto-mike and he suggested that the moving air is more effective to reduce coolant temps than the fans, and the fans can be counterproductive since it may cause drag after 30mph..so I don't know
glamcem is offline   Reply With Quote
Old 05-19-2014, 05:05 AM   #1052
It depends on the car, and it depends on the fans.
Remember, we're adding restrictions in front of the radiator (intercooler), so you need to be going at a decent speed for the air flowing into to be "more" than what the fans can pull through the radiator. In the case of our testing, we're talking speeds between 60 and 100 mph, and the fan still pulls more than is being pushed through by the velocity.
Anecdotal evidence: even at 130MPH, a 12" 20 amp SPAL pulls more air than is pushed through a FMIC/AC condensor/Radiator stack, that is assisted with a louvered/vented hood and undertrays.
glamcem (05-19-2014)
Old 05-19-2014, 05:06 AM   #1053
Superstar
Drives: Honda
yesterday, I did my first lapping event with Kraftwerks and all I can say is wow, I have to re-learn to drive this car again since the shifting points and gear selection for the certain turns are completely changed
I also took some logs and my oil temps were about the same (260-265 F) with last time but I have to add the ambient temps were higher yesterday (highest was around 220F) but I noticed it recovers a lot quicker ( both oil and coolant temps) maybe I should combine my oil to air with an air to air , coolant temps were a bit higher and I think I might have left some air in the system when changing the radiator I will make sure there is no air left..
Thanks for the vid. How much power are you putting down?
Superstar is offline   Reply With Quote
Old 05-19-2014, 05:17 AM   #1054
glamcem
glamcem's Avatar
Sure, I didn't get a chance to take it to a dyno place but as soon as I can do that I will share some dyno graphs
Old 05-19-2014, 03:44 PM   #1055
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Originally Posted by NCItaly View Post
Just bought a used kit. Does anyone have a link to install instructions or maybe even a video? I can't seem to find anywhere. ..
Email us! We'll send them to you.
support@kraftwerksusa.com
KraftWerks is offline   Reply With Quote
Old 05-19-2014, 05:49 PM   #1056
TmP
TmP's Avatar
Drives: A bunch of 'em...
Add me to this elusive club. LOL
Kit ordered.
TmP is offline   Reply With Quote
The Following 2 Users Say Thank You to TmP For This Useful Post:
86SPEED (05-19-2014), Freeman (05-19-2014)
Old 05-19-2014, 07:03 PM   #1057
glamcem
glamcem's Avatar
Kit ordered.
congrats, don't make the same mistake I did and do this now before even start installing your kit
http://www.ft86club.com/forums/showthread.php?t=62709
, I've only left one hose un-clamped and it popped off at my last track event :/ and of course it was the hardest to reach (under the intake manifold)
The Following User Says Thank You to glamcem For This Useful Post:
TmP (05-19-2014)
Old 05-19-2014, 07:12 PM   #1058
madpcsupreme
Drives: 95 accord
hey guys, I just installed the kit and put in a 4 bar MAP with the "4bar base tune"
Now I got
1.rough idle,
2.CEL (P0107-MAP sensor low input),
3.a tracking control on while decelerating.
Any one has experience like this in the KW kit?
madpcsupreme is offline   Reply With Quote
Old 05-19-2014, 07:15 PM   #1059
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Did you call KW?
Freeman is offline   Reply With Quote
Old 05-19-2014, 07:21 PM   #1060
TmP
TmP's Avatar
Any other lessons learned that I should know about?
Are the instructions quite thorough?
Old 05-19-2014, 07:24 PM   #1061
Freeman
Freeman's Avatar
Do an inventory of the kit before you get started.
Old 05-19-2014, 07:34 PM   #1062
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Damn I was hoping to avoid this...
post_break is offline   Reply With Quote
Old 05-19-2014, 07:39 PM   #1063
glamcem
glamcem's Avatar
Subaru/Scion should've included clamps on all the vacuum lines imo. Also are you planning to upgrade radiator and add oil cooler, if so maybe it is the best time to do..
I think instructions were good but could be better for sure (including factory tq specs and putting the steps and pictures side by side), I would read the OP's and other members' installation tips on this thread (I have a few starting from page 38 and page 39)
such as including all the TQ specs in the service manual.
Few important time saving tips would be,
  • hose clamps prior to installation
  • putting the hoses on the oil filter, oil canister and bypass valve before installing them on the car since they will be hard to reach
  • be extra careful when priming the charger
Old 05-19-2014, 07:40 PM   #1064
glamcem
glamcem's Avatar
^^ this, I had no missing item but some people did so it wouldn't hurt
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
