#1023 |
Professional Smartass
Drives: White Out FRS
FYI the belt is a Gates TP1200-8MGT-20 PowerGrip GT2 Twin Power V-Belt 92320041. You can pick them up online for about $65.
| The Following 2 Users Say Thank You to post_break For This Useful Post: | Model Citizen (05-15-2014), zoth (05-15-2014) |
#1024 |
Drives: 2013 Ultramarine FR-S
Finally got to drive the car today. Holy crap this thing is fun! I can't wait until I can get over to the tuner and get a custom tune.
Anyone have any word on the availability of a smaller pulley for the blower? |
#1025 |
Drives: 2013 BRZ Premium Dark Gray Metallic
#1026 |
http://www.biedlers-belts.com/gates-...t-20-belt.html @digital_assassin maybe put this URL in the first post? |
| The Following User Says Thank You to post_break For This Useful Post: | glamcem (05-15-2014) |
#1027 | |
Thanks, that is a great price. Anyone here using a Omi 3 bar on the kit? I would like to see how it's mounted. If you could please attached you pics. Thanks in advance. |
#1028 |
NASA SpecE30 Racer
It mounts just the like the OEM sensor does on the driver side of the intake manifold with one bolt.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | zoth (05-15-2014) |
#1029 |
Drives: frs
quick update on C38 blower kit:
1. Kraftwerks does have a whole new molded pipe for C38 kit which they do provide, not some hacked-up couplers. 2. For those who have Circuit Werks lightweight pulleys, crank pulley seems to work just fine with the kit. 3. I was told the kit made 299whp on mustang dyno with stock header, overpipe back exhaust, fuel mods (pump and injectors) on 93 pump gas, and standard pulley. don't have the dyno sheet yet though. |
| The Following 3 Users Say Thank You to vgi For This Useful Post: |
#1030 | |
#1031 |
Drives: frs
#1032 |
Drives: 2022 BRZ Limited
yesterday, I did my first lapping event with Kraftwerks and all I can say is wow, I have to re-learn to drive this car again since the shifting points and gear selection for the certain turns are completely changed
![]() I also took some logs and my oil temps were about the same (260-265 F) with last time but I have to add the ambient temps were higher yesterday (highest was around 220F) but I noticed it recovers a lot quicker ( both oil and coolant temps) maybe I should combine my oil to air with an air to air , coolant temps were a bit higher and I think I might have left some air in the system when changing the radiator I will make sure there is no air left.. [ame="http://youtu.be/Fa1UWvB-Lrg"]http://youtu.be/Fa1UWvB-Lrg[/ame]
| The Following User Says Thank You to glamcem For This Useful Post: | Superstar (05-19-2014) |
#1033 |
260 with an oil cooler is unacceptable... do you have air directed toward it?
#1034 |
Mike a few things worth the mention since I have OEM oil cooler and it depends on the radiator, I should get better temps when I burp the coolant system.. and since I had the same oil temps when I was NA (completely stock power) with lower ambient temps I can only guess it will get better, if not maybe I can consider adding an air to oil cooler on top of my OEM cooling system ( if possible) so that I can keep my OEM cooler for warming purposes.. I will provide more data
#1035 | |
*edit* I just got around to watching your video. Do you normally shift early, even before the SC? Engine RPM has a direct correlation to oil temperature that is fairly independent of actual engine output. |
#1036 |
Drives: 2013 FR-S Matte Orange
So up at @Drift-Office today for tune refining after adding the 3" exhaust and came away with some really good results. Bob and Bill smoothed it out and it is not falling off at 6800rpm any more. I can't wait till tomorrow so I can drive it.
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 01:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 06:27 PM |
