Old 05-10-2014, 10:11 AM   #925
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Originally Posted by zoth View Post
I fell your pain man...
I'm freaking stuck...
What are you missing?
post_break is offline   Reply With Quote
Old 05-10-2014, 12:47 PM   #926
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Map sensor. Are your idler pulleys smooth or cogged?
zoth is offline   Reply With Quote
Old 05-10-2014, 02:53 PM   #927
SPCorBUST
SPCorBUST's Avatar
@zoth Picked mine up in person yesterday, they were cogged.
Having issue with the molded coupler though. I think its only a C38 issue though. Couldn't tell until I actually tried to fit it for half an hour... Its just too small.
SPCorBUST is offline   Reply With Quote
Old 05-10-2014, 03:23 PM   #928
zoth
zoth's Avatar
Try a Heat Gun...
So yours are cogged... @KraftWerks why, why, why ?
Old 05-10-2014, 03:27 PM   #929
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I may have gotten the wrong molded coupler when I left the facility today. At least, I actually hope that thats the case.
The one I have is smaller on one side and larger on the other. The larger side slides right over the hot side pipe perfectly, but the smaller side will not fit over the outlet of the supercharger.
My thoughts are that this means it was truly meant for the C30, since the larger side can slide over the supercharger outlet perfectly. After checking, it seems like it's because the supercharger outlet and the intercooler pipe inlets are almost the same size. (all of the pipe inlets and outlets are this size)
Tagging @KraftWerks for a reply here... Hope to get this resolved
Met some of the folks there and they were pleasant to deal with.
I am not following you, the coupler that connects the supercharger to the intake tube is straight 3" and there is only one 2.5" to 3" coupler and that should be used on the second portion of the cold side (on the left between the last IC piping behind the radiator cap) ..
Are you sure you are following the instructions correctly?
glamcem is offline   Reply With Quote
Old 05-10-2014, 03:40 PM   #930
SPCorBUST
SPCorBUST's Avatar
@glamcem The 3" pipe you are referring to the SC inlet - I am referring to the SC outlet. The other coupler you mentioned is where it needs to be. Section 6 Step 1 references the molded coupler which secures to the SC outlet - this piece is the one the bypass valve is attached to.
I think the outlet of the C30 is a 2.5", and the outlet of the C38 is a 3".
The Following User Says Thank You to SPCorBUST For This Useful Post:
glamcem (05-10-2014)
Old 05-10-2014, 03:45 PM   #931
SPCorBUST
SPCorBUST's Avatar
@vgi was your molded coupler the same size all the way through? Mine starts small then opens up to accommodate the hotside pipe.
What motor/exhaust/fuel are you getting tuned with?
Old 05-10-2014, 06:48 PM   #932
zoth
zoth's Avatar
For you guys using cogged idler pulley's is it the sound that's different or there is a performance effect? I don't think so, but might as well ask.
Old 05-10-2014, 07:06 PM   #933
SPCorBUST
SPCorBUST's Avatar
Maybe some non slippage benefit in the upper rpms? I may have read that somewhere, but I can't remember exactly so take it with a grain of salt.
Sent from my SGH-M919 using Tapatalk
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
zoth (05-10-2014)
Old 05-10-2014, 08:41 PM   #934
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Kraftwerks Supercharger Owners Thread
Primarily a benefit of less whine - near silent operation esp at lower RPMs. The KW supercharger pulley is cogged regardless so the idlers being cogged probably don't have much more benefit wrt to slippage.
mit_peid is offline   Reply With Quote
The Following 2 Users Say Thank You to mit_peid For This Useful Post:
SPCorBUST (05-10-2014), zoth (05-10-2014)
Old 05-11-2014, 01:21 AM   #935
zoth
zoth's Avatar
Anyone installed replacement cogged pulley's without taking mostly everything apart at the mounting plate area?
Old 05-11-2014, 01:25 AM   #936
mit_peid
Boosted Noob
mit_peid's Avatar
Thanks to @digital_assassin for these instructions to put on the cogged idlers w/ minimum effort.
1) Remove oil filter
2) Loosen the belt tensioner and remove that pulley
3) Remove the bolt for the pulley by the oil filter but don't remove the pulley yet, just let it hang.
4) Remove the pulley above the tensioner pulley.
5) Now you can remove the pulley by the oil filter.
6) Put new pulley on the belt at the oil cooler and let hang again
7) Install the pulley above the tensioner pulley.
8) Bolt up the pulley in front of the oil reservoir.
9) Install the tensioner pulley.
10) Install the oil filter.
SPCorBUST (05-11-2014), zoth (05-11-2014)
Old 05-11-2014, 12:29 PM   #937
zoth
zoth's Avatar
Time to close her up.
Old 05-11-2014, 01:15 PM   #938
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Things to note. The Revworks catchcan complicates the oil tank placement.....
Freeman is offline   Reply With Quote
Search this Thread:
Advanced Search
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
